Hi,My mipi data type is raw8.
I can get mipi data that video resolution for 15360384.
However, I can’t get mipi data that video resolution for 16384384.
what is the maximum value for width?
hello wyf,
- may I know what’s the usage for this aspect ratio, is it panorama use-case?
- according to Camera Architecture Stack, you should go through v4l2src since maximum supported width in [Camera Core] is 6144.
- could you please share commands and also the failure kernel message for reference.
thanks
Thanks for your reply
1)I am not must use this aspect ratio, just want the width is 16384 or 32768.
2)We get the mipi data by coding according to v4l2,the kernel message is below:
[ 6255.606156] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000002
[ 6255.614975] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC2 = 0x00000002
[ 6255.623731] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000202
[ 6255.631613] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000202
[ 6255.639876] nvcsi 150c0000.nvcsi: csi4_cil_check_status (0) CIL_INTR_STATUS 0x00000156
[ 6255.647853] nvcsi 150c0000.nvcsi: csi4_cil_check_status (0) CIL_ERR_INTR_STATUS 0x00000156
[ 6256.653985] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
