Hello @WayneWWW,
Thanks for the prompt response. I will try to upload the version to a storage space and reply to you. Yes I have multiple TX2 modules to clone, however, I failed by cloning the incomplete image on 2 TX2s, and both are now causing the recovery mode failure. Once I realized the issue, I cloned the proper image on other 2 different TX2 modules, and it worked perfectly out of the box.
I am happy that there could be a way to recover the device
I will need few hours to uploaded the incomplete image and get back to you.
@WayneWWW I sent you the image link over private message.
We can still flash the board after we flash with your system.img.
Really?. May be the difference between us is the board configuration, but then I don’t understand why in my boards alone I was unable to keep the device in recovery mode.
What can I do here?
If you have a different model of carrier board, e.g., the dev kit, then try your module on the different carrier board. If you succeed on one carrier board, but not the other, then you know it is an electrical issue.
That’s a good one, I will give it a try.
Thank you,
Yes, it seems to be board issue.
