I am trying to clone TX2 custom boards by flashing an image from my custom “original” board.
I’ve followed the instructions per https://elinux.org/Jetson/TX2_Cloning that is, on the host ubuntu PC by applying the following commands to prepare the image to be copied to the cloned units:
sudo ./flash.sh -r -k APP -G backup.img jetson-tx2 mmcblk0p1
sudo cp backup.img.raw bootloader/system.img
The size of the image is 30,064,771,072[B].
Then replacing the “original” cloned unit (=Jetson TX2 + Board) by new fresh units (directly from Factory) to be connected to the USB cable:
sudo ./flash.sh -r -k APP jetson-tx2 mmcblk0p1
After a suceesful flashing I am getting the following looped log (which crashed ~200msec after kernel starting)
[0000.271] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-03715cad)
[0000.279] I> Boot-device: eMMC
[0000.287] I> sdmmc bdev is already initialized
[0000.291] I> pmic: reset reason (nverc) : 0x4
[0000.324] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.344] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.350] W> No valid slot number is found in scratch register
[0000.356] W> Return default slot: _a
[0000.359] I> A/B: bin_type (16) slot 0
[0000.363] I> Loading partition bpmp-fw at 0xd7800000
[0000.368] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.373] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.398] I> Binary(16) of size 534416 is loaded @ 0xd7800000
[0000.404] W> No valid slot number is found in scratch register
[0000.409] W> Return default slot: _a
[0000.413] I> A/B: bin_type (17) slot 0
[0000.416] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.422] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.427] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.453] I> Binary(17) of size 604720 is loaded @ 0xd796c400
[0000.683] I> Loading SCE-FW ...
[0000.686] W> No valid slot number is found in scratch register
[0000.692] W> Return default slot: _a
[0000.695] I> A/B: bin_type (12) slot 0
[0000.699] I> Loading partition sce-fw at 0xd7300000
[0000.704] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.709] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.728] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.734] I> Init SCE
[0000.736] I> Loading APE-FW ...
[0000.739] W> No valid slot number is found in scratch register
[0000.745] W> Return default slot: _a
[0000.748] I> A/B: bin_type (11) slot 0
[0000.752] I> Loading partition adsp-fw at 0xd7400000
[0000.757] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.762] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.781] I> Binary(11) of size 77216 is loaded @ 0xd7400000
[0000.787] I> Copy BTCM section
[0000.790] W> No valid slot number is found in scratch register
[0000.796] W> Return default slot: _a
[0000.799] I> A/B: bin_type (13) slot 0
[0000.803] I> Loading partition cpu-bootloader at 0x96000000
[0000.808] I> Reading two headers - addr:0x96000000 blocks:1
[0000.814] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.834] I> Binary(13) of size 302064 is loaded @ 0x96000000
[0000.840] W> No valid slot number is found in scratch register
[0000.846] W> Return default slot: _a
[0000.849] I> A/B: bin_type (20) slot 0
[0000.853] I> Loading partition bootloader-dtb at 0x8520f400
[0000.858] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.864] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.886] I> Binary(20) of size 374528 is loaded @ 0x8520f400
[0000.892] W> No valid slot number is found in scratch register
[0000.897] W> Return default slot: _a
[0000.901] I> A/B: bin_type (14) slot 0
[0000.904] I> Loading partition secure-os at 0x8530f600
[0000.909] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.915] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.937] I> Binary(14) of size 394672 is loaded @ 0x8530f600
[0000.945] I> TOS boot-params @ 0x85000000
[0000.949] I> TOS params prepared
[0000.952] I> Loading EKS ...
[0000.954] I> A/B: bin_type (15) slot 0
[0000.958] I> Loading partition eks at 0x8590f800
[0000.963] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.968] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.987] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.992] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.997] I> Copied encrypted keys
[0001.001] I> boot profiler @ 0x275844000
[0001.005] I> boot profiler for TOS @ 0x275844000
[0001.010] I> Unhalting SCE
[0001.012] I> Primary Memory Start:80000000 Size:70000000
[0001.018] I> Extended Memory Start:f0110000 Size:1856f0000
[0001.024] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:38:54, Feb 19 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing .......
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0001.397] I> Welcome to Cboot
[0001.400] I> Cboot Version: t186-28749d1d
[0001.403] I> CPU-BL Params @ 0x275800000
[0001.407] I> 0) Base:0x00000000 Size:0x00000000
[0001.412] I> 1) Base:0x277f00000 Size:0x00100000
[0001.416] I> 2) Base:0x277e00000 Size:0x00100000
[0001.421] I> 3) Base:0x277d00000 Size:0x00100000
[0001.425] I> 4) Base:0x277c00000 Size:0x00100000
[0001.430] I> 5) Base:0x277b00000 Size:0x00100000
[0001.434] I> 6) Base:0x277800000 Size:0x00200000
[0001.439] I> 7) Base:0x277400000 Size:0x00400000
[0001.443] I> 8) Base:0x277a00000 Size:0x00100000
[0001.448] I> 9) Base:0x277300000 Size:0x00100000
[0001.452] I> 10) Base:0x276800000 Size:0x00800000
[0001.457] I> 11) Base:0x30000000 Size:0x00040000
[0001.461] I> 12) Base:0xf0000000 Size:0x00100000
[0001.466] I> 13) Base:0x30040000 Size:0x00001000
[0001.470] I> 14) Base:0x30048000 Size:0x00001000
[0001.474] I> 15) Base:0x30049000 Size:0x00001000
[0001.479] I> 16) Base:0x3004a000 Size:0x00001000
[0001.483] I> 17) Base:0x3004b000 Size:0x00001000
[0001.488] I> 18) Base:0x3004c000 Size:0x00001000
[0001.492] I> 19) Base:0x3004d000 Size:0x00001000
[0001.497] I> 20) Base:0x3004e000 Size:0x00001000
[0001.501] I> 21) Base:0x3004f000 Size:0x00001000
[0001.505] I> 22) Base:0x00000000 Size:0x00000000
[0001.510] I> 23) Base:0xf0100000 Size:0x00010000
[0001.514] I> 24) Base:0x00000000 Size:0x00000000
[0001.519] I> 25) Base:0x00000000 Size:0x00000000
[0001.523] I> 26) Base:0x00000000 Size:0x00000000
[0001.528] I> 27) Base:0x00000000 Size:0x00000000
[0001.532] I> 28) Base:0x84400000 Size:0x00400000
[0001.536] I> 29) Base:0x30000000 Size:0x00010000
[0001.541] I> 30) Base:0x278000000 Size:0x08000000
[0001.545] I> 31) Base:0x00000000 Size:0x00000000
[0001.550] I> 32) Base:0x276000000 Size:0x00600000
[0001.554] I> 33) Base:0x80000000 Size:0x70000000
[0001.559] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.563] I> 35) Base:0x00000000 Size:0x00000000
[0001.568] I> 36) Base:0x00000000 Size:0x00000000
[0001.572] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.577] I> 38) Base:0x84000000 Size:0x00400000
[0001.581] I> 39) Base:0x96000000 Size:0x02000000
[0001.586] I> 40) Base:0x85000000 Size:0x01200000
[0001.590] I> 41) Base:0x275800000 Size:0x00500000
[0001.595] I> 42) Base:0x00000000 Size:0x00000000
[0001.599] I> 43) Base:0x00000000 Size:0x00000000
[0001.603] GIC-SPI Target CPU: 4
[0001.607] Interrupts Init done
[0001.610] calling constructors
[0001.613] initializing heap
[0001.616] initializing threads
[0001.619] initializing timers
[0001.622] creating bootstrap completion thread
[0001.627] top of bootstrap2()
[0001.630] CPU: ARM Cortex A57
[0001.633] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.638] initializing platform
[0001.641] I> Bl_dtb @0x8520f400
[0001.644] I> gpio framework initialized
[0001.651] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.661] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.669] I> GPIO framework and drivers are initialized.
[0001.674] I> Boot-device: eMMC
[0001.681] I> sdmmc bdev is already initialized
[0001.712] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0001.729] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.735] W> opt-in fuse is not set, skip fuse_burning
[0001.740] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.745] W> No valid slot number is found in scratch register
[0001.751] W> Return default slot: _a
[0001.760] I> A/B: bin_type (21) slot 0
[0001.764] I> Loading kernel-dtb from partition
[0001.768] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.786] I> Kernel_dtb @0x80000000
[0001.789] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.799] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.806] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.815] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.826] I> fixed regulator driver initialized
[0001.859] I> register 'maxim' power off handle
[0001.865] I> virtual i2c enabled
[0001.868] I> registered 'maxim,max77620' pmic
[0001.872] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.886] I> Find /i2c@c250000's alias i2c7
[0001.890] I> Reading eeprom i2c=7 address=0x50
[0001.919] I> Device at /i2c@c250000:0x50
[0001.923] I> Reading eeprom i2c=7 address=0x57
[0001.927] E> I2C: slave not found in slaves.
[0001.931] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.939] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.945] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.954] E> eeprom: Failed to read I2C slave device
[0001.959] I> Eeprom read failed 0x3526070d
[0001.964] I> Find /i2c@c240000's alias i2c1
[0001.968] I> Reading eeprom i2c=1 address=0x51
[0001.973] E> I2C: slave not found in slaves.
[0001.977] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.985] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.991] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0002.000] E> eeprom: Retry to read I2C slave device.
[0002.005] E> I2C: slave not found in slaves.
[0002.009] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0002.017] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.023] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0002.032] E> eeprom: Failed to read I2C slave device
[0002.037] I> Eeprom read failed 0x3526070d
[0002.042] I> Find /i2c@3160000's alias i2c0
[0002.046] I> Reading eeprom i2c=0 address=0x50
[0002.050] E> I2C: slave not found in slaves.
[0002.054] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.062] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.068] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0002.077] E> eeprom: Failed to read I2C slave device
[0002.082] I> Eeprom read failed 0x3526070d
[0002.087] I> Find /i2c@3180000's alias i2c2
[0002.091] I> Reading eeprom i2c=2 address=0x54
[0002.095] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.101] E> I2C: slave not found in slaves.
[0002.105] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0002.113] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.119] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0002.129] E> eeprom: Failed to read I2C slave device
[0002.133] I> Disabling gpio chip_id = 2, gpio pin = 9
[0002.138] I> Eeprom read failed 0x00000000
[0002.142] I> Reading eeprom i2c=2 address=0x57
[0002.147] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.152] E> I2C: slave not found in slaves.
[0002.156] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.164] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.170] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0002.179] E> eeprom: Failed to read I2C slave device
[0002.184] I> Disabling gpio chip_id = 2, gpio pin = 9
[0002.189] I> Eeprom read failed 0x00000000
[0002.193] I> create_pm_ids: id: 3310-1000-D02-K, len: 15
[0002.198] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.233] I> enabling 'vdd-hdmi' regulator
[0002.249] I> regulator 'vdd-hdmi' already enabled
[0002.253] I> hdmi cable connected
[0002.262] I> setting 'vdd-pex-1v00' regulator to 1000000 micro volts
[0002.274] I> setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.283] E> cannot find any other nvdisp nodes
[0002.304] I> edid read success
[0002.319] I> edid read success
[0002.322] I> This is not a CEA-extension block!
[0002.326] I> width = 640, height = 480, frequency = 25174825
[0002.332] I> width = 640, height = 480, frequency = 25174825
[0002.337] I> width = 640, height = 480, frequency = 25174825
[0002.343] I> width = 640, height = 480, frequency = 25174825
[0002.348] I> width = 1920, height = 1080, frequency = 148500000
[0002.354] I> Best mode Width = 640, Height = 480, freq = 25174825
[0002.364] I> hdmi_enable, starting HDMI initialisation
[0002.372] I> hdmi_enable, HDMI initialisation complete
[0002.378] initializing target
[0002.381] calling apps_init()
[0002.384] starting app kernel_boot_app
[0002.406] I> found decompressor handler: lz4-legacy
[0002.411] I> decompressing BMP blob ...
[0002.423] I> Kernel type = Normal
[0002.426] I> Loading kernel-bootctrl from partition
[0002.431] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0002.445] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0002.452] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0002.459] I> ########## Fixed storage boot ##########
[0002.464] W> No valid slot number is found in scratch register
[0002.469] W> Return default slot: _a
[0002.473] I> A/B: bin_type (24) slot 0
[0002.489] I> Boot image size read from image header: 97de5
[0002.494] I> Boot image load address: 0x80400000
[0002.498] I> Loading kernel from partition
[0002.502] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.444] I> Validate kernel ...
[0003.447] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.455] I> Checking boot.img header magic ... [0003.459] I> [OK]
[0003.461] I> kernel-dtb is already loaded
[0003.465] I> Validate kernel-dtb ...
[0003.468] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.476] I> Kernel hdr @0x80400000
[0003.479] I> Kernel dtb @0x80000000
[0003.483] I> decompressor handler not found
[0003.487] I> Copying kernel image (622053 bytes) from 0x80400800 to 0x80600000 ... [0003.494] I> Done
[0003.496] I> Move ramdisk (len: 0) from 0x80498800 to 0x947d0000
[0003.503] I> Updated bpmp info to DTB
[0003.509] I> Ramdisk: Base: 0x947d0000; Size: 0x0
[0003.514] I> Updated initrd info to DTB
[0003.518] W> WARN: Fail to override "console=none" in commandline
[0003.524] I> Active rootfs suffix:
[0003.527] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.534] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.541] I> disabled_core_mask: 0xffffff0c
[0003.545] W> No valid slot number is found in scratch register
[0003.551] W> Return default slot: _a
[0003.554] I> Active slot suffix:
[0003.557] I> add_boot_slot_suffix: slot_suffix =
[0003.562] I> Linux Cmdline: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt rootfs.slot_suffix= tegra_fbmem2=0x140000@0x96081000 lut_mem2=0x2008@0x9607e000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[0003.615] I> Updated bootarg info to DTB
[0003.618] I> eeprom_get_mac_addr: MAC (type: 0): 48:b0:2d:11:1f:37
[0003.625] I> eeprom_get_mac_addr: MAC (type: 1): 48:b0:2d:11:1f:38
[0003.631] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:11:1f:39
[0003.637] E> Found no plugin manager ids in source DT
[0003.642] W> Add plugin manager ids from board info
[0003.647] W> "plugin-manager" doesn't exist, creating
[0003.652] W> "ids" doesn't exist, creating
[0003.656] W> "connection" doesn't exist, creating
[0003.660] W> "configs" doesn't exist, creating
[0003.665] I> create_pm_ids: id: 3310-1000-D02-K, len: 15
[0003.670] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0003.681] I> Adding plugin-manager/ids/3310-1000-D02=/i2c@c250000:module@0x50
[0003.688] W> "i2c@c250000" doesn't exist, creating
[0003.693] W> "module@0x50" doesn't exist, creating
[0003.699] I> Adding plugin-manager/ids/3310-1000-D02-K
[0003.707] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.712] I> Adding plugin-manager/configs/3310-power-config 00
[0003.718] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.724] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.730] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.736] I> Adding plugin-manager/configs/3310-display-config 00
[0003.742] I> Adding plugin-manager/cvm
[0003.746] W> "chip-id" doesn't exist, creating
[0003.750] I> Adding plugin-manager/chip-id/A02P
[0003.755] W> "odm-data" doesn't exist, creating
[0003.759] I> Adding /chosen/plugin-manager/odm-data
[0003.769] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.775] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.781] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.787] I> added [base:0x276600000, size:0x200000] to /memory
[0003.792] I> added [base:0x277000000, size:0x200000] to /memory
[0003.798] I> Updated memory info to DTB
[0003.803] E> add_disp_param: failed to get display params for du=1
[0003.811] W> "reset" doesn't exist, creating
[0003.815] W> "pmc-reset-reason" doesn't exist, creating
[0003.820] W> "pmic-reset-reason" d
[0003.827] I> Adding ecid(00000001646ca6c20000000005fb8180) to DT
[0003.833] I> disabled_core_mask: 0xffffff0c
[0003.845] I> Add serial number:1424420031169 as DT property
[0003.854] I> Plugin-manager override starting
[0003.860] I> node /plugin-manager/fragement@0 matches
[0003.870] I> node /plugin-manager/fragement@4 matches
[0003.883] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.903] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.912] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.921] I> node /plugin-manager/fragment-devslp@0 matches
[0003.934] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.948] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.971] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.985] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.996] I> node /plugin-manager/fragment-p3310-c01 matches
[0004.009] I> node /plugin-manager/fragment-p3310-c03 matches
[0004.047] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0004.074] I> Disable plugin-manager status in FDT
[0004.079] I> Plugin-manager override finished successfully
[0004.084] I> tegrabl_load_kernel_and_dtb: Done
[0004.094] I> Kernel EP: 0x80600000, DTB: 0x80000000
U-Boot 2020.04-g6b630d64fd (Feb 19 2021 - 08:38:59 -0800)
SoC: tegra186
Model: NVIDIA P2771-0000-500
Board: NVIDIA P2771-0000
DRAM:
7.8 GiB
MMC: sdhci@3400000: 1, sdhci@3460000: 0
Loading Environment from MMC...
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net:
Warning: ethernet@2490000 using MAC address from ROM
eth0: ethernet@2490000
Hit any key to stop autoboot: 2
1
0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1203 bytes read in 34 ms (34.2 KiB/s)
L4T boot options
1: primary kernel
2: backup kernel
Enter choice:
1: primary kernel
Retrieving file: /boot/initrd
7236792 bytes read in 191 ms (36.1 MiB/s)
Retrieving file: /boot/Image
34527240 bytes read in 831 ms (39.6 MiB/s)
append: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt rootfs.slot_suffix= tegra_fbmem2=0x140000@0x96081000 lut_mem2=0x2008@0x9607e000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
Retrieving file: /boot/tegra186-quill-p3310-1000-c03-00-base.dtb
346120 bytes read in 38 ms (8.7 MiB/s)
## Flattened Device Tree blob at 88400000
Booting using the fdt blob at 0x88400000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000088400000, end 0000000088457807
copying carveout for /host1x@13e00000/display-hub@15200000/display@15200000...
copying carveout for /host1x@13e00000/display-hub@15200000/display@15210000...
copying carveout for /host1x@13e00000/display-hub@15200000/display@15220000...
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.201-tegra (root@nvidia-desktop) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #235 SMP PREEMPT Fri Oct 8 08:21:25 IDT 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 80,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00140000@96081000
[ 0.000000] Found lut_mem2: 00002008@9607e000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022645
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt rootfs.slot_suffix= tegra_fbmem2=0x140000@0x96081000 lut_mem2=0x2008@0x9607e000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29392(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7276560K/8219380K available (15294K kernel code, 2934K rwdata, 6896K rodata, 8576K init, 609K bss, 189156K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009630000 ( 6912 KB)
[ 0.000000] .init : 0xffffff8009630000 - 0xffffff8009e90000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e90000 - 0xffffff800a16d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a16d808 - 0xffffff800a205cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009629] Console: colour dummy device 80x25
[ 0.014291] console [tty0] enabled
[ 0.017846] bootconsole [uart8250] disabled
[0000.176] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-03715cad)
[0000.184] I> Boot-device: eMMC
[0000.191] I> sdmmc bdev is already initialized
[0000.196] I> pmic: reset reason (nverc) : 0x0
[0000.229] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.249] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.255] W> No valid slot number is found in scratch register
[0000.261] W> Return default slot: _a
[0000.264] I> A/B: bin_type (16) slot 0
[0000.268] I> Loading partition bpmp-fw at 0xd7800000
The above terminal display loops forever.
Some more info:
The “Original” unit was SDKed with JP4.5.1.
I have also replaced the u-boot.bin files in the u-boot-p2771-0000-500 and u-boot-p2771-0000-000 directories per Flashing device tree from L4T 32.5.1 - #24 by JerryChang
I’ve also attached the host’s terminal during the whole process.
Flashing Terminal on Host.txt (45.7 KB)
Please advise what I’m doing wrong.
Regards.
