Just want to make sure that we’re on the same page:
On the ubuntu running host I edit the file /home/nvidia/HWImage/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/jetson-tx2.conf and add at the end of the file the above mentioned line:
I am not sure about the exact procedure to be done here since clone is getting involved.
Actually, I don’t care how you make it. The final result should be you need to see “console=none” and “keep_bootcon” shows up in your kernel command line. dmsg will show that.
I guess the process should require two flash process
You flash both jetson TX2, first one on devkit while another one on your custom board. And you shall see both side have this console setting.
Clone the image from devkit case to your custom board with the command you used. Boot up the device and make sure the kernel command line still has these properties. And you shall see the full log.
and actually your request is that the console will be output to none and the flag keep_bootcon will be added.
I guess that I could do it by the following procedure:
modify the /boot/extlinux/extlinux.conf on my original TX2
clone it (prepare/read the image)
write the image to another TX2 unit.
Does it make sense?
on host p2771-0000.conf.common - no change in the boot command line
on unit to the /boot/extlinux/extlinux.conf file - no change in the boot command line
BTW, I have a backup image on the flashed unit, that is when the unit boots I can select another image to boot from (a backup image stored on the /boot directory) in this case the unit boots OK. This means that all other partitions are good while the kernel image is defected for some reason. The original unit boots OK, so the process of reading the image from this unit is not working OK.
I keep on searching what should I change in order to add the keep_bootcon to the boot command line. Now I’m going to replace the lines as following:
If you are trying to say the kernel command line are not showing up…
I think you should share how you flashed the board and the boot up log so that other people can find out why something can work/cannot work…
If the kernel image might be the cause of your issue, why not you just copy /boot/Image from your cloned board and to your custom board to verify your assumption?
cannot see there the console=none keep_bootcon
The flashing operation was not changed during the whole discussion it is detailed here TX2 not booting after successful flashing :
sudo ./flash.sh -r -k APP jetson-tx2 mmcblk0p1
I shall copy the image from my cloned unit to the cusotm, and keep the discussion posted.
BTW, during my searches where I can modify the boot command line to take affect, I found that the following flag sdhci_tegra.en_boot_part_access is only depicted in the flash.sh file for the Nano type:
>elif [ "${target_rootdev}" = "cloning_root" ]; then
if [ "${tegraid}" = "0x21" ]; then
# Nano
CMDLINE_ADD="console=ttyS0,115200n8 sdhci_tegra.en_boot_part_access=1";
elif [ "${tegraid}" = "0x18" ]; then
# TX2
CMDLINE_ADD="console=ttyS0,115200n8";
elif [ "${tegraid}" = "0x19" ]; then
# Xavier
CMDLINE_ADD="console=ttyTCU0,115200n8";
else
echo "Unknown tegraid/board,exiting..";
exit 1
fi;
I’ve never used nano neither in the SDK nor on the unit, could you guess whats going on?
Regarding the settings:
I am not saying that flash.sh overwrites, all I say is, that the flag sdhci_tegra.en_boot_part_access is depicted in the flash script when programming a Nano type device.
The clone command is always same. Just do the full flash and make sure the kernel command line has the correct console setting we need for debug…
Not sure why you mentioned this. This is not related to your issue at all. What I am trying to ask you to do now is just one thing.
“Add that console setting and then reproduce the error again”. With such console setting, more log should get printed after “bootconsole [uart8250] disabled”.
I though that the command without the -r -k APP will overwrite the whole image.raw to the unit, but I guess it reflashed from scratch the unit. So now the unit is in mode as it was after SDK programming, where I need to configure the user name, etc…
Let me recap what I am trying to ask you to do… looks like you toally don’t understand what you are doing now… I don’t care about what was flashed on that board before. What I am asking now is doing the clean setup with below.
If you claim there is an issue with image cloned, then below steps shall give us the error again. But this time you will have more logs to check because we have new console setting in kernel cmdline.
You flash both jetson TX2, first one on devkit while another one on your custom board. And you shall see both side have this console setting. → Now you are doing this step. Please confirm if console setting is seen.
Is it clear now? I don’t want to tell this again so please ask right now if you still have any question.
No, we do not have the new console configuration, as you don’t tell me which configuration file to modify, and I’ve to modify the configuration files on the without any success.
Unless tyou advise where I should put the keep_bootcon configuration, the only thing that I can do is copy the image from my cloned unit to a new unit and check if the unit boots OK.
I think where you modified the configuration is fine. Actually, I am no jetson god so cannot 100% remember every config file would take effect since I have to take care about every SoC.
Please do share the log file so that we can check why it does not take effect.
