The same problem when I finished flashing Jetpack 3.1
U-Boot 2016.07-g0ce7ca2 (Jul 20 2017 - 00:45:25 -0700)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
213 bytes read in 78 ms (2 KiB/s)
p2771-0000 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
20280368 bytes read in 534 ms (36.2 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=4
## Flattened Device Tree blob at 92000000
Booting using the fdt blob at 0x92000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000092000000, end 000000009204664f
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-553) (gcc vers7
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible is
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5cf3000 s31232 r8192 d302
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa7
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=tty4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 byt)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7972328K/8204288K available (10976K kernel code, 1817K r)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 )
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 )
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9d7c400 ( 125 )
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 )
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 )
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 )
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f5f10000 ( 8031 )
[ 0.000000] .init : 0xffffffc0010cd000 - 0xffffffc0011f0000 ( 1164 )
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0010cd000 ( 16692 )
[ 0.000000] .data : 0xffffffc001211000 - 0xffffffc0013d7430 ( 1818 )
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398s
[ 0.009854] Console: colour dummy device 80x25
[ 0.014514] console [tty0] enabled
[ 0.018069] bootconsole [uart0] disabled
[ 0.022169] kmemleak: Kernel memory leak detector disabled
[ 0.022180] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.022192] pid_max: default: 32768 minimum: 301
[ 0.022234] Security Framework initialized
[ 0.022262] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022271] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 byt)
[ 0.022623] Initializing cgroup subsys freezer
[ 0.022634] Initializing cgroup subsys debug
[ 0.022772] CPU0 ipc=752
[ 0.022781] CPU1 ipc=1024
[ 0.022789] CPU2 ipc=1024
[ 0.022798] CPU3 ipc=752
[ 0.022807] CPU4 ipc=752
[ 0.022815] CPU5 ipc=752
[ 0.022846] ASID allocator initialised with 65536 entries
[ 0.046175] tegra-id: chipid=21817.
[ 0.046187] tegra-id: opt_subrevision=1.
[ 0.046195] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046807] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4s
[ 0.046826] DTB Build time: Jul 20 2017 00:50:45
[ 0.062594] CPU1: Booted secondary processor [4e0f0030]
[ 0.074084] CPU2: Booted secondary processor [4e0f0030]
[ 0.085817] CPU3: Booted secondary processor [411fd073]
[ 0.097830] CPU4: Booted secondary processor [411fd073]
[ 0.109800] CPU5: Booted secondary processor [411fd073]
[ 0.109863] Brought up 6 CPUs
[ 0.109915] SMP: Total of 6 processors activated.
[ 0.109927] CPU: All CPU(s) started at EL2
[ 0.110424] devtmpfs: initialized
[ 0.137670] Initilizing CustomIPI irq domain
[ 0.137872] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.138719] pinctrl core: initialized pinctrl subsystem
[ 0.138896] OS set in device tree is L4T.
[ 0.139102] regulator-dummy: no parameters
[ 0.139212] Initializing plugin-manager
[ 0.139269] Plugin module not found
[ 0.139684] node /plugin-manager/soc-prod-a02-fragment match with chip-id A0P
[ 0.140014] node /plugin-manager/fragement@0 match with odm-data enable-denvt
[ 0.140630] node /plugin-manager/fragement@4 match with odm-data enable-denvt
[ 0.141820] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with b0
[ 0.142198] node /plugin-manager/fragement-pmon-p3310-1000-300 match with bo0
[ 0.142454] node /plugin-manager/fragement-pmon-p3310-1000-800 match with bo0
[ 0.142674] node /plugin-manager/fragment-devslp@0 match with board >=3310-10
[ 0.143093] node /plugin-manager/fragment-500-pcie-config match with board >0
[ 0.143561] node /plugin-manager/fragment-500-xusb-config match with board >0
[ 0.143840] node /plugin-manager/fragment-500-e3325-pcie match with board >=0
[ 0.144214] node /plugin-manager/fragment-p3310-c00-comm match with board >=0
[ 0.144465] node /plugin-manager/fragment-p3310-c00-pmic match with board >=0
[ 0.144695] node /plugin-manager/fragment-p3310-c01 match with board >=3310-0
[ 0.144956] node /plugin-manager/fragment-p3310-c03 match with board >=3310-0
[ 0.146540] node /plugin-manager/fragment-e3326@0 match with board 3326-*
[ 0.147662] node /plugin-manager/fragment-p3310-c00-camera match with board 0
[ 0.149448] Adding domain adsp-pd to PM domain ape-pd
[ 0.151786] NET: Registered protocol family 16
[ 0.159115] console [pstore-1] enabled
[ 0.159126] pstore: Registered ramoops as persistent store backend
[ 0.159138] ramoops: attached 0x200000@0x96080000, ecc: 0/0
[ 0.169354] cpuidle: using governor ladder
[ 0.173819] cpuidle: using governor menu
[ 0.174993] bpmp: waiting for handshake
[ 0.175006] bpmp: handshake completed
[ 0.175045] bpmp: synchronizing channels
[ 0.175076] bpmp: channels synchronized
[ 0.175086] bpmp: mail init ok
[ 0.175412] vdso: 2 pages (1 code @ ffffffc001219000, 1 data @ ffffffc001218)
[ 0.175444] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.176397] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atoms
[ 0.177862] tegra_powergate_init: DONE
[ 0.177882] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4s
[ 0.177909] DTB Build time: Jul 20 2017 00:50:45
[ 0.178808] Tegra reboot handler registered.
[ 0.179874] Registering Tegra186 clocks (this may take a while)...done
[ 0.182065] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.182081] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.182093] arm-smmu 12000000.iommu: stage 1 translation
[ 0.182104] arm-smmu 12000000.iommu: stage 2 translation
[ 0.182114] arm-smmu 12000000.iommu: nested translation
[ 0.182127] arm-smmu 12000000.iommu: stream matching with 128 regist0
[ 0.182144] arm-smmu 12000000.iommu: SMMU address space size (0x800000) diff!
[ 0.182161] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 onl)
[ 0.182173] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.182185] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.231358] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.236841] iommu: Adding device 3460000.sdhci to group 0
[ 0.237665] iommu: Adding device 3400000.sdhci to group 1
[ 0.241590] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.242055] iommu: Adding device 3160000.i2c to group 3
[ 0.242472] iommu: Adding device c240000.i2c to group 4
[ 0.242833] iommu: Adding device 3180000.i2c to group 5
[ 0.243200] iommu: Adding device 3190000.i2c to group 6
[ 0.243644] iommu: Adding device 31b0000.i2c to group 7
[ 0.243970] iommu: Adding device 31c0000.i2c to group 8
[ 0.244309] iommu: Adding device c250000.i2c to group 9
[ 0.244619] iommu: Adding device 31e0000.i2c to group 10
[ 0.246561] iommu: Adding device 3210000.spi to group 11
[ 0.246934] iommu: Adding device c260000.spi to group 12
[ 0.247230] iommu: Adding device 3240000.spi to group 13
[ 0.248027] iommu: Adding device 3100000.serial to group 14
[ 0.248332] iommu: Adding device 3110000.serial to group 15
[ 0.248650] iommu: Adding device c280000.serial to group 16
[ 0.249018] iommu: Adding device 3130000.serial to group 17
[ 0.250215] iommu: Adding device 2490000.ether_qos to group 18
[ 0.250813] iommu: Adding device b000000.rtcpu to group 19
[ 0.251301] iommu: Adding device c1a0000.aon to group 20
[ 0.252180] Wake73 for irq=42
[ 0.252477] iommu: Adding device smmu_test to group 21
[ 0.252989] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.253049] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.253082] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.253115] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.253151] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.253182] mc-err: Set intmask: 0xf3140
[ 0.253417] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.254156] Wake76 for irq=199
[ 0.254176] Wake77 for irq=199
[ 0.254194] Wake78 for irq=199
[ 0.254228] Wake79 for irq=199
[ 0.254245] Wake80 for irq=199
[ 0.254261] Wake81 for irq=199
[ 0.254277] Wake82 for irq=199
[ 0.254417] iommu: Adding device 3530000.xhci to group 22
[ 0.254765] iommu: Adding device 3550000.xudc to group 23
[ 0.255534] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.255562] tegra-pmc: ### PMC reset source: Software reset
[ 0.255583] tegra-pmc: ### PMC reset level: L1
[ 0.255602] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.255854] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registerd
[ 0.255908] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.256066] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.256092] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.256582] iommu: Adding device 13e10000.host1x to group 24
[ 0.256812] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.257069] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.257303] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.257576] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.257792] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.258027] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.258252] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.258489] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.258960] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.259466] iommu: Adding device 15700000.vi to group 34
[ 0.259829] iommu: Adding device 15600000.isp to group 35
[ 0.260127] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.260340] iommu: Adding device 15340000.vic to group 37
[ 0.260526] iommu: Adding device 154c0000.nvenc to group 38
[ 0.260754] iommu: Adding device 15480000.nvdec to group 39
[ 0.261063] iommu: Adding device 15380000.nvjpg to group 40
[ 0.261293] iommu: Adding device 15500000.tsec to group 41
[ 0.261469] iommu: Adding device 15100000.tsecb to group 42
[ 0.262122] iommu: Adding device 15810000.se to group 43
[ 0.262331] iommu: Adding device 15820000.se to group 44
[ 0.262513] iommu: Adding device 15830000.se to group 45
[ 0.262715] iommu: Adding device 15840000.se to group 46
[ 0.263342] iommu: Adding device 17000000.gp10b to group 47
[ 0.264655] tegra-reset 5000000.clock: registered 193 resets.
[ 0.266691] iommu: Adding device d000000.bpmp to group 48
[ 0.266930] bpmp: ping status is 0
[ 0.267087] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3df
[ 0.267473] bpmp d000000.bpmp: probe ok
[ 0.269925] iommu: Adding device 2600000.dma to group 49
[ 0.270736] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.270787] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.270855] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.270901] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.270949] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.270994] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.271040] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.271161] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-o
[ 0.273126] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.273224] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-n
[ 0.274111] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.274343] iommu: Adding device sound to group 51
[ 0.276081] iommu: Adding device 3510000.hda to group 52
[ 0.277186] iommu: Adding device adsp_audio to group 53
[ 0.278745] iommu: Adding device 2993000.adsp to group 54
[ 0.288639] vdd-ac-bat: 5000 mV
[ 0.290834] vdd-1v8-ap: 1800 mV
[ 0.292094] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 0.292434] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 0.308733] SCSI subsystem initialized
[ 0.309197] usbcore: registered new interface driver usbfs
[ 0.309253] usbcore: registered new interface driver hub
[ 0.309371] usbcore: registered new device driver usb
[ 0.313425] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.313886] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.313986] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.315384] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.315474] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.327847] media: Linux media interface: v0.10
[ 0.327910] Linux video capture interface: v2.00
[ 0.331771] pps_core: LinuxPPS API ver. 1 registered
[ 0.331812] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 0.331852] PTP clock support registered
[ 0.332742] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.332780] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.334277] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.336102] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.336292] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.336381] gpiochip_add_data: registered GPIOs 216 to 223 on device: max776o
[ 0.342776] vddio-ddr: at 1125 mV
[ 0.346610] avdd_dsi_csi: 1200 mV
[ 0.350609] vdd-1v8: 1800 mV
[ 0.354609] vdd-3v3-sys: 3300 mV
[ 0.355247] spmic-ldo0: at 1800 mV
[ 0.355918] spmic-ldo1: at 800 mV
[ 0.358611] vddio-3v3: 3300 mV
[ 0.359243] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.362613] vdd-rtc: at 800 mV
[ 0.363236] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.365350] spmic-ldo6: at 1500 mV
[ 0.369350] vdd-pex-1v05: 1000 mV
[ 0.369888] dvdd-pex: 1000 mV
[ 0.370151] max77620 4-003c: max77620 probe successful
[ 0.370393] Advanced Linux Sound Architecture Driver Initialized.
[ 0.371353] en-vdd-sd: 3300 mV
[ 0.371947] en-vdd-cam: 1800 mV
[ 0.373822] vdd-hdmi: 5000 mV
[ 0.374022] vdd-usb0-5v: 5000 mV
[ 0.374197] vdd-usb1-5v: 5000 mV
[ 0.377820] en-vdd-ts-1v8: 1800 mV
[ 0.381821] en-vdd-ts-hv-3v3: 3300 mV
[ 0.382333] en-vdd-disp-3v3: 3300 mV
[ 0.382849] en-mdm-pwr-3v7: 3700 mV
[ 0.383393] en-vdd-disp-1v8: 1800 mV
[ 0.383907] en-vdd-cam-hv-2v8: 2800 mV
[ 0.384448] en-vdd-cam-1v2: 1200 mV
[ 0.384975] vdd-fan: 5000 mV
[ 0.385082] vdd-3v3: 3300 mV
[ 0.385834] dis-vdd-1v2: 1200 mV
[ 0.385963] en-vdd-vcm-2v8: 2800 mV
[ 0.386485] vdd-usb2-5v: 5000 mV
[ 0.386590] vdd-sys-bl: 3300 mV
[ 0.387136] en-vdd-sys: 1200 mV
[ 0.388837] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.390520] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.390904] clocksource: Switched to clocksource arch_sys_counter
[ 0.410257] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.410575] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cs
[ 0.411061] nvmap_page_pool_init: Total RAM pages: 2009466
[ 0.411077] nvmap_page_pool_init: nvmap page pool size: 251183 pages (981 MB)
[ 0.411215] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.415804] Wake76 for irq=199
[ 0.415816] Wake77 for irq=199
[ 0.415826] Wake78 for irq=199
[ 0.415835] Wake79 for irq=199
[ 0.415844] Wake80 for irq=199
[ 0.415852] Wake81 for irq=199
[ 0.415860] Wake82 for irq=199
[ 0.416603] thermal thermal_zone0: Registering thermal zone thermal_zone0 fom
[ 0.416809] thermal thermal_zone1: Registering thermal zone thermal_zone1 fom
[ 0.416922] thermal thermal_zone2: Registering thermal zone thermal_zone2 fom
[ 0.416998] thermal thermal_zone3: Registering thermal zone thermal_zone3 fom
[ 0.417386] thermal thermal_zone4: Registering thermal zone thermal_zone4 fom
[ 0.417526] thermal thermal_zone5: Registering thermal zone thermal_zone5 foa
[ 0.417674] thermal thermal_zone6: Registering thermal zone thermal_zone6 foa
[ 0.417831] thermal thermal_zone7: Registering thermal zone thermal_zone7 foe
[ 0.418127] isomgr_init(): iso emc max clk=1866000KHz
[ 0.418138] isomgr_init(): max_iso_bw=26870400KB
[ 0.418216] NET: Registered protocol family 2
[ 0.418522] TCP established hash table entries: 65536 (order: 7, 524288 byte)
[ 0.418743] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.419074] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.419135] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.419189] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.419346] NET: Registered protocol family 1
[ 0.419528] RPC: Registered named UNIX socket transport module.
[ 0.419541] RPC: Registered udp transport module.
[ 0.419551] RPC: Registered tcp transport module.
[ 0.419561] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.419680] Trying to unpack rootfs image as initramfs...
[ 0.433645] host1x 13e10000.host1x: initialized
[ 0.434463] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[ 0.436430] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.436530] audit: initializing netlink subsys (disabled)
[ 0.436571] audit: type=2000 audit(0.424:1): initialized
[ 0.443060] io scheduler noop registered (default)
[ 0.445598] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.446769] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.447858] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.448928] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.452371] tsec 15500000.tsec: initialized
[ 0.453512] tsec 15100000.tsecb: initialized
[ 0.455830] nvdec 15480000.nvdec: initialized
[ 0.459515] falcon 15340000.vic: initialized
[ 0.460498] falcon 154c0000.nvenc: initialized
[ 0.461469] falcon 15380000.nvjpg: initialized
[ 0.462236] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.462761] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.463270] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.463782] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.464280] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.464776] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.465281] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.465775] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.468357] DC OR NODE connected to /host1x/sor1
[ 0.468518] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:e
[ 0.468565] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.468608] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 register0
[ 0.468624] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_isos
[ 0.468628] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0
[ 0.476053] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = s
[ 0.476072] tegra_nvdisp_bandwidth_register_max_config: max config EMC floorz
[ 0.476088] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = z
[ 0.476132] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.476147] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.476297] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.478404] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initid
[ 0.478657] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use de
[ 0.478677] PD DISP0 index2 UP
[ 0.478783] kfuse 3830000.kfuse: initialized
[ 0.479526] PD DISP1 index3 UP
[ 0.479685] PD DISP2 index4 UP
[ 0.480013] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.480492] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.482393] console [ttyS0] disabled
[ 0.482445] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 2a
[ 0.517319] Unsupported HDMI VIC 15, ignoring
[ 0.517321] Unsupported HDMI VIC 29, ignoring
[ 0.517323] Unsupported HDMI VIC 114, ignoring
[ 0.517324] Unsupported HDMI VIC 81, ignoring
[ 0.517331] V_REF_TO_SYNC >= 1; H_REF_TO_SYNC < 0
[ 0.517335] tegradc 15210000.nvdisplay: Display timing doesn't meet restrict.
[ 0.517338] PD DISP2 index4 DOWN
[ 0.517499] PD DISP1 index3 DOWN
[ 0.517641] PD DISP0 index2 DOWN
[ 0.519462] tegradc 15210000.nvdisplay: probed
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7 | VT102 | Offline | ttyUSB0
How to fix this? Thanks
