Hello, so I’m testing out TX2 NX and plan to add custom camera driver but I have noticed an issue even before trying to add custom stuff to the kernel.
So I set up the Jetson TX2 NX on Xavier NX Devkit with SDK Manager and everything works fine - display, USB, etc.
Now as a precaution, before adding my custom stuff, I tried to compile and flash completely stock kernel and DTB from L4T 32.6.1 sources. Compiling went without issues but after flashing kernel-dtb the display wasn’t working anymore and the Jetson was stuck on boot (kinda halfway - desktop didn’t work - it was failing on NPModel init and Docker container runtime init) unfortunately I don’t have logs for that part exactly.
Loaded: loaded (/etc/systemd/system/nvpmodel.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2021-08-10 11:49:30 EEST; 39min ago
Process: 5191 ExecStart=/usr/sbin/nvpmodel -f /etc/nvpmodel.conf (code=exited, status=255)
Main PID: 5191 (code=exited, status=255)
aug 10 11:49:30 test-tx2nx nvpmodel[5191]: NVPM ERROR: failed to write PARAM GPU_POWER_CONTROL_ENABLE: ARG GPU_PWR_CNTL_EN: PATH: /sys/devices/gpu.0/power/control VAL: on
aug 10 11:49:30 test-tx2nx nvpmodel[5191]: NVPM ERROR: Error opening /sys/devices/17000000.gp10b/devfreq/17000000.gp10b/available_frequencies: 2
aug 10 11:49:30 test-tx2nx nvpmodel[5191]: NVPM ERROR: failed to read PARAM GPU: ARG FREQ_TABLE: PATH /sys/devices/17000000.gp10b/devfreq/17000000.gp10b/available_frequencies
aug 10 11:49:30 test-tx2nx nvpmodel[5191]: NVPM ERROR: Error opening /sys/devices/gpu.0/power/control: 2
aug 10 11:49:30 test-tx2nx nvpmodel[5191]: NVPM ERROR: failed to write PARAM GPU_POWER_CONTROL_DISABLE: ARG GPU_PWR_CNTL_DIS: PATH: /sys/devices/gpu.0/power/control VAL: auto
aug 10 11:49:30 test-tx2nx nvpmodel[5191]: NVPM ERROR: failed to set power mode!
aug 10 11:49:30 test-tx2nx nvpmodel[5191]: NVPM ERROR: optMask is 2, no request for power mode
aug 10 11:49:30 test-tx2nx systemd[1]: nvpmodel.service: Main process exited, code=exited, status=255/n/a
aug 10 11:49:30 test-tx2nx systemd[1]: nvpmodel.service: Failed with result 'exit-code'.
aug 10 11:49:30 test-tx2nx systemd[1]: Failed to start nvpmodel service.
Here’s the command I used to flash the device:
sudo ./flash.sh -r -k kernel-dtb -d kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb jetson-xavier-nx-devkit-tx2-nx mmcblk0p1
After that I copied Image file to /boot/ directory
What could be the problem here? Am I doing the flashing wrong?
