The folder tree of “Linux_for_Tegra” add to attached file
folder-tree (41.6 KB)
Is your disk that used to save Linux_for_Tegra a ext4 file system?
No,we used ntfs
There is not enough space. So we use a partition of window
ext4 is required.
FYI, NTFS has no concept of Linux permissions. When generating an image for flash from the “Linux_for_Tegra/rootfs/
” content (normally ext4
) the permissions are inherited and transferred to the image. NTFS destroys much of that permission system. Flash will appear to work, but the system will be unusable and mandate a complete reflash (the damage from NTFS is so extreme there is no point in trying to “fix” this).
If you were using a cloned image which already had the filesystem within it, then it wouldn’t matter about using NTFS since no image would be created from damaged permissions.
we got it.
thank you !
ok
thank you!
