The TX2NX has an SD card footprint. Can the connector be simply soldered on and used? Is there any software changes that need to be done in order to enable this feature?
Thank you.
Thank you.
We don’t suggest to change the module internal design.
I understand you do not suggest it.
However my question remains, will it function? Does particular software have to be incorporated to make the SD card function?
It is not validated, no suggestion on that.
