TX2 NX SPI pinmux setting on R32.6.1 error
Below is the pin configure by jetson-io,
You can add it manually.
        pinmux@2430000 {
                compatible = "nvidia,tegra186-pinmux";
                status = "okay";
                phandle = <0x89>;
                reg = <0x0 0x2430000 0x0 0x15000 0x0 0xc300000 0x0 0x4000>;
                pinctrl-0 = <0x16e>;
                #gpio-range-cells = <0x3>;
                linux,phandle = <0x89>;
                pinctrl-names = "default";
                exp-header-pinmux {
                        phandle = <0x16e>;
                        linux,phandle = <0x16e>;
                        hdr40-pin21 {
                                nvidia,enable-input = <0x1>;
                                nvidia,pins = "gpio_wan6_ph1";
                                nvidia,lpdr = <0x0>;
                                nvidia,tristate = <0x0>;
                                nvidia,function = "spi1";
                                nvidia,pull = <0x1>;
                        hdr40-pin18 {
                                nvidia,pins = "gpio_sen4_pv4";
                                nvidia,function = "spi2";
                        hdr40-pin24 {
                                nvidia,pins = "gpio_wan8_ph3";
                        hdr40-pin22 {
                                nvidia,pins = "gpio_sen2_pv2";
                        hdr40-pin19 {
                                nvidia,pins = "gpio_wan7_ph2";
                        hdr40-pin37 {
                                nvidia,pins = "gpio_sen3_pv3";
                        hdr40-pin23 {
                                nvidia,pins = "gpio_wan5_ph0";
                        hdr40-pin13 {
                                nvidia,pins = "gpio_sen1_pv1";
