I use PCIe0 to extend 2 Ethernet(RJ45) port, using RTL8111E,
What is the connections between the TX2 and the RTL8111E?
what should I do with the software?
Hi qiusihai,
RTL8111E is a driver for your new ethernet card. As you can install it on x86 linux, it is basically the same as on tx2.
http://www.realtek.com.tw/products/productsView.aspx?Langid=1&PFid=5&Level=5&Conn=4&ProdID=239
I use PEX_RX0_AP_P/N and PEX_CLK0_P/N. Why there is “No Device detected” message?
It is not clear from this thread whether you are using Nvidia provided base board or you are using a custom base board.
I use a new base board. I figure out the problem.
