Hi Guys,
When run our deep-learning application, sometimes TX2 will reboot directly. We catch the dmesg of reboot. There are may be some clue that “PMC reset source: Denvor watchdog time out”. Can you help us figure out the root cause?
The attachment is whole dmesg info, and also highlight useful dmesg info below. Hope it is helpful.
[Fri Feb 5 12:50:12 2021] iommu: Adding device 3550000.xudc to group 23
[Fri Feb 5 12:50:12 2021] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[Fri Feb 5 12:50:12 2021] tegra-pmc: ### PMC reset source: Denvor watchdog time out
[Fri Feb 5 12:50:12 2021] tegra-pmc: ### PMC reset level: L1
[Fri Feb 5 12:50:12 2021] tegra-pmc: ### PMC reset status reg: 0x9
[Fri Feb 5 12:50:12 2021] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[Fri Feb 5 12:50:12 2021] tegra-pmc c360000.pmc: IO padctrl driver initialized
[Fri Feb 5 12:50:12 2021] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[Fri Feb 5 12:50:12 2021] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[Fri Feb 5 12:50:12 2021] iommu: Adding device 13e10000.host1x to group 24
[Fri Feb 5 12:50:12 2021] iommu: Adding device 13e10000.host1x:ctx0 to group 25
dmesg.pmic (69.7 KB)
