During our stability test of our Video Analysis Product on TX2, we encountered several crashes caused by the decoder.
Please confirm this as a BUG of JetPack or misuse of multimedia API.
[Reproduce]
Input: 12x 1080p@25FPS H264 RTSP
Start video analyzer program
run for 6~7 days (with no reconnect or error log)
Crash in libnvmmlite_video.so with the following Backtrace
[Test Software Environment]
JetPack 3.3
Decoder: multimedia API (instead of gstreamer)
NVPMode: Max-N, Fixed at highest clock rate
No DeepStream SDK
Fixed a bug according to the following link.
https://devtalk.nvidia.com/default/topic/1036111/jetson-tx2/-mmapi-decode-more-than-one-h264-file-get-problem-when-trying-to-modify-00_video_decode/post/5265055/#5265055
[Backtrace]
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000007f5e352bd8 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so
[Current thread is 1 (Thread 0x7d1111d050 (LWP 17596))]
(gdb) bt
#1 0x0000007f4b0a7688 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvparser.so
#2 0x0000007f4b0a8c60 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvparser.so
#3 0x0000007f4b0a5f6c in video_parser_parse () from /usr/lib/aarch64-linux-gnu/tegra/libnvparser.so
#4 0x0000007f5e34ac90 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so
#5 0x0000007f5e3e36dc in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvos.so
#6 0x0000007f5e803fc4 in start_thread (arg=0x7f5e3e36a0) at pthread_create.c:335
#7 0x0000007f5e5082e0 in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:89
dmesg log
[Tue Jan 15 16:01:29 2019] track_console_f[17596]: unhandled level 2 translation fault (11) at 0x00000070, esr 0x92000046
[Tue Jan 15 16:01:29 2019] pgd = ffffffc1a4ba8000
[Tue Jan 15 16:01:29 2019] [00000070] *pgd=000000022ff2d003, *pud=000000022ff2d003, *pmd=0000000000000000
[Tue Jan 15 16:01:29 2019] CPU: 4 PID: 17596 Comm: track_console_f Not tainted 4.4.38-tegra #1
[Tue Jan 15 16:01:29 2019] Hardware name: quill (DT)
[Tue Jan 15 16:01:29 2019] task: ffffffc1a6d50c80 ti: ffffffc137140000 task.ti: ffffffc137140000
[Tue Jan 15 16:01:30 2019] PC is at 0x7f5e352bd8
[Tue Jan 15 16:01:30 2019] LR is at 0x7f5e352ff8
[Tue Jan 15 16:01:30 2019] pc : [<0000007f5e352bd8>] lr : [<0000007f5e352ff8>] pstate: 60000000
[Tue Jan 15 16:01:30 2019] sp : 0000007d1111a8c0
[Tue Jan 15 16:01:30 2019] x29: 0000007d1111c840 x28: 00000000ffffffff
[Tue Jan 15 16:01:30 2019] x27: 000000007b2296b0 x26: 0000000000000000
[Tue Jan 15 16:01:30 2019] x25: 0000000000007c9a x24: 0000000000000001
[Tue Jan 15 16:01:30 2019] x23: 0000007f5e3d9000 x22: 0000000000000000
[Tue Jan 15 16:01:30 2019] x21: 00000000ad389000 x20: 000000008772a000
[Tue Jan 15 16:01:30 2019] x19: 00000000ad388000 x18: 0000000000000003
[Tue Jan 15 16:01:30 2019] x17: 0000007f5e4baa40 x16: 0000007f5e3d92f0
[Tue Jan 15 16:01:30 2019] x15: 000000004774d000 x14: 1010101010101010
[Tue Jan 15 16:01:30 2019] x13: 1010101010101010 x12: 1010101010101010
[Tue Jan 15 16:01:30 2019] x11: 1010101010101010 x10: 1010101010101010
[Tue Jan 15 16:01:30 2019] x9 : 1010101010101010 x8 : 1010101010101010
[Tue Jan 15 16:01:30 2019] x7 : 1010101010101010 x6 : 0000000000000001
[Tue Jan 15 16:01:30 2019] x5 : 000000008772a420 x4 : 0000000000000000
[Tue Jan 15 16:01:30 2019] x3 : 0000000000000000 x2 : 0000000000001060
[Tue Jan 15 16:01:30 2019] x1 : 0000000000000002 x0 : 000000008b126800
[Tue Jan 15 16:01:30 2019] Library at 0x7f5e352bd8: 0x7f5e339000 /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so
[Tue Jan 15 16:01:30 2019] Library at 0x7f5e352ff8: 0x7f5e339000 /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so
[Tue Jan 15 16:01:30 2019] vdso base = 0x7f8150b000
