I get three warnings when using omxh265enc in the below pipeline. Can anyone help me clear them up? What is the consequence of these warnings? As-is the video streams successfully.
- WARN omx gstomx.c:2836:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs
- WARN omxh265enc gstomxh265enc.c:146:gst_omx_h265_enc_set_format: Setting profile/level not supported by component
- WARN omxvideoenc gstomxvideoenc.c:1804:gst_omx_video_enc_set_format: Error setting temporal_tradeoff 0 : Vendor specific error (0x00000001)
nvcamerasrc fpsRange="30.0 30.0" sensor-id=1 ! capsfilter caps=video/x-raw(memory:NVMM),width=(int)1920,height=(int)1080,format=(string)I420,framerate=(fraction)30/1 ! nvvidconv flip-method=0 name=nvv ! omxh265enc control-rate=3 bitrate=3400000 ! mpegtsmux ! tee name=t2 t2. ! queue ! tcpserversink port=8555 host=0.0.0.0 t2. ! queue ! filesink name=record location=./sa1553133479.977801.ts
0:00:00.056558142 19958 0xb30900 WARN omx gstomx.c:2836:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/nvidia/.config:/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
Available Sensor modes :
1948 x 1096 FR=60.000000 CF=0x1009208a10 SensorModeType=4 CSIPixelBitDepth=12 DynPixelBitDepth=12
NvCameraSrc: Trying To Set Default Camera Resolution. Selected sensorModeIndex = 0 WxH = 1948x1096 FrameRate = 60.000000 ...
Framerate set to : 30 at NvxVideoEncoderSetParameter0:00:01.094239437 19958 0xb861e0 WARN omxh265enc gstomxh265enc.c:146:gst_omx_h265_enc_set_format:<omxh265enc-omxh265enc0> Setting profile/level not supported by component
NvMMLiteOpen : Block : BlockType = 8
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
0:00:01.095290016 19958 0xb861e0 WARN omxvideoenc gstomxvideoenc.c:1804:gst_omx_video_enc_set_format:<omxh265enc-omxh265enc0> Error setting temporal_tradeoff 0 : Vendor specific error (0x00000001)
===== NVENC blits (mode: 1) into block linear surfaces =====
