Hi everyone,
I use TX2 bsp version R32.3.1. It could not output info leve message via serial terminal, for example I use dev_info() function output message, there is no message output via serial terminal,but use dmesg tool can display the message. I use command cat /proc/sys/kernel/printk it output “6 6 1 7 4”.
In <kernel_src>\kernel\kernel-4.9\include\linux\printk.h there are macros definition as below:
#define CONSOLE_LOGLEVEL_SILENT 0 /* Mum's the word */
#define CONSOLE_LOGLEVEL_MIN 1 /* Minimum loglevel we let people use */
#define CONSOLE_LOGLEVEL_QUIET 4 /* Shhh ..., when booted with "quiet" */
#define CONSOLE_LOGLEVEL_DEFAULT 7 /* anything MORE serious than KERN_DEBUG */
#define CONSOLE_LOGLEVEL_DEBUG 10 /* issue debug messages */
#define CONSOLE_LOGLEVEL_MOTORMOUTH 15 /* You can't shut this one up */
In <kernel_src>\kernel\kernel-4.9\kernel\printk\printk.c console_printk array defined as below:
int console_printk[5] = {
CONSOLE_LOGLEVEL_DEFAULT, /* console_loglevel */
MESSAGE_LOGLEVEL_DEFAULT, /* default_message_loglevel */
CONSOLE_LOGLEVEL_MIN, /* minimum_console_loglevel */
CONSOLE_LOGLEVEL_DEFAULT, /* default_console_loglevel */
MESSAGE_LOGLEVEL_DEFAULT, /* default_devkmsg_loglevel */
How can I output info level message via serial terminal? Thanks.
