您好我这里刷机过程钟发现两块tx2核心刷完机以后断电会自动进入recovery模式,无法正常启动,其他的核心都正常,使用的载板是官方开发套件和定制载板两者都这样,刷机的版本是3251和3261,刷完以后正常启动但是就是不能断电,断电以后就又是recovery,这样的案例我看之前有人问过,请问如何解决?
Are you sure about it is in recovery mode? I mean you can flash the board under such case?
是的他又出现了nvidia crop,还可以刷机
If only two of your boards have such issue, it looks like module issue then. You can try RMA for these two modules.
好的感谢
