Hi, I was following the official guide to flash my new Nvidia TX2 with SDK Manager. I’m flashing the latest version of JetPack 4.6.2. In the beginning, the TX2 is able to start the GUI and set up the user info without a problem. But after setting up the user info on TX2 and finishing the flash procedure on the SDK manager, the gdm service can not be started successfully on the TX2 and keep restarting to make the screen flickering. Here are some log files of my TX2 system. Could you please help me point out which step is going wrong? Thank you!
Xorg.0.log (7.5 KB)
gdm service status
● gdm.service - GNOME Display Manager
Loaded: loaded (/lib/systemd/system/gdm.service; static; vendor preset: enabled)
Active: active (running) since Wed 2022-05-11 13:36:48 CST; 21min ago
Process: 16010 ExecStartPre=/usr/share/gdm/generate-config (code=exited, status=0/SUCCESS)
Main PID: 16033 (gdm3)
Tasks: 3 (limit: 4915)
CGroup: /system.slice/gdm.service
└─16033 /usr/sbin/gdm3
May 11 13:39:08 ubuntu gdm3[16033]: Child process -26742 was already dead.
May 11 13:39:08 ubuntu gdm-launch-environment][26748]: pam_unix(gdm-launch-environment:session): session opened for user gdm by (uid=0)
May 11 13:39:08 ubuntu gdm-launch-environment][26748]: pam_unix(gdm-launch-environment:session): session closed for user gdm
May 11 13:39:08 ubuntu gdm3[16033]: GdmLaunchEnvironment: Unknown user gdm
May 11 13:39:08 ubuntu gdm3[16033]: GLib-GObject: g_object_set: assertion 'G_IS_OBJECT (object)' failed
May 11 13:39:08 ubuntu gdm3[16033]: Child process -26763 was already dead.
May 11 13:39:08 ubuntu gdm3[16033]: Child process 26748 was already dead.
May 11 13:39:08 ubuntu gdm3[16033]: Unable to kill session worker process
May 11 13:39:08 ubuntu gdm3[16033]: Unable to run script: Too many open files
