hello everyone:
Must I execute the jetpack-14t-3,2.run script the second time I brush the system?Can you directly operate a certain command to directly call out the “post install limitation” window to brush the system
Not sure what you mean by “brush”. You can uncheck anything you don’t want to do, so for example, you can flash without adding extra packages…or at some later date you can add packages without flash. Just make sure items you are not interested in are unchecked.
If you do add packages later without flashing, then you will probably need to enter the IP address when asked.
