imini
July 10, 2020, 10:04am
1
hi,
i’m trying to convert float* to mat.
float * imgRGBA;
Mat dst( height, width, CV_32FC1, imgRGBA);
imshow(“img”,dst);
this code results segmentation fault.
[cuda] registere 4915200 byte openGL texture for interop access (640x480)
segmentation fault (core dumped)
what should i do, to solve this error?
Hi @imini , can you show the code that sets the imgRGBA pointer? My guess is that it is CUDA device memory, and not accessible from the CPU like Mat and imshow() are trying to use.
If you are capturing imgRGBA from camera, change the call to this:
camera->CaptureRGBA(&imgRGBA, 1000, true); // 'true' enables ZeroCopy
Specifying true for the optional third parameter to CaptureRGBA() will put the image in mapped ZeroCopy memory, where both the CPU and GPU have access. So you can use the memory from the CPU then.
imini
July 10, 2020, 2:44pm
3
hi, thank you so much for your help.
https://github.com/dusty-nv/jetson-inference/blob/master/examples/detectnet-camera/detectnet-camera.cpp
here is the code that sets imgRGBA pointer.
like what you said, i specified true
the imshow() runs well now,
but the problem is by imshow(“img”,dst), i only can see white window.
i cannot see my dst image…
I think you may need to create your Mat object as CV_32FC4 (4-channel float) instead of CV_32FC1 (single-channel float).
imini
July 10, 2020, 2:58pm
5
i’ve changed CV_32FC1 to CV_32FC4, but i still have same problem…
Hmm. Before you make your Mat object, can you insert a call to cudaDeviceSynchronize()?
And do you know if imshow() supports floating-point formats?
imini
July 10, 2020, 3:16pm
7
cudaDeviceSynchronize();
Mat dest(480,640,CV_32Fc4,imgRGBA);
imshow(“pic”,dest)
i’ve tried this, but same problem…
you mean imshow(“pic”,imgRGBA)…?
this makes error, so i don’t think imshow supports floating-point formats
You might want to us cvCvtColor to change your Mat from floating-point to 8-bit unsigned char format.
imini
July 10, 2020, 3:35pm
9
I’m so sorry, but i don’t understand well yet.
where should i use cvCvtColor…?
Between Mat dst() and imshow()
<-- cvCvtColor() here
imshow(“pic”,dest)
imini
July 10, 2020, 3:44pm
11
what about cvCvtColor()'s arguments?
Let me give it a try here to see if I can get it working.
BTW is there a reason just to not use the glDisplay? It would avoid the extra overhead.
imini
July 10, 2020, 4:07pm
13
because to combine my code,
i should convert imgRGBA to mat type
OK, I did a test with OpenCV and found the problem:
OpenCV expects that floating-point images have pixel values in the range of [0,1] but jetson-inference uses pixels in the range of [0,255]
OpenCV expects the image to be in BGR format, but jetson-inference uses RGB format
With this code, it is working:
#include "cudaNormalize.h" // include this above
CUDA(cudaNormalizeRGBA((float4*)imgRGBA, make_float2(0,255),
(float4*)imgRGBA, make_float2(0,1),
imgWidth, imgHeight));
CUDA(cudaDeviceSynchronize());
cv::Mat cv_image(cv::Size(imgWidth, imgHeight), CV_32FC4, imgRGBA);
cv::Mat cv_image2(cv::Size(imgWidth, imgHeight), CV_8UC3);
cv::cvtColor(cv_image, cv_image2, cv::COLOR_RGBA2BGR);
cv::imshow("Display window", cv_image2);
cv::waitKey(0);
imini
July 10, 2020, 5:03pm
15
oh you helped me so hard that i was able to fix the error!
thanks a lot!!
No problem, glad you got it working!
