Hello!
I’m trying to get the can-app-rx-task
working on a Jetson TX2 SPE. However I’m unable to receive any messages. I created a function, ivc_log, to help provide debugging data through the IVC data channel between the SPE and the Linux host and this is showing me that all of the messages I send to the SPE are being received with cmdid = 0x05
which is corresponding to MTTCAN_BERR_CHG
Setup
I’ve attached a diagram of the setup I’m working with. On the Jetson side, I have a 120 Ω termination resistor across CAN H/L. Then, I have both CAN H/L connected to the PEAK PCAN-USB Adapter along with the GND from the Jeton. From there, the PEAK is plugged into a laptop running Ubuntu 20.04 with can-utils
installed.
Code
I started with the demo code that goes along with the guide found here. I made a few modifications to get it working with our system and what we’re looking to do with the SPE as follows:
can-app.c
- Enable CAN0 as TX and RX
- Comment out the section that checks to make sure a single CAN controller is not both TX and RX
- The demo code said that a single CAN controller can be used as both TX and RX
- ‘soc/t18x/targer_specific.mk`
- Set ENABLE_CAN_APP to 1
can-app-tx-task.c
- Comment out the
can_tx_event
task and thecan_process_txevent
function- I found this would interfere with can-app-rx-task
- Update
CAN_TEST_DELAY
to 100 - Add
vTaskDelay (CAN_TEST_DELAY*100)
before the infinite while loop that transmits the messages- This gives the Linux host some time to boot up. Without it, the Linux host would not boot after flashing the Jetson with the SPE firmware
- Remove all instances of
can_test_transmit
after the first one- I only want to send a normal CAN frame with an 11 bit identifier
- Add an
ivc_log
function that utilizes the data channel between the SPE and the Linux host to be able to print debug messages
- Comment out the
can-app-rx-task.c
- Add an
ivc_log
function that utilizes the data channel between the SPE and the Linux host to be able to print debug messages - Comment out all
printf
statements formcan_rx_test_print
- Replace them with
ivc_log ("CMD ID: 0x%02x, MSG ID: 0x%02x, Data Length: %d\r\n", cf->cmdid, msgid, dlen);
so I can seecmdid
,msgid
, anddlen
from the Linux host after a message is received
- Replace them with
- Comment out the if statement checking to only print messaged with a
cmdid
ofMTTCAN_MSG_RX
- I commented this out once I saw that I wasn’t seeing any of the messages sent to the Jetson being processed
- I figured that the messages weren’t passing this check and I was correct since they’re all being read as
MTTCAN_BERR_CHG
- Add an
On the laptop, I set up the PEAK as a CAN interface with a baud rate of 500Kbps to match the default setting on the Jetson. I’ve also tested this at 1Mpbs and received similar results. When changing the baud rate on the Jetson, I updated ttcan_set_bitrate(ttcan, NBITRATE_PRESCALAR_500K, DBITRATE_PRESCALAR_2M);
to ttcan_set_bitrate(ttcan, NBITRATE_PRESCALAR_1M, DBITRATE_PRESCALAR_2M);
in tegra-can.c
following a post that I saw here on the forums
Testing
For my initial test, I tried just TX by commenting out can_app_rx_task_init(CAN_RX_CONTROLLER);
in can-app.c
. From here, I was able to see the messages being sent from the SPE on my laptop by using candump
This showed that I was able to get TX from the SPE to work. So I then went to test RX. For this, I commented out can_app_tx_task_init(CAN_TX_CONTROLLER);
in can-app.c
. Once the SPE firmware was flashed to the Jetson, I sent messages from my laptop using the command cansend 0A5#12
Using the ivc_log
function, I checked the information the SPE was reading from the message:
- cmdid: 0x05
- msgid: 0x00
- Data Length: 20
I’ve had similar results using different messages as well, such as: cansend 0A5#AA55
,cansend 0A5#
, and cansend 000#12
From tegra-can.h
, I can see that a cmdid
of 0x05
corresponds to MTTCAN_MSG_BERR_CHG
. Upon further testing, I found that all RX messages on the SPE were being seen with this cmdid
. I believe this is corresponding to a bus error, but I’m not sure what could be causing this error.
I’ve also attached an image from my oscilloscope that is showing the CAN frame being sent from my laptop and not getting the ACK from the Jetson.
can setup.pdf (9.4 KB)
