Hi
I had ubuntu 20.04 installed on TX2 that i have to use in project and I decided to flash ubuntu 18.04. I have flashed the TX2 at least 15 times now (with SKDM and without it via ./flash.sh). I cannot access the TX2 via an HDMI connected monitor - nothing shows up. Whats more always when i power on TX2 two green lights are on like in recovery mode but it isn’t recovery mode. After flashing I can see device L4TREDME and info that connection failed.
On host I have ubuntu 18.04.6 LTS installed.
I often get this message when stuck on 99% of flashing in SDKM:
“Installation of ‘Flash Jetson TX2’ is taking longer than expected.
Do you want to continue installing this package?”
I think the board is not broken because it works a week ago.
So what I can do to install OS on my TX2?
[ 34.3742 ] Writing partition secondary_gpt with gpt_secondary_0_3.bin
[ 34.3747 ] […] 100%
[ 34.4241 ] Erasing sdmmc_user: 3 … [Done]
[ 35.8416 ] Writing partition master_boot_record with mbr_1_3.bin
[ 35.8421 ] […] 100%
[ 35.8462 ] Writing partition primary_gpt with gpt_primary_1_3.bin
[ 35.8477 ] […] 100%
[ 35.8521 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin
[ 35.8597 ] […] 100%
[ 35.8713 ] Writing partition mb1 with mb1_prod.bin.encrypt
[ 35.8717 ] […] 100%
[ 35.8785 ] Writing partition mb1_b with mb1_prod.bin.encrypt
[ 35.8995 ] […] 100%
[ 35.9063 ] Writing partition spe-fw with spe_sigheader.bin.encrypt
[ 35.9291 ] […] 100%
[ 35.9358 ] Writing partition spe-fw_b with spe_sigheader.bin.encrypt
[ 35.9704 ] […] 100%
[ 35.9773 ] Writing partition mb2 with nvtboot_sigheader.bin.encrypt
[ 36.0083 ] […] 100%
[ 36.0158 ] Writing partition mb2_b with nvtboot_sigheader.bin.encrypt
[ 36.0556 ] […] 100%
[ 36.0631 ] Writing partition mts-preboot with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 36.1075 ] […] 100%
[ 36.1138 ] Writing partition mts-preboot_b with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 36.1650 ] […] 100%
[ 36.1716 ] Writing partition SMD with slot_metadata.bin
[ 36.2265 ] […] 100%
[ 36.2498 ] Writing partition SMD_b with slot_metadata.bin
[ 36.2558 ] […] 100%
[ 36.2600 ] Writing partition VER_b with emmc_bootblob_ver.txt
[ 36.2624 ] […] 100%
[ 36.2785 ] Writing partition VER with emmc_bootblob_ver.txt
[ 36.3283 ] […] 100%
[ 36.3326 ] Writing partition master_boot_record with mbr_1_3.bin
[ 36.3361 ] […] 100%
[ 36.3400 ] Writing partition APP with system.img
[ 36.3415 ] […] 100%
[ 307.6252 ] Writing partition mts-bootpack with mce_mts_d15_prod_cr_sigheader.bin.encrypt
[ 307.6727 ] […] 100%
[ 307.7688 ] Writing partition mts-bootpack_b with mce_mts_d15_prod_cr_sigheader.bin.encrypt
[ 307.7737 ] […] 100%
[ 307.8692 ] Writing partition cpu-bootloader with cboot_sigheader.bin.encrypt
[ 307.8741 ] […] 100%
[ 307.8875 ] Writing partition cpu-bootloader_b with cboot_sigheader.bin.encrypt
[ 307.8932 ] […] 100%
[ 307.9075 ] Writing partition bootloader-dtb with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 307.9158 ] […] 100%
[ 307.9302 ] Writing partition bootloader-dtb_b with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 307.9371 ] […] 100%
[ 307.9524 ] Writing partition secure-os with tos-trusty_sigheader.img.encrypt
[ 307.9591 ] […] 100%
[ 307.9745 ] Writing partition secure-os_b with tos-trusty_sigheader.img.encrypt
[ 307.9822 ] […] 100%
[ 307.9981 ] Writing partition eks with eks_sigheader.img.encrypt
[ 308.0053 ] […] 100%
[ 308.0095 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt
[ 308.0115 ] […] 100%
[ 308.0180 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt
[ 308.0214 ] […] 100%
[ 308.0279 ] Writing partition bpmp-fw with bpmp_sigheader.bin.encrypt
[ 308.0314 ] […] 100%
[ 308.0500 ] Writing partition bpmp-fw_b with bpmp_sigheader.bin.encrypt
[ 308.0603 ] […] 100%
[ 308.0794 ] Writing partition bpmp-fw-dtb with tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt
[ 308.0893 ] […] 100%
[ 308.1103 ] Writing partition bpmp-fw-dtb_b with tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt
[ 308.1201 ] […] 100%
[ 308.1406 ] Writing partition sce-fw with camera-rtcpu-sce_sigheader.img.encrypt
[ 308.1502 ] […] 100%
[ 308.1582 ] Writing partition sce-fw_b with camera-rtcpu-sce_sigheader.img.encrypt
[ 308.1621 ] […] 100%
[ 308.1697 ] Writing partition sc7 with warmboot_wbheader.bin.encrypt
[ 308.1734 ] […] 100%
[ 308.1780 ] Writing partition sc7_b with warmboot_wbheader.bin.encrypt
[ 308.1804 ] […] 100%
[ 308.1852 ] Writing partition BMP with bmp.blob
[ 308.1890 ] […] 100%
[ 308.2132 ] Writing partition BMP_b with bmp.blob
[ 308.2171 ] […] 100%
[ 308.2253 ] Writing partition recovery with recovery_sigheader.img.encrypt
[ 308.2298 ] […] 100%
[ 310.2314 ] Writing partition recovery-dtb with tegra186-quill-p3310-1000-c03-00-base.dtb_sigheader.rec.encrypt
[ 310.2368 ] […] 100%
[ 310.2511 ] Writing partition kernel-bootctrl with kernel_bootctrl.bin
[ 310.2574 ] […] 100%
[ 310.2784 ] Writing partition kernel-bootctrl_b with kernel_bootctrl.bin
[ 310.2802 ] […] 100%
[ 310.2855 ] Writing partition kernel with boot_sigheader.img.encrypt
[ 310.2871 ] […] 100%
[ 310.3091 ] Writing partition kernel_b with boot_sigheader.img.encrypt
[ 310.3189 ] […] 100%
[ 310.3405 ] Writing partition kernel-dtb with kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 310.3522 ] […] 100%
[ 310.3664 ] Writing partition kernel-dtb_b with kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 310.3733 ] […] 100%
[ 310.3940 ]
[ 310.3962 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 310.3973 ] Bootloader version 01.00.0000
[ 310.3991 ] Writing partition BCT with br_bct_BR.bct
[ 310.3993 ] […] 100%
[ 310.4580 ]
[ 310.4617 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 310.4632 ] Bootloader version 01.00.0000
[ 310.4652 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 310.4659 ] […] 100%
[ 310.5325 ]
[ 310.5353 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 310.5364 ] Bootloader version 01.00.0000
[ 310.5381 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 310.5386 ] […] 100%
[ 310.5949 ]
[ 310.5950 ] Flashing completed
[ 310.5950 ] Coldbooting the device
[ 310.5978 ] tegradevflash_v2 --reboot coldboot
[ 310.5990 ] Bootloader version 01.00.0000
[ 310.6055 ]
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
Thanks Daniel
