I have a tx2 work well for long time,and this tx2 can’t start-up today when power on.There is no modification before system can’t start-up. Debug uart tell me “Bad Linux ARM64 Image magic!”,Could someone point me why the Image is bad suddenly?
Thank you.
Debug uart infodebug-uart.log (20.4 KB)
Are you sure you didn’t replace new kernel image to your tx2? Could you try to reflash your board?
If even re-flash cannot work, probably a hardware issue.
Hi, WayneWWW,
Do I have a way to dump or export the kernel Image in boot cmd environment?
Under current status, I guess no way. You could try to clone the APP partition from your board and put it into other board to use it.
