Hi, all:
It have “arb lost” error on tx2, the bus clear is not use. I want set the sda and scl to gpio pin and set the scl-gpio produce 9 clocks.
I found there are have tegra_i2c_gpio_xxx functions in the file “i2c-tegra.c”.
could you tell me how should I do to use the tegra_i2c_gpio_xxx correctly.
