Tx2 uart can't work at baud rate above 460800bps
In dts file, the serail port /dev/ttyTHS3 is configured as flow:
uartd: serial@3130000 {
compatible = “nvidia,tegra186-hsuart”;
#stream-id-cells = <1>;
reg = <0x0 0x03130000 0x0 0x40>;
reg-shift = <2>;
interrupts = <0 TEGRA186_IRQ_UARTD 0x04>;
nvidia,memory-clients = <14>;
dmas = <&gpcdma 19>, <&gpcdma 19>;
dma-names = “rx”, “tx”;
clocks = <&tegra_car TEGRA186_CLK_UARTD>,
<&tegra_car TEGRA186_CLK_PLLP_OUT0>;
clock-names = “serial”, “parent”;
resets = <&tegra_car TEGRA186_RESET_UARTD>;
reset-names = “serial”;
status = “disabled”;
nvidia,adjust-baud-rates = <115200 115200 100>;
when I use picocom to read from the port, there is one error message from dmesg:
[26046.949265] serial-tegra 3130000.serial: configured rate out of supported range by -0.29 %
and the data read is also wrong
the command used to read is : picocom -b 460800 /dev/ttyTHS3
after reading kenel source, this may be caused by this config nvidia,adjust-baud-rates = <115200 115200 100>
Does anyone know how to ajust the configuration, so 460800 and higher baudrate can be used?
The clock is not within tolerance above 115200. If you use two stop bits though it should start working.
I will try this, thanks for your reply
