the line
dtc -I dts -o /boot/modified_tegra186-quill-p3310-1000-c03-00-base.dtb extracted.dts
has an argument -I which you did set to dts
it means that you are using inputr file format there of source type
-I, --in-format <arg>
Input formats are:
dts - device tree source text
dtb - device tree blob
fs - /proc/device-tree style directory
than you say to create dtb file from extracted.dts there.
However the phrase "I created modified_tegra186-quill-p3310-1000-c03-00-base.dtb extracted.dts file "
has two files mentioned"
As I understand you should have created the extracted.dts file first from the existing dtb file and than edit it and than create the dtb from the edited dts file.
How did you create extracted.dts file?
In my case it returns:
root@tegra-ubuntu:/tmp# dtc -I dtb -o dts extracted.dts /boot/tegra186-quill-p3310-1000-c03-00-base.dtb
Usage: dtc [options] <input file>
Options: -[qI:O:o:V:d:R:S:p:fb:i:H:sW:E:hv]
-q, --quiet
Quiet: -q suppress warnings, -qq errors, -qqq all
Input formats are:
-o, --out <arg>
Output file
-O, --out-format <arg>
Output formats are:
asm - assembler source
-V, --out-version <arg>
Blob version to produce, defaults to %d (for dtb and asm output)
-d, --out-dependency <arg>
Output dependency file
-R, --reserve <arg>
tMake space for <number> reserve map entries (for dtb and asm output)
-S, --space <arg>
Make the blob at least <bytes> long (extra space)
-p, --pad <arg>
Add padding to the blob of <bytes> long (extra space)
-b, --boot-cpu <arg>
Set the physical boot cpu
-f, --force
Try to produce output even if the input tree has errors
-i, --include <arg>
Add a path to search for include files
-s, --sort
Sort nodes and properties before outputting (useful for comparing trees)
-H, --phandle <arg>
Valid phandle formats are:
legacy - "linux,phandle" properties only
epapr - "phandle" properties only
both - Both "linux,phandle" and "phandle" properties
-W, --warning <arg>
Enable/disable warnings (prefix with "no-")
-E, --error <arg>
Enable/disable errors (prefix with "no-")
-h, --help
Print this help and exit
-v, --version
Print version and exit
Error: missing files
