TX2 uboot usb dfu support
hi,guys. for some reason, we have to modify the ubooot to support DFU or fastboot.
and the branch of uboot source code is :
sources/u-boot$ git branch
  • l4t/l4t-r28.3
and we make like this:
step1:
sources/u-boot$ make p2771-0000-500_defconfig
configuration written to .config
step2:
make menuconfig to set usb drive and dfu support
then:
the .config file like this:
Automatically generated file; DO NOT EDIT.
U-Boot 2016.07 Configuration
CONFIG_CREATE_ARCH_SYMLINK=y
CONFIG_ARC is not set
CONFIG_ARM=y
CONFIG_AVR32 is not set
CONFIG_BLACKFIN is not set
CONFIG_M68K is not set
CONFIG_MICROBLAZE is not set
CONFIG_MIPS is not set
CONFIG_NDS32 is not set
CONFIG_NIOS2 is not set
CONFIG_OPENRISC is not set
CONFIG_PPC is not set
CONFIG_SANDBOX is not set
CONFIG_SH is not set
CONFIG_SPARC is not set
CONFIG_X86 is not set
CONFIG_SYS_ARCH=“arm”
CONFIG_SYS_CPU=“armv8”
CONFIG_SYS_SOC=“tegra186”
CONFIG_SYS_VENDOR=“nvidia”
CONFIG_SYS_BOARD=“p2771-0000”
CONFIG_SYS_CONFIG_NAME=“p2771-0000”
ARM architecture
CONFIG_ARM64=y
CONFIG_DMA_ADDR_T_64BIT=y
CONFIG_SYS_ARM_ARCH=8
CONFIG_SEMIHOSTING is not set
CONFIG_SYS_L2CACHE_OFF is not set
CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set
CONFIG_ARCH_AT91 is not set
CONFIG_TARGET_EDB93XX is not set
CONFIG_TARGET_VCMA9 is not set
CONFIG_TARGET_SMDK2410 is not set
CONFIG_TARGET_ASPENITE is not set
CONFIG_TARGET_GPLUGD is not set
CONFIG_ARCH_DAVINCI is not set
CONFIG_KIRKWOOD is not set
CONFIG_ARCH_MVEBU is not set
CONFIG_TARGET_DEVKIT3250 is not set
CONFIG_TARGET_WORK_92105 is not set
CONFIG_TARGET_MX25PDK is not set
CONFIG_TARGET_ZMX25 is not set
CONFIG_TARGET_APF27 is not set
CONFIG_TARGET_APX4DEVKIT is not set
CONFIG_TARGET_XFI3 is not set
CONFIG_TARGET_M28EVK is not set
CONFIG_TARGET_MX23EVK is not set
CONFIG_TARGET_MX28EVK is not set
CONFIG_TARGET_MX23_OLINUXINO is not set
CONFIG_TARGET_BG0900 is not set
CONFIG_TARGET_SANSA_FUZE_PLUS is not set
CONFIG_TARGET_SC_SPS_1 is not set
CONFIG_ORION5X is not set
CONFIG_TARGET_SPEAR300 is not set
CONFIG_TARGET_SPEAR310 is not set
CONFIG_TARGET_SPEAR320 is not set
CONFIG_TARGET_SPEAR600 is not set
CONFIG_TARGET_STV0991 is not set
CONFIG_TARGET_X600 is not set
CONFIG_TARGET_IMX31_PHYCORE is not set
CONFIG_TARGET_MX31ADS is not set
CONFIG_TARGET_MX31PDK is not set
CONFIG_TARGET_WOODBURN is not set
CONFIG_TARGET_WOODBURN_SD is not set
CONFIG_TARGET_FLEA3 is not set
CONFIG_TARGET_MX35PDK is not set
CONFIG_ARCH_BCM283X is not set
CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set
CONFIG_TARGET_VEXPRESS_CA5X2 is not set
CONFIG_TARGET_VEXPRESS_CA9X4 is not set
CONFIG_TARGET_BRXRE1 is not set
CONFIG_TARGET_BRPPT1 is not set
CONFIG_TARGET_CM_T335 is not set
CONFIG_TARGET_PEPPER is not set
CONFIG_TARGET_AM335X_IGEP0033 is not set
CONFIG_TARGET_PCM051 is not set
CONFIG_TARGET_DRACO is not set
CONFIG_TARGET_THUBAN is not set
CONFIG_TARGET_RASTABAN is not set
CONFIG_TARGET_ETAMIN is not set
CONFIG_TARGET_PXM2 is not set
CONFIG_TARGET_RUT is not set
CONFIG_TARGET_PENGWYN is not set
CONFIG_TARGET_AM335X_BALTOS is not set
CONFIG_TARGET_AM335X_EVM is not set
CONFIG_TARGET_AM335X_SHC is not set
CONFIG_TARGET_AM335X_SL50 is not set
CONFIG_TARGET_BAV335X is not set
CONFIG_TARGET_TI814X_EVM is not set
CONFIG_TARGET_TI816X_EVM is not set
CONFIG_TARGET_BCM23550_W1D is not set
CONFIG_TARGET_BCM28155_AP is not set
CONFIG_TARGET_BCMCYGNUS is not set
CONFIG_TARGET_BCMNSP is not set
CONFIG_ARCH_EXYNOS is not set
CONFIG_ARCH_S5PC1XX is not set
CONFIG_ARCH_HIGHBANK is not set
CONFIG_ARCH_INTEGRATOR is not set
CONFIG_ARCH_KEYSTONE is not set
CONFIG_ARCH_MESON is not set
CONFIG_ARCH_MX7 is not set
CONFIG_ARCH_MX6 is not set
CONFIG_ARCH_MX5 is not set
CONFIG_TARGET_M53EVK is not set
CONFIG_TARGET_MX51EVK is not set
CONFIG_TARGET_MX53ARD is not set
CONFIG_TARGET_MX53EVK is not set
CONFIG_TARGET_MX53LOCO is not set
CONFIG_TARGET_MX53SMD is not set
CONFIG_OMAP34XX is not set
CONFIG_OMAP44XX is not set
CONFIG_OMAP54XX is not set
CONFIG_AM43XX is not set
CONFIG_RMOBILE is not set
CONFIG_TARGET_S32V234EVB is not set
CONFIG_ARCH_SNAPDRAGON is not set
CONFIG_ARCH_SOCFPGA is not set
CONFIG_TARGET_CM_T43 is not set
CONFIG_ARCH_SUNXI is not set
CONFIG_TARGET_TS4800 is not set
CONFIG_TARGET_VF610TWR is not set
CONFIG_TARGET_COLIBRI_VF is not set
CONFIG_TARGET_PCM052 is not set
CONFIG_ARCH_ZYNQ is not set
CONFIG_ARCH_ZYNQMP is not set
CONFIG_TEGRA=y
CONFIG_TARGET_VEXPRESS64_AEMV8A is not set
CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set
CONFIG_TARGET_VEXPRESS64_BASE_FVP_DRAM is not set
CONFIG_TARGET_VEXPRESS64_JUNO is not set
CONFIG_TARGET_LS2080A_EMU is not set
CONFIG_TARGET_LS2080A_SIMU is not set
CONFIG_TARGET_LS2080AQDS is not set
CONFIG_TARGET_LS2080ARDB is not set
CONFIG_TARGET_HIKEY is not set
CONFIG_TARGET_LS1012AQDS is not set
CONFIG_TARGET_LS1012ARDB is not set
CONFIG_TARGET_LS1012AFRDM is not set
CONFIG_TARGET_LS1021AQDS is not set
CONFIG_TARGET_LS1021ATWR is not set
CONFIG_TARGET_LS1043AQDS is not set
CONFIG_TARGET_LS1043ARDB is not set
CONFIG_TARGET_H2200 is not set
CONFIG_TARGET_ZIPITZ2 is not set
CONFIG_TARGET_COLIBRI_PXA270 is not set
CONFIG_ARCH_UNIPHIER is not set
CONFIG_STM32 is not set
CONFIG_ARCH_ROCKCHIP is not set
CONFIG_TARGET_THUNDERX_88XX is not set
CONFIG_SYS_MALLOC_F_LEN=0x1800
CONFIG_SYS_MALLOC_F=y
CONFIG_DM_SERIAL=y
CONFIG_DM_SPI=y
CONFIG_DM_SPI_FLASH=y
CONFIG_DM_I2C=y
CONFIG_DM_GPIO=y
CONFIG_BLK is not set
CONFIG_TEGRA_IVC=y
CONFIG_TEGRA_COMMON=y
CONFIG_TEGRA_ARMV7_COMMON is not set
CONFIG_TEGRA_ARMV8_COMMON=y
CONFIG_TEGRA20 is not set
CONFIG_TEGRA30 is not set
CONFIG_TEGRA114 is not set
CONFIG_TEGRA124 is not set
CONFIG_TEGRA210 is not set
CONFIG_TEGRA186=y
CONFIG_TEGRA_DISCONNECT_UDC_ON_BOOT=y
CONFIG_TARGET_P2771_0000=y
CONFIG_ARMV8_MULTIENTRY is not set
ARM debug
CONFIG_DM_KEYBOARD=y
CONFIG_DEFAULT_DEVICE_TREE=“tegra186-p2771-0000-500”
CONFIG_AHCI is not set
CONFIG_I8042_KEYB is not set
General setup
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_DISTRO_DEFAULTS is not set
CONFIG_EXPERT=y
CONFIG_SYS_MALLOC_CLEAR_ON_INIT=y
Boot images
CONFIG_FIT=y
CONFIG_FIT_VERBOSE is not set
CONFIG_FIT_SIGNATURE is not set
CONFIG_FIT_BEST_MATCH is not set
CONFIG_OF_BOARD_SETUP is not set
CONFIG_OF_SYSTEM_SETUP=y
CONFIG_OF_STDOUT_VIA_ALIAS is not set
CONFIG_SYS_EXTRA_OPTIONS=""
CONFIG_SPL_LOAD_FIT is not set
Boot timing
CONFIG_BOOTSTAGE is not set
CONFIG_BOOTSTAGE_USER_COUNT=20
CONFIG_BOOTSTAGE_STASH_ADDR=0
CONFIG_BOOTSTAGE_STASH_SIZE=4096
Boot media
CONFIG_NAND_BOOT is not set
CONFIG_ONENAND_BOOT is not set
CONFIG_QSPI_BOOT is not set
CONFIG_SATA_BOOT is not set
CONFIG_SD_BOOT is not set
CONFIG_SPI_BOOT is not set
CONFIG_BOOTDELAY=2
CONFIG_CONSOLE_RECORD is not set
Command line interface
CONFIG_CMDLINE=y
CONFIG_HUSH_PARSER=y
CONFIG_SYS_PROMPT="Tegra186 (P2771-0000-500) # "
Autoboot options
CONFIG_AUTOBOOT=y
CONFIG_AUTOBOOT_KEYED is not set
Commands
Info commands
CONFIG_CMD_BDI=y
CONFIG_CMD_CONSOLE=y
CONFIG_CMD_CPU is not set
CONFIG_CMD_LICENSE is not set
Boot commands
CONFIG_CMD_BOOTD=y
CONFIG_CMD_BOOTM=y
CONFIG_CMD_BOOTZ is not set
CONFIG_CMD_BOOTEFI=y
CONFIG_CMD_ELF=y
CONFIG_CMD_FDT=y
CONFIG_CMD_GO=y
CONFIG_CMD_RUN=y
CONFIG_CMD_IMI is not set
CONFIG_CMD_IMLS is not set
CONFIG_CMD_XIMG=y
Environment commands
CONFIG_CMD_ASKENV is not set
CONFIG_CMD_EXPORTENV=y
CONFIG_CMD_IMPORTENV=y
CONFIG_CMD_EDITENV=y
CONFIG_CMD_GREPENV is not set
CONFIG_CMD_SAVEENV=y
CONFIG_CMD_ENV_EXISTS=y
Memory commands
CONFIG_CMD_MEMORY=y
CONFIG_CMD_CRC32=y
CONFIG_LOOPW is not set
CONFIG_CMD_MEMTEST is not set
CONFIG_CMD_MX_CYCLIC is not set
CONFIG_CMD_MEMINFO is not set
Device access commands
CONFIG_CMD_DM=y
CONFIG_CMD_DEMO is not set
CONFIG_CMD_LOADB=y
CONFIG_CMD_LOADS=y
CONFIG_CMD_FLASH is not set
CONFIG_CMD_ARMFLASH is not set
CONFIG_CMD_MMC=y
CONFIG_CMD_NAND is not set
CONFIG_CMD_SF=y
CONFIG_CMD_SPI=y
CONFIG_CMD_I2C=y
CONFIG_CMD_USB=y
CONFIG_CMD_DFU=y
CONFIG_CMD_USB_MASS_STORAGE is not set
CONFIG_CMD_FPGA is not set
CONFIG_CMD_GPIO=y
Shell scripting commands
CONFIG_CMD_ECHO=y
CONFIG_CMD_ITEST=y
CONFIG_CMD_SOURCE=y
CONFIG_CMD_SETEXPR is not set
Network commands
CONFIG_CMD_NET=y
CONFIG_CMD_TFTPPUT is not set
CONFIG_CMD_TFTPSRV is not set
CONFIG_CMD_RARP is not set
CONFIG_CMD_DHCP=y
CONFIG_CMD_NFS is not set
CONFIG_CMD_MII=y
CONFIG_CMD_PING=y
CONFIG_CMD_CDP is not set
CONFIG_CMD_SNTP is not set
CONFIG_CMD_DNS is not set
CONFIG_CMD_LINK_LOCAL is not set
Misc commands
CONFIG_CMD_CACHE is not set
CONFIG_CMD_TIME is not set
CONFIG_CMD_MISC=y
CONFIG_CMD_TIMER is not set
CONFIG_CMD_QFW is not set
Power commands
Security commands
Filesystem commands
CONFIG_CMD_EXT2=y
CONFIG_CMD_EXT4=y
CONFIG_CMD_EXT4_WRITE=y
CONFIG_CMD_FAT=y
CONFIG_CMD_FS_GENERIC=y
CONFIG_SUPPORT_OF_CONTROL=y
Device Tree Control
CONFIG_OF_CONTROL=y
CONFIG_OF_SEPARATE=y
CONFIG_OF_EMBED is not set
CONFIG_NET=y
CONFIG_NET_RANDOM_ETHADDR is not set
CONFIG_NETCONSOLE is not set
CONFIG_NET_TFTP_VARS=y
CONFIG_BOOTP_PXE_CLIENTARCH=0x16
CONFIG_BOOTP_VCI_STRING=“U-Boot.armv8”
Device Drivers
Generic Driver Options
CONFIG_DM=y
CONFIG_DM_WARN=y
CONFIG_DM_DEVICE_REMOVE=y
CONFIG_DM_STDIO=y
CONFIG_DM_SEQ_ALIAS=y
CONFIG_SPL_DM_SEQ_ALIAS is not set
CONFIG_REGMAP is not set
CONFIG_SPL_REGMAP is not set
CONFIG_DEVRES is not set
CONFIG_SIMPLE_BUS=y
CONFIG_OF_TRANSLATE=y
CONFIG_ADC is not set
CONFIG_ADC_EXYNOS is not set
CONFIG_ADC_SANDBOX is not set
CONFIG_BLOCK_CACHE is not set
Clock
CONFIG_CLK=y
CONFIG_SPL_CLK is not set
CONFIG_TEGRA186_CLOCK=y
CONFIG_CPU is not set
Hardware crypto devices
CONFIG_FSL_CAAM is not set
Demo for driver model
CONFIG_DM_DEMO is not set
DFU support
CONFIG_DFU_TFTP=y
DMA Support
CONFIG_DMA is not set
CONFIG_TI_EDMA3 is not set
GPIO Support
CONFIG_ALTERA_PIO is not set
CONFIG_DWAPB_GPIO is not set
CONFIG_ATMEL_PIO4 is not set
CONFIG_INTEL_BROADWELL_GPIO is not set
CONFIG_LPC32XX_GPIO is not set
CONFIG_MSM_GPIO is not set
CONFIG_ROCKCHIP_GPIO is not set
CONFIG_TEGRA_GPIO is not set
CONFIG_TEGRA186_GPIO=y
CONFIG_VYBRID_GPIO is not set
CONFIG_DM_74X164 is not set
CONFIG_DM_PCA953X is not set
CONFIG_MPC85XX_GPIO is not set
I2C support
CONFIG_DM_I2C_COMPAT is not set
CONFIG_DM_I2C_GPIO is not set
CONFIG_SYS_I2C_FSL is not set
CONFIG_SYS_I2C_CADENCE is not set
CONFIG_SYS_I2C_DW is not set
CONFIG_SYS_I2C_INTEL is not set
CONFIG_SYS_I2C_ROCKCHIP is not set
CONFIG_TEGRA186_BPMP_I2C=y
CONFIG_I2C_MUX is not set
CONFIG_CROS_EC_KEYB is not set
LED Support
CONFIG_LED is not set
Mailbox Controller Support
CONFIG_DM_MAILBOX=y
CONFIG_TEGRA_HSP=y
Memory Controller drivers
Multifunction device drivers
CONFIG_MISC=y
CONFIG_ALTERA_SYSID is not set
CONFIG_CROS_EC is not set
CONFIG_FSL_SEC_MON is not set
CONFIG_MXC_OCOTP is not set
CONFIG_PWRSEQ is not set
CONFIG_PCA9551_LED is not set
CONFIG_SYSRESET is not set
CONFIG_TEGRA186_BPMP=y
CONFIG_WINBOND_W83627 is not set
MMC Host controller Support
CONFIG_DM_MMC is not set
MTD Support
CONFIG_MTD is not set
NAND Device Support
CONFIG_NAND_DENALI is not set
CONFIG_NAND_VF610_NFC is not set
CONFIG_NAND_PXA3XX is not set
CONFIG_NAND_ARASAN is not set
Generic NAND options
SPI Flash Support
CONFIG_SPI_FLASH is not set
CONFIG_DM_ETH=y
CONFIG_PHYLIB=y
CONFIG_RTL8211X_PHY_FORCE_MASTER is not set
CONFIG_NETDEVICES=y
CONFIG_ALTERA_TSE is not set
CONFIG_DWC_ETH_QOS=y
CONFIG_E1000=y
CONFIG_E1000_SPI_GENERIC is not set
CONFIG_E1000_SPI is not set
CONFIG_CMD_E1000 is not set
CONFIG_ETH_DESIGNWARE is not set
CONFIG_PCH_GBE is not set
CONFIG_RTL8139 is not set
CONFIG_RTL8169=y
PCI
CONFIG_DM_PCI=y
CONFIG_DM_PCI_COMPAT=y
CONFIG_PCI_TEGRA=y
Pin controllers
CONFIG_PINCTRL is not set
Power
Power Domain Support
CONFIG_POWER_DOMAIN=y
CONFIG_TEGRA186_POWER_DOMAIN=y
CONFIG_DM_PMIC is not set
CONFIG_DM_REGULATOR is not set
CONFIG_DM_PWM=y
CONFIG_PWM_EXYNOS is not set
CONFIG_PWM_ROCKCHIP is not set
CONFIG_PWM_TEGRA is not set
CONFIG_RAM is not set
Remote Processor drivers
Reset Controller Support
CONFIG_DM_RESET=y
CONFIG_TEGRA186_RESET=y
Real Time Clock
CONFIG_DM_RTC is not set
Serial drivers
CONFIG_REQUIRE_SERIAL_CONSOLE=y
CONFIG_SERIAL_PRESENT=y
CONFIG_SPL_SERIAL_PRESENT=y
CONFIG_DEBUG_UART is not set
CONFIG_DEBUG_UART_SKIP_INIT is not set
CONFIG_ALTERA_JTAG_UART is not set
CONFIG_ALTERA_UART is not set
CONFIG_FSL_LPUART is not set
CONFIG_SYS_NS16550=y
CONFIG_MSM_SERIAL is not set
Sound support
CONFIG_SOUND is not set
SPI Support
CONFIG_ALTERA_SPI is not set
CONFIG_CADENCE_QSPI is not set
CONFIG_DESIGNWARE_SPI is not set
CONFIG_EXYNOS_SPI is not set
CONFIG_FSL_DSPI is not set
CONFIG_FSL_QSPI is not set
CONFIG_ICH_SPI is not set
CONFIG_ROCKCHIP_SPI is not set
CONFIG_TEGRA114_SPI is not set
CONFIG_TEGRA20_SFLASH is not set
CONFIG_TEGRA20_SLINK is not set
CONFIG_TEGRA210_QSPI is not set
CONFIG_XILINX_SPI is not set
CONFIG_OMAP3_SPI is not set
CONFIG_FSL_ESPI is not set
CONFIG_TI_QSPI is not set
SPMI support
CONFIG_SPMI is not set
CONFIG_DM_THERMAL is not set
Timer Support
CONFIG_TIMER is not set
TPM support
CONFIG_USB=y
CONFIG_DM_USB=y
USB Host Controller Drivers
CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_OHCI_GENERIC is not set
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI=y
CONFIG_USB_EHCI_MSM is not set
CONFIG_USB_EHCI_GENERIC=y
CONFIG_USB_DWC3 is not set
MUSB Controller Driver
CONFIG_USB_MUSB_HOST is not set
CONFIG_USB_MUSB_GADGET is not set
ULPI drivers
USB peripherals
CONFIG_USB_STORAGE is not set
CONFIG_USB_KEYBOARD is not set
CONFIG_USB_GADGET=y
CONFIG_USB_GADGET_ATMEL_USBA is not set
CONFIG_USB_GADGET_DWC2_OTG is not set
CONFIG_CI_UDC=y
CONFIG_USB_GADGET_VBUS_DRAW=100
CONFIG_USB_GADGET_DUALSPEED=y
CONFIG_USB_GADGET_DOWNLOAD=y
CONFIG_G_DNL_MANUFACTURER=“SRP1”
CONFIG_G_DNL_VENDOR_NUM=0x1
CONFIG_G_DNL_PRODUCT_NUM=0x1
Graphics support
CONFIG_DM_VIDEO is not set
TrueType Fonts
CONFIG_VIDEO_VESA is not set
CONFIG_VIDEO_LCD_ANX9804 is not set
CONFIG_VIDEO_LCD_SSD2828 is not set
CONFIG_VIDEO_MVEBU is not set
CONFIG_I2C_EDID is not set
CONFIG_DISPLAY is not set
CONFIG_VIDEO_TEGRA20 is not set
CONFIG_VIDEO_BRIDGE is not set
CONFIG_PHYS_TO_BUS is not set
File systems
Library routines
CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set
CONFIG_SYS_HZ=1000
CONFIG_USE_TINY_PRINTF is not set
CONFIG_REGEX=y
CONFIG_LIB_RAND is not set
CONFIG_CMD_DHRYSTONE is not set
CONFIG_RSA is not set
CONFIG_TPM is not set
Hashing Support
CONFIG_SHA1 is not set
CONFIG_SHA256 is not set
CONFIG_SHA_HW_ACCEL is not set
Compression Support
CONFIG_LZ4 is not set
CONFIG_ERRNO_STR is not set
CONFIG_OF_LIBFDT=y
CONFIG_SPL_OF_LIBFDT is not set
CONFIG_EFI_LOADER=y
CONFIG_EFI_LOADER_BOUNCE_BUFFER is not set
CONFIG_UNIT_TEST is not set
step3:
we make and flash the new uboot into tx2
step4:
we power on the tx2 and go into the uboot terminal lik this:
U-Boot 2016.07-g73d8ed8-dirty (Mar 17 2020 - 19:57:44 +0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 2 \0x08\0x08\0x08 0
step5:
we used usb cmd to start usb, we got this:
Tegra186 (P2771-0000-500) # usb start
starting USB…
No controllers found
step6:
Tegra186 (P2771-0000-500) # setenv dfu_alt_info 0 ext4 0 0
Tegra186 (P2771-0000-500) # dfu 0 mmc 0
g_dnl_register: failed!, error: -19
“Synchronous Abort” handler, esr 0x96000004
ELR: eff624c0
LR: eff3c44c
x0 : e59ff018e59ff018 x1 : 0000000003100014
x2 : 0000000003100000 x3 : 0000000003100000
x4 : 0000000000000000 x5 : 0000000000000001
x6 : 0000000000000000 x7 : 000000000000000a
x8 : 0000000000000000 x9 : 0000000000000008
x10: 00000000eda27654 x11: 0000000000000002
x12: 00000000ffffffff x13: 00000000ffffffff
x14: 00000000eda2815c x15: 00000000eda28220
x16: 0000000000000000 x17: 0000000000000000
x18: 00000000eda2ade0 x19: 0000000000000000
x20: 0000000000000000 x21: 0000000000000000
x22: 00000000effbc000 x23: 0000000000000000
x24: 0000000000000004 x25: 0000000000002710
x26: 0000000000000000 x27: 0000000000000000
x28: 00000000eda38460 x29: 00000000eda27f20
Resetting CPU …
resetting …
[0000.267] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-
step7:
I have compared the defconfig file and between TX1 and TX2, I found that: TX1 support the usb, and I try in a TX1,and the cmd usb start work.
I need you help,please!
TX2 uboot does not support usb for long time. It is due to the fw is not able to get loaded in uboot.
thanks,
and there any possible way to update the rootfs without ubuntu ?
can I use dfu tftp to update the kernel and rootfs?
or can I use 2 partition to do that?
one for normal app(A system) and one for update/recovery(B system).
when I need to update, I boot the B system and update or recovery to modify the rootfs of A system?
or any other suggestion about that?
thank you so much
