yes,Is my closing method right?
I don’t think that is necessary.
Could you just enable/disable pcie@3,0 and see if usb3-0 can work? No need to fully disable the pcie-controller@10003000.
When enable or disable pcie@3 , 0, usb3-0 can work
Do you mean usb3-0 can only work after you disabling pcie@3,0? Or something else?
Sorry that I feel all your comments cannot directly give a clear description.
Usb3-0 can work in both States
ok, then nothing to do with the PCIe.
Please share things like how we share the schematic…
https://developer.nvidia.com/embedded/downloads#?search=Board%20Design%20Files
I just want to double confirm. When you filed this topic:
Is this using the same custom board as current issue?
yes, it’s the same custom
But usb3-1 was able to work on that board at that time?
Yes, it worked last time
Can you put your current dts to that board and see if it can work?
It’s still a hardware problem. I won’t mention this problem again. I’m very sorry for wasting your time
Could you share what hardware side has problem to cause this issue?
