hi WayneWWW
After I burned in DTB in the NVIDIA public version, WIFI/BT is still not displayed.
tx2ai@ubuntu:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (root@faa54e61216b) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #2 SMP PREEMPT Fri Jul 31 03:28:05 UTC 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@9607d000
[ 0.000000] Found lut_mem2: 00002008@9607a000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2053117
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 521725 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1f676a000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2020917
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607d000 lut_mem2=0x2008@0x9607a000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29520(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7960756K/8212468K available (15230K kernel code, 2926K rwdata, 6660K rodata, 8576K init, 609K bss, 186176K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095f0000 ( 6720 KB)
[ 0.000000] .init : 0xffffff80095f0000 - 0xffffff8009e50000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e50000 - 0xffffff800a12b808 ( 2927 KB)
[ 0.000000] .bss : 0xffffff800a12b808 - 0xffffff800a1c3dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001567] Console: colour dummy device 80x25
[ 0.001573] console [tty0] enabled
[ 0.001576] bootconsole [uart8250] disabled
[ 0.001583] kmemleak: Kernel memory leak detector disabled
[ 0.001593] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001600] pid_max: default: 32768 minimum: 301
[ 0.001909] Security Framework initialized
[ 0.002065] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002069] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002654] ftrace: allocating 47001 entries in 184 pages
[ 0.125865] sched-energy: Sched-energy-costs installed from DT
[ 0.125876] ASID allocator initialised with 65536 entries
[ 0.163923] tegra-id: chipid=21817.
[ 0.163929] tegra-id: opt_subrevision=1.
[ 0.163946] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.163954] DTS File Name: /root/mic-720ai/bsp/tx2_jetpack-4.3/build/source/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.163960] DTB Build time: Jul 31 2020 11:28:48
[ 0.209649] CPU1: Booted secondary processor [4e0f0030]
[ 0.241289] CPU2: Booted secondary processor [4e0f0030]
[ 0.273084] CPU3: Booted secondary processor [411fd073]
[ 0.305071] CPU4: Booted secondary processor [411fd073]
[ 0.337059] CPU5: Booted secondary processor [411fd073]
[ 0.337112] Brought up 6 CPUs
[ 0.337115] SMP: Total of 6 processors activated.
[ 0.337120] CPU features: detected feature: 32-bit EL0 Support
[ 0.337851] CPU: All CPU(s) started at EL2
[ 0.337904] alternatives: patching kernel code
[ 0.347235] devtmpfs: initialized
[ 0.385578] Initilizing CustomIPI irq domain
[ 0.385802] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.385812] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.386599] pinctrl core: initialized pinctrl subsystem
[ 0.386792] OS set in device tree is not L4T.
[ 0.386957] regulator-dummy: no parameters
[ 0.387093] Initializing plugin-manager
[ 0.387146] Plugin module not found
[ 0.387183] Plugin-manager status disabled
[ 0.389017] NET: Registered protocol family 16
[ 0.389682] pstore: using zlib compression
[ 0.389695] console [pstore-1] enabled
[ 0.389698] pstore: Registered ramoops as persistent store backend
[ 0.389702] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.408683] cpuidle: using governor menu
[ 0.410146] bpmp: waiting for handshake
[ 0.410150] bpmp: handshake completed
[ 0.410163] bpmp: synchronizing channels
[ 0.410180] bpmp: channels synchronized
[ 0.410183] bpmp: mail init ok
[ 0.412250] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.412254] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.412258] arm-smmu 12000000.iommu: stage 1 translation
[ 0.412261] arm-smmu 12000000.iommu: stage 2 translation
[ 0.412264] arm-smmu 12000000.iommu: nested translation
[ 0.412270] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.412275] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.412279] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.412284] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.412287] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.414379] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e54000)
[ 0.414391] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.416852] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.418701] Registering BPMP clocks...
[ 0.418795] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.421017] tegra_powergate_init: DONE
[ 0.421024] DTS File Name: /root/mic-720ai/bsp/tx2_jetpack-4.3/build/source/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.421030] DTB Build time: Jul 31 2020 11:28:48
[ 0.423100] Tegra reboot handler registered.
[ 0.424537] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.424600] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.424614] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.424616] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.424619] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.424811] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.424821] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.425155] iommu: Adding device 3460000.sdhci to group 0
[ 0.425832] iommu: Adding device 3400000.sdhci to group 1
[ 0.426878] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.426889] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.427328] iommu: Adding device 3160000.i2c to group 3
[ 0.427765] iommu: Adding device c240000.i2c to group 4
[ 0.428105] iommu: Adding device 3180000.i2c to group 5
[ 0.428435] iommu: Adding device 3190000.i2c to group 6
[ 0.428887] iommu: Adding device 31b0000.i2c to group 7
[ 0.429221] iommu: Adding device 31c0000.i2c to group 8
[ 0.429552] iommu: Adding device c250000.i2c to group 9
[ 0.429884] iommu: Adding device 31e0000.i2c to group 10
[ 0.431368] iommu: Adding device 3210000.spi to group 11
[ 0.431707] iommu: Adding device c260000.spi to group 12
[ 0.432048] iommu: Adding device 3240000.spi to group 13
[ 0.432792] iommu: Adding device 3100000.serial to group 14
[ 0.433148] iommu: Adding device 3110000.serial to group 15
[ 0.433483] iommu: Adding device c280000.serial to group 16
[ 0.433822] iommu: Adding device 3130000.serial to group 17
[ 0.435205] iommu: Adding device 2490000.ether_qos to group 18
[ 0.435218] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.435898] iommu: Adding device b000000.rtcpu to group 19
[ 0.438202] iommu: Adding device 13e10000.host1x to group 20
[ 0.438523] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.438825] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.439136] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.439444] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.439743] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.440049] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.440361] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.440692] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.441167] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.441824] iommu: Adding device 15700000.vi to group 30
[ 0.442186] iommu: Adding device 15600000.isp to group 31
[ 0.442653] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.442762] platform 15210000.nvdisplay: OF IOVA linear map 0x9607d000 size (0x800000)
[ 0.442797] platform 15210000.nvdisplay: OF IOVA linear map 0x9607a000 size (0x2008)
[ 0.443312] iommu: Adding device 15340000.vic to group 33
[ 0.443534] iommu: Adding device 154c0000.nvenc to group 34
[ 0.443750] iommu: Adding device 15480000.nvdec to group 35
[ 0.444102] iommu: Adding device 15380000.nvjpg to group 36
[ 0.444329] iommu: Adding device 15500000.tsec to group 37
[ 0.444544] iommu: Adding device 15100000.tsecb to group 38
[ 0.445273] iommu: Adding device 15810000.se to group 39
[ 0.445501] iommu: Adding device 15820000.se to group 40
[ 0.445715] iommu: Adding device 15830000.se to group 41
[ 0.445928] iommu: Adding device 15840000.se to group 42
[ 0.446814] iommu: Adding device smmu_test to group 43
[ 0.447417] mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x2c10000
[ 0.447428] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c20000
[ 0.447441] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c30000
[ 0.447451] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c40000
[ 0.447460] mc: mapped MMIO address: 0xffffff800b110000 -> 0x2c50000
[ 0.447468] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.447479] mc-err: mcerr ops are set to t18x
[ 0.447630] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.448782] iommu: Adding device 3530000.xhci to group 44
[ 0.448794] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.449253] iommu: Adding device 3550000.xudc to group 45
[ 0.449264] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.449995] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.450000] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.450576] iommu: Adding device 17000000.gp10b to group 46
[ 0.451609] tegra-reset 5000000.clock: registered 193 resets.
[ 0.453833] iommu: Adding device d000000.bpmp to group 47
[ 0.454039] bpmp: ping status is 0
[ 0.454137] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.456518] bpmp d000000.bpmp: probe ok
[ 0.459678] iommu: Adding device 2600000.dma to group 48
[ 0.460952] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.460980] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.461005] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.461028] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.461053] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.461077] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.461100] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.461295] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.465128] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.465296] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.466913] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.466928] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.467385] iommu: Adding device 3510000.hda to group 50
[ 0.474933] iommu: Adding device c1a0000.aon to group 51
[ 0.475370] vdd-ac-bat: 5000 mV
[ 0.476572] vdd-1v8-ap: 1800 mV
[ 0.497330] random: fast init done
[ 0.514854] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.520781] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.521292] SCSI subsystem initialized
[ 0.521507] libata version 3.00 loaded.
[ 0.521779] usbcore: registered new interface driver usbfs
[ 0.521835] usbcore: registered new interface driver hub
[ 0.521979] usbcore: registered new device driver usb
[ 0.527088] GPIO line 240 (do-rails) hogged as output/low
[ 0.527737] GPIO line 241 (do-rails) hogged as output/low
[ 0.528455] GPIO line 242 (do-rails) hogged as output/low
[ 0.528957] GPIO line 243 (do-rails) hogged as output/low
[ 0.529234] GPIO line 248 (di-rails) hogged as input
[ 0.529495] GPIO line 249 (di-rails) hogged as input
[ 0.529729] GPIO line 250 (di-rails) hogged as input
[ 0.529968] GPIO line 251 (di-rails) hogged as input
[ 0.530377] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.532014] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 0.532277] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.544873] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.549843] vddio-ddr: at 1125 mV
[ 0.553673] avdd_dsi_csi: 1200 mV
[ 0.557317] vdd-1v8: 1800 mV
[ 0.561320] vdd-3v3-sys: 3300 mV
[ 0.562660] spmic-ldo0: at 1800 mV
[ 0.563506] spmic-ldo1: at 800 mV
[ 0.565319] vddio-3v3: 3300 mV
[ 0.566194] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.569318] vdd-rtc: at 800 mV
[ 0.570201] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.573317] spmic-ldo6: at 1500 mV
[ 0.577317] vdd-pex-1v00: 1000 mV
[ 0.578085] dvdd-pex: 1000 mV
[ 0.580793] GPIO line 221 (spmic_gpio_input) hogged as input
[ 0.580960] GPIO line 222 (spmic_gpio_input) hogged as input
[ 0.581212] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
[ 0.581504] max77620 4-003c: max77620 probe successful
[ 0.581954] media: Linux media interface: v0.10
[ 0.582023] Linux video capture interface: v2.00
[ 0.585248] pps_core: LinuxPPS API ver. 1 registered
[ 0.585255] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.585328] PTP clock support registered
[ 0.586108] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.586141] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.590488] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[ 0.596071] trusty trusty: trusty version: Built: 22:43:54 Dec 9 2019
[ 0.596112] trusty trusty: selected api version: 3 (requested 3)
[ 0.597218] Advanced Linux Sound Architecture Driver Initialized.
[ 0.597795] Bluetooth: Core ver 2.22
[ 0.597829] NET: Registered protocol family 31
[ 0.597834] Bluetooth: HCI device and connection manager initialized
[ 0.597846] Bluetooth: HCI socket layer initialized
[ 0.597855] Bluetooth: L2CAP socket layer initialized
[ 0.597898] Bluetooth: SCO socket layer initialized
[ 0.598796] en-vdd-sd: 3300 mV
[ 0.599618] en-vdd-cam: 1800 mV
[ 0.605324] vdd-hdmi: 5000 mV
[ 0.605818] vdd-usb0-5v: 5000 mV
[ 0.606266] vdd-usb1-5v: 5000 mV
[ 0.607173] en-mdm-pwr-3v7: 3700 mV
[ 0.608031] en-vdd-cam-hv-2v8: 2800 mV
[ 0.608799] en-vdd-cam-1v2: 1200 mV
[ 0.609590] vdd-fan: 5000 mV
[ 0.609874] vdd-3v3: 3300 mV
[ 0.610138] en-vdd-vcm-2v8: 2800 mV
[ 0.610420] vdd-sys-bl: 3300 mV
[ 0.611220] en-vdd-sys: 1200 mV
[ 0.614275] camchar: rtcpu character device driver loaded
[ 0.614874] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.616800] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.618308] clocksource: Switched to clocksource arch_sys_counter
[ 0.659456] VFS: Disk quotas dquot_6.6.0
[ 0.659677] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.660295] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.661207] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.661215] nvmap_page_pool_init: Total RAM pages: 2006573
[ 0.661222] nvmap_page_pool_init: nvmap page pool size: 250821 pages (979 MB)
[ 0.661428] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.665535] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.677913] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.678108] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.678601] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.678703] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.678843] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.678982] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.679193] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.679499] la/ptsa driver initialized.
[ 0.679513] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.679518] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.680637] NET: Registered protocol family 2
[ 0.682714] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.683539] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.684341] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.684394] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.684550] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.685464] NET: Registered protocol family 1
[ 0.686644] RPC: Registered named UNIX socket transport module.
[ 0.686651] RPC: Registered udp transport module.
[ 0.686656] RPC: Registered tcp transport module.
[ 0.686661] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.686672] PCI: CLS 0 bytes, default 64
[ 0.686901] Trying to unpack rootfs image as initramfs...
[ 0.877596] Freeing initrd memory: 5432K
[ 0.899740] host1x 13e10000.host1x: initialized
[ 0.901691] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.906830] audit: initializing netlink subsys (disabled)
[ 0.906883] audit: type=2000 audit(0.800:1): initialized
[ 0.907778] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.925547] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.928425] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.930044] 9p: Installing v9fs 9p2000 file system support
[ 0.936779] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.936961] io scheduler noop registered
[ 0.937585] io scheduler cfq registered (default)
[ 0.942626] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.066555] iommu: Adding device aconnect@2a41000:adsp_audio to group 52
[ 1.106572] iommu: Adding device 2993000.adsp to group 53
[ 1.107779] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.110729] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 1.114964] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.116460] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.117815] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 1.119285] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.122414] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
[ 1.123508] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 1.123930] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[ 1.124242] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.124499] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.124511] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 1.128830] tsec 15500000.tsec: initialized
[ 1.130170] tsec 15100000.tsecb: initialized
[ 1.134265] nvdec 15480000.nvdec: initialized
[ 1.140311] falcon 15340000.vic: initialized
[ 1.141817] falcon 154c0000.nvenc: initialized
[ 1.143313] falcon 15380000.nvjpg: initialized
[ 1.147104] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.148803] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.150541] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.152196] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.153821] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.155429] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.156927] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.158445] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.161831] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.161846] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.161893] tegradccommon 15200000.dc_common: dma mapping done
[ 1.162396] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=390
[ 1.163007] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.163054] generic_infoframe_type: 0x87
[ 1.163140] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.163196] tegradc 15210000.nvdisplay: Display dc.ffffff800b650000 registered with id=0
[ 1.163431] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.164387] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.164415] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.164707] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.164715] tegra_cec 3960000.tegra_cec: probed
[ 1.168582] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.168587] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.168590] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.168756] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.168761] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.170326] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.177557] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.177567] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.181131] tegradc 15210000.nvdisplay: probed
[ 1.183525] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.184279] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.184839] kfuse 3830000.kfuse: initialized
[ 1.186501] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.192468] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.193595] Console: switching to colour frame buffer device 240x67
[ 1.193842] tegradc 15210000.nvdisplay: fb registered
[ 1.194166] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 1.194828] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.195114] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.195343] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.203193] console [ttyS0] disabled
[ 1.203233] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.203296] console [ttyS0] enabled
[ 1.203859] Parent Clock set for DC plld2
[ 1.205702] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.207021] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.207338] serial-tegra 3130000.serial: RX in PIO mode
[ 1.208348] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.209562] [drm] Initialized
[ 1.219779] brd: module loaded
[ 1.224414] loop: module loaded
[ 1.224516] tegra_profiler: version: 1.139, samples/io: 47/27
[ 1.224655] tegra_profiler: auth: init
[ 1.225186] nct1008_nct72 7-004c: starting parse dt
[ 1.225328] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.225356] nct1008_nct72 7-004c: success parsing dt
[ 1.225473] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.225632] THERMAL EST: found 3 subdevs
[ 1.225674] THERMAL EST num_resources: 0
[ 1.225714] [THERMAL EST subdev 0]
[ 1.225721] [THERMAL EST subdev 1]
[ 1.225727] [THERMAL EST subdev 2]
[ 1.226151] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.226156] THERMAL EST: thz register success.
[ 1.226260] THERMAL EST: end of probe, return err: 0
[ 1.229550] hisi_sas: driver version v1.6
[ 1.234143] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.234158] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.235430] scsi host0: tegra_ahci
[ 1.236995] scsi host1: tegra_ahci
[ 1.237246] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.237253] ata2: DUMMY
[ 1.237308] [MIC-720AI] Tegra AHCI Driver: Platform Init Success.
[ 1.257082] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 1.257710] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 1.266181] tegradc 15210000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.266751] tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.266766] tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.290654] nct1008_nct72 7-004c: initial LOC temp: 39000
[ 1.291006] nct1008_nct72 7-004c: initial EXT temp: 50750
[ 1.291682] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.292182] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.292430] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.294399] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.294405] Extcon AUX1(HDMI) enable
[ 1.337839] [MIC-720AI] Tegra AHCI Driver: Port 0 Setup ATA_PFLAG_EXTERNAL
[ 1.337849] [MIC-720AI] Tegra AHCI Driver: Port 1 Setup ATA_PFLAG_EXTERNAL
[ 1.344269] libphy: Fixed MDIO Bus: probed
[ 1.344781] tun: Universal TUN/TAP device driver, 1.6
[ 1.344786] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.345420] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.345426] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.345468] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.345473] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.345514] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.345518] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.345556] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.345561] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.354456] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 1.358238] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a5 5a 66
[ 1.358403] libphy: dwc_phy: probed
[ 1.358837] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.361004] PPP generic driver version 2.4.2
[ 1.361246] PPP BSD Compression module registered
[ 1.361253] PPP Deflate Compression module registered
[ 1.361301] PPP MPPE Compression module registered
[ 1.361308] NET: Registered protocol family 24
[ 1.361367] usbcore: registered new interface driver r8152
[ 1.361407] usbcore: registered new interface driver asix
[ 1.361438] usbcore: registered new interface driver ax88179_178a
[ 1.361466] usbcore: registered new interface driver cdc_ether
[ 1.361492] usbcore: registered new interface driver net1080
[ 1.361516] usbcore: registered new interface driver cdc_subset
[ 1.361540] usbcore: registered new interface driver zaurus
[ 1.361581] usbcore: registered new interface driver cdc_ncm
[ 1.361841] VFIO - User Level meta-driver version: 0.3
[ 1.363608] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.363631] ehci-pci: EHCI PCI platform driver
[ 1.363667] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.363677] ohci-pci: OHCI PCI platform driver
[ 1.363715] ohci-platform: OHCI generic platform driver
[ 1.369705] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.371961] tegra-xusb 3530000.xhci: extcon 0: ffffffc1eaddcc00 id
[ 1.372724] usbcore: registered new interface driver uas
[ 1.372775] usbcore: registered new interface driver usb-storage
[ 1.372867] usbcore: registered new interface driver usbserial
[ 1.374415] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 1.377662] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.378974] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 1.402576] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.402599] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.403434] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.403480] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 1.403741] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.403751] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.403758] usb usb1: Product: xHCI Host Controller
[ 1.403764] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.403770] usb usb1: SerialNumber: 3530000.xhci
[ 1.404170] hub 1-0:1.0: USB hub found
[ 1.404216] hub 1-0:1.0: 4 ports detected
[ 1.404636] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.404651] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.404907] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.404915] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.404921] usb usb2: Product: xHCI Host Controller
[ 1.404927] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.404932] usb usb2: SerialNumber: 3530000.xhci
[ 1.405413] hub 2-0:1.0: USB hub found
[ 1.405454] hub 2-0:1.0: 3 ports detected
[ 1.430661] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.466516] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.466519] Extcon AUX1(HDMI) disable
[ 1.470654] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 1.470660] tegra-usb-cd usb_cd: connected to SDP
[ 1.470675] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 1.470888] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 1.471550] mousedev: PS/2 mouse device common for all mice
[ 1.471618] usbcore: registered new interface driver xpad
[ 1.494278] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1.495017] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.498495] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.514468] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.527929] tegradc 15210000.nvdisplay: unblank
[ 1.533129] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.534152] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.534801] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.548175] Parent Clock set for DC plld2
[ 1.552141] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.552899] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.553580] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 1.553593] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.586922] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.588470] Wake73 for irq=42
[ 1.589553] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.589557] Extcon AUX1(HDMI) enable
[ 1.589760] rtc rtc1: alarm rtc device
[ 1.589774] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.589798] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.590015] i2c /dev entries driver
[ 1.591990] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.596952] parse_throttle_dt_data: Num cap clks = 4
[ 1.596955] parse_throttle_dt_data: clk=mcpu type=1
[ 1.596957] parse_throttle_dt_data: clk=bcpu type=2
[ 1.596964] parse_throttle_dt_data: clk=gpu type=4
[ 1.596966] parse_throttle_dt_data: clk=emc type=3
[ 1.597685] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.598232] FAN dev name: pwm-fan
[ 1.598311] FAN:gpio request success.
[ 1.598319] FAN: can't find tach_gpio
[ 1.598345] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.598533] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.598538] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.598933] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.598942] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.598948] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.598954] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.598959] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.598964] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.598968] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.598974] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.598980] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.598986] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.600672] device-mapper: uevent: version 1.0.3
[ 1.601556] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.601906] CPU EMC frequency mapping table: default setting
[ 1.606412] cpufreq: platform driver Initialization: pass
[ 1.607128] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 1.607241] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 1.608238] sdhci: Secure Digital Host Controller Interface driver
[ 1.608240] sdhci: Copyright(c) Pierre Ossman
[ 1.608243] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.609895] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.612058] CMDQ: cmdq_platfm_init successful
[ 1.613333] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.613337] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.616560] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.616611] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.617256] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.618968] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 1.622631] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.623571] tegra-se-nvhost 15810000.se: initialized
[ 1.624700] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.625380] tegra-se-nvhost 15820000.se: initialized
[ 1.626475] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.627104] tegra-se-nvhost 15830000.se: initialized
[ 1.627922] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.628514] tegra-se-nvhost 15840000.se: initialized
[ 1.629514] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.629756] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.630777] usbcore: registered new interface driver usbhid
[ 1.630779] usbhid: USB HID core driver
[ 1.637278] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 1.640164] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 1.640638] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 1.640905] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 1.641401] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 1.642843] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 1.642920] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 1.642972] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 1.643016] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 1.643128] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 1.643434] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 1.643436] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 1.644424] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 1.645992] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.646439] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.646585] register_ari_mca_banks: Registered MCA ROC:IOB
[ 1.646650] register_ari_mca_banks: Registered MCA ROC:CCE
[ 1.646946] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.646949] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 1.646951] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 1.647000] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647001] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 1.647003] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 1.647048] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647050] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 1.647051] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 1.647105] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647107] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 1.647108] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 1.647155] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647156] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 1.647158] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 1.647207] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647210] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 1.647212] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 1.647259] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647264] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 1.647265] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 1.647310] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647315] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 1.647316] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 1.647363] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647368] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 1.647369] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 1.647414] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647416] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 1.647417] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 1.647463] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647468] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 1.647469] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 1.647513] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647517] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 1.647519] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 1.647565] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647569] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 1.647570] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 1.647618] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647623] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 1.647624] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 1.647668] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.647672] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 1.647673] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 1.647731] **** A57 ECC: Enabled
[ 1.647733] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 1.647794] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 1.648241] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.648675] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 1.648790] denver_knobs_init:MTS_VERSION:47926945
[ 1.650430] nvpmodel: initialized successfully
[ 1.651258] trusty-virtio trusty:virtio: initializing
[ 1.651366] trusty_ipc virtio0: vring0: va(pa) ffffffc1e5486000(0) qsz 32 notifyid 1
[ 1.651372] trusty_ipc virtio0: vring1: va(pa) ffffffc1e54ac000(0) qsz 32 notifyid 2
[ 1.651434] trusty-virtio trusty:virtio: initializing done
[ 1.651687] trusty_ipc virtio0: is online
[ 1.654372] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.654396] usbcore: registered new interface driver snd-usb-audio
[ 1.662349] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.666716] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.666775] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.670803] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.670972] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.699973] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.713877] mmc0: periodic cache flush enabled
[ 1.713894] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.714396] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 1.714631] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 1.714882] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 1.719231] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 1.722621] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 1.729632] OPE platform probe
[ 1.729699] OPE platform probe successful
[ 1.730353] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.734525] u32 classifier
[ 1.734526] Actions configured
[ 1.734584] Initializing XFRM netlink socket
[ 1.735124] NET: Registered protocol family 10
[ 1.735726] NET: Registered protocol family 17
[ 1.735734] NET: Registered protocol family 15
[ 1.735789] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.735897] Bluetooth: RFCOMM socket layer initialized
[ 1.735911] Bluetooth: RFCOMM ver 1.11
[ 1.735914] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.735918] Bluetooth: HIDP socket layer initialized
[ 1.735932] 9pnet: Installing 9P2000 support
[ 1.735963] Key type dns_resolver registered
[ 1.736151] Registered cp15_barrier emulation handler
[ 1.736159] Registered setend emulation handler
[ 1.737400] registered taskstats version 1
[ 1.740912] isp 15600000.isp: initialized
[ 1.745715] nvcsi 150c0000.nvcsi: initialized
[ 1.751901] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 1.752118] input: gpio-keys as /devices/gpio-keys/input/input2
[ 1.753771] tegra-vi4 15700000.vi: initialized
[ 1.754687] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[ 1.761926] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.761931] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.761935] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 1.761937] usb 1-2: Manufacturer: Generic
[ 1.763127] hub 1-2:1.0: USB hub found
[ 1.764035] hub 1-2:1.0: 4 ports detected
[ 1.783068] tegra_rtc c2a0000.rtc: setting system clock to 2020-07-31 03:49:42 UTC (1596167382)
[ 1.784456] mmcblk mmc0:0001: Card claimed for testing.
[ 1.821153] bpmp: mounted debugfs mirror
[ 1.823305] bwmgr: missing cdev-type property
[ 1.828423] spmic-ldo0: disabling
[ 1.828698] spmic-ldo1: disabling
[ 1.828869] en-vdd-sd: disabling
[ 1.828874] en-vdd-cam: disabling
[ 1.828877] vdd-usb0-5v: disabling
[ 1.828881] vdd-usb1-5v: disabling
[ 1.828884] en-mdm-pwr-3v7: disabling
[ 1.828887] en-vdd-cam-hv-2v8: disabling
[ 1.828890] en-vdd-cam-1v2: disabling
[ 1.828925] vdd-fan: disabling
[ 1.828928] vdd-3v3: disabling
[ 1.828932] en-vdd-vcm-2v8: disabling
[ 1.828935] vdd-sys-bl: disabling
[ 1.828939] en-vdd-sys: disabling
[ 1.828943] ALSA device list:
[ 1.828948] #0: tegra-hda at 0x3518000 irq 383
[ 1.923523] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.186374] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.250911] tegra_cec 3960000.tegra_cec: Sent <Text View On> res: -113.
[ 2.250916] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.330724] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.332752] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.436236] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 2.436582] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 3.595672] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 3.595677] Extcon HDMI: HPD enabled
[ 3.595697] tegradc 15210000.nvdisplay: hdmi: plugged
[ 3.597676] Freeing unused kernel memory: 8576K
[ 3.638549] Root device found: mmcblk0p1
[ 3.640881] Found dev node: /dev/mmcblk0p1
[ 4.047074] EXT4-fs (mmcblk0p1): 19 orphan inodes deleted
[ 4.047081] EXT4-fs (mmcblk0p1): recovery complete
[ 4.056884] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.058458] Rootfs mounted over mmcblk0p1
[ 4.084636] Switching from initrd to actual rootfs
[ 4.214821] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.259440] cgroup: cgroup2: unknown option "nsdelegate"
[ 4.282768] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.285907] systemd[1]: Detected architecture arm64.
[ 4.374906] systemd[1]: Set hostname to <ubuntu>.
[ 4.474248] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.474274] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.526814] Wake76 for irq=199
[ 4.526820] Wake77 for irq=199
[ 4.526822] Wake78 for irq=199
[ 4.526825] Wake79 for irq=199
[ 4.526827] Wake80 for irq=199
[ 4.526829] Wake81 for irq=199
[ 4.526831] Wake82 for irq=199
[ 4.526862] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 4.526867] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 4.662559] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.665896] systemd[1]: Created slice System Slice.
[ 4.666585] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.673938] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.674009] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.674571] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.674923] systemd[1]: Listening on udev Kernel Socket.
[ 4.675032] systemd[1]: Reached target Swap.
[ 4.729618] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.744364] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 4.752840] random: crng init done
[ 4.752844] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.854657] usb 1-2-port2: connect-debounce failed
[ 4.859574] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 4.892786] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 4.892795] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.892799] usb 2-1: Product: 4-Port USB 3.0 Hub
[ 4.892803] usb 2-1: Manufacturer: Generic
[ 4.902013] hub 2-1:1.0: USB hub found
[ 4.903284] hub 2-1:1.0: 4 ports detected
[ 5.006783] systemd-journald[2287]: Received request to flush runtime journal from PID 1
[ 5.170351] usb 2-1: usb_suspend_both: status 0
[ 5.739117] ov5693 2-0036: probing v4l2 sensor.
[ 5.741693] ov5693 2-0036: tegracam sensor driver:ov5693_v2.0.6
[ 5.777457] using random self ethernet address
[ 5.782106] using random host ethernet address
[ 6.198625] Mass Storage Function, version: 2009/09/11
[ 6.198631] LUN: removable file: (no medium)
[ 6.221840] using random self ethernet address
[ 6.249081] using random host ethernet address
[ 6.377523] rndis0: HOST MAC fa:14:1b:5c:4d:88
[ 6.377718] rndis0: MAC fa:14:1b:5c:4d:89
[ 6.380100] usb0: HOST MAC fa:14:1b:5c:4d:8a
[ 6.380132] usb0: MAC fa:14:1b:5c:4d:8b
[ 6.380160] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.394811] l4tbr0: port 1(rndis0) entered blocking state
[ 6.394816] l4tbr0: port 1(rndis0) entered disabled state
[ 6.395345] device rndis0 entered promiscuous mode
[ 6.406416] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.425419] l4tbr0: port 2(usb0) entered blocking state
[ 6.425424] l4tbr0: port 2(usb0) entered disabled state
[ 6.425956] device usb0 entered promiscuous mode
[ 6.434116] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.535910] android_work: did not send uevent (0 0 (null))
[ 6.568933] android_work: sent uevent USB_STATE=CONNECTED
[ 6.753206] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 7.746437] usb 1-2-port4: connect-debounce failed
[ 8.346411] usb 2-1: usb_suspend_both: status 0
[ 8.346714] usb usb2: usb_suspend_both: status 0
[ 10.634524] usb 1-2-port2: connect-debounce failed
[ 11.391922] usb 2-1-port4: connect-debounce failed
[ 11.450339] usb 2-1: usb_suspend_both: status 0
[ 11.450495] usb usb2: usb_suspend_both: status 0
[ 14.550410] usb 2-1: usb_suspend_both: status 0
[ 14.550716] usb usb2: usb_suspend_both: status 0
[ 14.642366] usb 1-2.2: new low-speed USB device number 3 using tegra-xusb
[ 14.666863] usb 1-2.2: New USB device found, idVendor=093a, idProduct=2510
[ 14.666870] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 14.666875] usb 1-2.2: Product: USB Optical Mouse
[ 14.666879] usb 1-2.2: Manufacturer: PixA琀
[ 14.671198] input: PixA琀 USB Optical Mouse as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:093A:2510.0001/input/input3
[ 14.671596] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixA琀 USB Optical Mouse] on usb-3530000.xhci-2.2/input0
[ 14.894345] usb 1-2.4: new high-speed USB device number 4 using tegra-xusb
[ 14.926002] usb 1-2.4: New USB device found, idVendor=0bda, idProduct=5411
[ 14.926010] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 14.926014] usb 1-2.4: Product: 4-Port USB 2.0 Hub
[ 14.926018] usb 1-2.4: Manufacturer: Generic
[ 14.927835] hub 1-2.4:1.0: USB hub found
[ 14.929711] hub 1-2.4:1.0: 4 ports detected
[ 15.222347] usb 1-2.4.3: new low-speed USB device number 5 using tegra-xusb
[ 15.248776] usb 1-2.4.3: New USB device found, idVendor=1c4f, idProduct=0002
[ 15.248784] usb 1-2.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 15.248789] usb 1-2.4.3: Product: USB Keyboard
[ 15.248792] usb 1-2.4.3: Manufacturer: SIGMACHIP
[ 15.252576] input: SIGMACHIP USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.4/1-2.4.3/1-2.4.3:1.0/0003:1C4F:0002.0002/input/input4
[ 15.310904] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-3530000.xhci-2.4.3/input0
[ 15.313825] input: SIGMACHIP USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.4/1-2.4.3/1-2.4.3:1.1/0003:1C4F:0002.0003/input/input5
[ 15.370739] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-3530000.xhci-2.4.3/input1
[ 15.759633] CPU1: shutdown
[ 15.762405] psci: CPU1 killed.
[ 15.852507] CPU2: shutdown
[ 15.855436] psci: CPU2 killed.
[ 15.910112] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.997170] zram: Added device: zram0
[ 15.997613] zram: Added device: zram1
[ 15.998048] zram: Added device: zram2
[ 16.000940] zram: Added device: zram3
[ 16.001698] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 16.004221] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.022150] zram0: detected capacity change from 0 to 1029160960
[ 16.069439] Adding 1005036k swap on /dev/zram0. Priority:5 extents:1 across:1005036k SS
[ 16.075587] zram1: detected capacity change from 0 to 1029160960
[ 16.088111] Adding 1005036k swap on /dev/zram1. Priority:5 extents:1 across:1005036k SS
[ 16.091688] zram2: detected capacity change from 0 to 1029160960
[ 16.107235] Adding 1005036k swap on /dev/zram2. Priority:5 extents:1 across:1005036k SS
[ 16.122260] zram3: detected capacity change from 0 to 1029160960
[ 16.136053] Adding 1005036k swap on /dev/zram3. Priority:5 extents:1 across:1005036k SS
[ 16.940261] tegradc 15210000.nvdisplay: blank - powerdown
[ 17.004305] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 17.004307] Extcon AUX1(HDMI) disable
[ 17.031321] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 17.031419] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 17.032035] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 17.032223] tegradc 15210000.nvdisplay: unblank
[ 17.035404] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 17.035493] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 17.035573] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 17.036935] Parent Clock set for DC plld2
[ 17.040314] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 17.041531] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 17.041538] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 17.076841] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 17.076844] Extcon AUX1(HDMI) enable
[ 17.076914] tegradc 15210000.nvdisplay: unblank
[ 19.218111] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 19.218735] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.578877] fuse init (API version 7.26)
[ 19.686831] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.686841] Bluetooth: BNEP socket layer initialized
[ 20.545622] tegradc 15210000.nvdisplay: unblank
[ 36.673517] android_work: sent uevent USB_STATE=DISCONNECTED
[ 36.705909] android_work: sent uevent USB_STATE=CONNECTED
[ 36.741178] configfs-gadget gadget: high-speed config #1: c
[ 36.741211] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 36.741226] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 36.741243] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 36.741322] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 36.741338] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 36.741353] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 36.741456] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 36.741474] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 36.741494] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 36.741523] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 36.741730] android_work: sent uevent USB_STATE=CONFIGURED
[ 40.646116] l4tbr0: port 1(rndis0) entered blocking state
[ 40.646123] l4tbr0: port 1(rndis0) entered forwarding state
[ 40.647442] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 40.647468] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 105.412619] usb 1-2.4.3: USB disconnect, device number 5
[ 105.726020] usb 1-2.4: usb_suspend_both: status 0
[ 4677.448401] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 4677.448410] Extcon AUX1(HDMI) disable
[ 4677.473192] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 4677.473305] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4677.473952] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4677.474120] tegradc 15210000.nvdisplay: blank - powerdown
[ 4677.474251] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 4677.474256] Extcon HDMI: HPD disabled
[ 4677.474310] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 4677.478817] tegradc 15210000.nvdisplay: blank - powerdown
[ 4677.478829] tegradc 15210000.nvdisplay: unblank
[ 4677.478843] tegradc 15210000.nvdisplay: unblank
[ 4677.716975] tegradc 15210000.nvdisplay: blank - powerdown
[ 4677.717004] tegradc 15210000.nvdisplay: unblank
[ 4677.717805] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4677.717938] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4677.718040] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 4677.724488] Parent Clock set for DC plld2
[ 4677.728536] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 4677.730203] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 4677.730210] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4677.767506] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 4677.767511] Extcon AUX1(HDMI) enable
[ 4677.776158] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 4677.776161] Extcon HDMI: HPD enabled
[ 4677.776217] tegradc 15210000.nvdisplay: hdmi: plugged
[ 4677.781302] tegradc 15210000.nvdisplay: blank - powerdown
[ 4677.847723] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 4677.847731] Extcon AUX1(HDMI) disable
[ 4677.870902] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 4677.870996] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4677.871566] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4677.871753] tegradc 15210000.nvdisplay: unblank
[ 4677.872457] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4677.872558] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4677.872651] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 4677.874078] Parent Clock set for DC plld2
[ 4677.882328] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 4677.883610] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 4677.883616] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4677.925328] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 4677.925332] Extcon AUX1(HDMI) enable
[ 4677.925419] tegradc 15210000.nvdisplay: unblank
[ 4677.956024] tegradc 15210000.nvdisplay: unblank
tx2ai@ubuntu:~$ sudo rfkill list
0: bluedroid_pm: Bluetooth
Soft blocked: no
Hard blocked: no
tx2ai@ubuntu:~$ iwconfig
l4tbr0 no wireless extensions.
eth0 no wireless extensions.
lo no wireless extensions.
dummy0 no wireless extensions.
usb0 no wireless extensions.
rndis0 no wireless extensions.
dmesg |grep kernel
[ 0.163954] DTS File Name: /root/tx2ai/bsp/tx2_jetpack-4.3/build/source/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.421024] DTS File Name: /root/tx2ai/bsp/tx2_jetpack-4.3/build/source/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
