Having wifi issues with the tx2. I cannot start a wireless access point, or connect to an existing wifi hotspot.
Release: # R28 (release), REVISION: 2.1, GCID: 11272647, BOARD: t186ref, EABI: aarch64, DATE: Thu May 17 07:29:06 UTC 2018
Board: Auvidea J120
nvidia@tegra-ubuntu:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:04:4b:c5:61:7c
inet addr:172.16.154.89 Bcast:172.16.154.255 Mask:255.255.255.0
inet6 addr: fe80::204:4bff:fec5:617c/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:9000 Metric:1
RX packets:1595 errors:0 dropped:0 overruns:0 frame:0
TX packets:2887 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:144562 (144.5 KB) TX bytes:9558416 (9.5 MB)
Interrupt:43
l4tbr0 Link encap:Ethernet HWaddr b6:b5:28:de:52:ca
inet addr:192.168.55.1 Bcast:192.168.55.255 Mask:255.255.255.0
inet6 addr: fe80::1c16:2eff:fe83:54db/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:772 (772.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:796 errors:0 dropped:0 overruns:0 frame:0
TX packets:796 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:87219 (87.2 KB) TX bytes:87219 (87.2 KB)
usb0 Link encap:Ethernet HWaddr ea:9c:cd:f2:8a:00
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usb1 Link encap:Ethernet HWaddr b6:b5:28:de:52:ca
wlan0 Link encap:Ethernet HWaddr 00:04:4b:c5:61:7a
inet addr:192.168.8.1 Bcast:192.168.8.255 Mask:255.255.255.0
inet6 addr: fe80::204:4bff:fec5:617a/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
TX packets:86 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:10258 (10.2 KB)
iwconfig
usb0 no wireless extensions.
lo no wireless extensions.
dummy0 no wireless extensions.
wlan0 no wireless extensions.
l4tbr0 no wireless extensions.
usb1 no wireless extensions.
tunl0 no wireless extensions.
eth0 no wireless extensions.
hostapd.conf
nvidia@tegra-ubuntu:~$ cat /etc/hostapd/hostapd.conf
interface=wlan0
driver=nl80211
ssid=Float1
hw_mode=a
channel=36
#wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
country_code=AU
wpa_passphrase=pwd
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
# N
ieee80211n=1
require_ht=1
# AC
ieee80211ac=1
require_vht=1
ieee80211d=0
ieee80211h=0
wme_enabled=1
wmm_enabled=1
max_num_sta=2
[ 0.256504] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.258712] GPIO line 315 (wifi-wake-ap) hogged as input
[ 6.365206] tegra_net_perf_init: cannot get wifi sclk
[ 6.365284] found wifi platform device bcmdhd_wlan
[ 6.366479] wifi_platform_get_country_code_map: could not get country_code_map
[ 6.366481] wifi_plat_dev_drv_probe:platform country code map is not available
[ 6.366496] wifi_platform_set_power = 1
[ 6.568313] wifi_platform_bus_enumerate device present 1
[ 6.596922] wifi_platform_bus_enumerate device present 0
[ 6.682939] wifi_platform_prealloc: failed to alloc static mem section 7
[ 6.691451] wifi_platform_get_mac_addr
[ 6.912340] wifi_platform_set_power = 0
[ 8.192165] wl_android_wifi_on in
[ 8.192167] wifi_platform_set_power = 1
[ 8.795061] wifi_platform_get_mac_addr
[ 19.092409] wl_android_wifi_off in
[ 19.130392] wifi_platform_set_power = 0
I’ve set /etc/modprobe.d/bcmdhd.conf
options bcmdhd op_mode=2
When I disable disable hostapd, it still fails, and try to find a network via network manager or manually via /etc/network/inferfaces, it fails to find a network and powers down. I’ve copied the working configuration settings (hostapd,dnsmasq,/etc/network/interfaces) from another tx2.
