i change /boot/extlinux/extlinux.conf to install camera software, but when i reboot tx2, i could not open tx2 system.Log in in the logo cycle. Can i edit /boot/extlinux/extlinux.conf to solve this problem or reinstall tx2‘s system?
It would be rather rare that an edit to extlinux.conf
would cause early boot failure. There are ways to fix this which will maintain what you already have, but it is quite time consuming. Before doing so, if you look at your host PC’s flash software, you will find this file:
Linux_for_Tegra/rootfs/boot/extlinux/extlinux.conf
Can you use that as a guide and maybe give an idea of what your edit was?
Also, was this file being edited the only change? Was this edited in place on the Jetson without any host PC flash? Typically one would not flash to install this file, I’m wondering if some sort of flash might have caused unintended changes.
