Since I210 is working but not 82599, it looks like interoperability issue. Can you verify 82599ES on Jetson AGX and Jetson TX2 devkits? PCIe IP in Jetson AGX and TX2 are different, if there is any interoperability issue, link comes up on AGX but not TX2.
Thanks for reply.
Yes, we also have a Jetson AGX board connect 82599ES, and it works well.
Your meaning is if it links on AGX, then it will not link on TX2?
So what can I do next?And where can I find the TX2 support device list?
No, I think there is some interoperability issue between TX2/TX2i and 82599ES. Only way to root cause this issue is capture PCIe protocol traces. Is it possible to capture protocol traces?
We didn’t compiled a list, but we verified several NIC cards on TX2. Intel I210 is one of them. Could you tell me your requirements, I can reach out to QA team to find out if they verified any cards which fits to your requirements.
I can just capture the RST and REFCLK waveform on the OSC. I don’t know how to capture the PCIE protocol traces on the software, only the log information.
At present, we use TX2i PCIEx4 to connect 82599ES to realize the SFI interface. Please help me verify the NIC.
