I have a custom board based on the Jetson TX2i, with the reference design derived from the Jetson TX2i EVB kit
JETSON-TX2I-Carrier-board-schematics.pdf (1.2 MB)
Below mentioned sections have been removed my custom board.
- M2 Key E
- SD Card Socket
- SATA Connector
- HDMI Connector
- Display Connector.
These are my custom board schematics
Jetson Carrier_TX2i- MCU REV2.0-SCH.pdf (2.9 MB)
Jestson Carrier _TX2i_Power_Board_Rev 2.0-SCH.pdf (3.6 MB)
The USB 3.0 port has a Type-A connector, and the USB 3.0 root hub is enabled by the system-on-module (SoM). However, when I connect a USB 3.0 supported pedrive , it is not detected.
I followed the forum link to troubleshoot USB 3.0 bus detection using a USB 3.0 supported pendrive.
Could you please verify if the removal of any of the above sections could affect the detection of USB 3.0 devices on the bus?
