How to modify the pull-up/pull-down drive strength of GPIO3_PW.05 (uart3_cts) pin in GPIO mode on TX2NX ?How can I find this register?
Hi TrevinN,
What do you mean about “strength”?
You could just use pinmux spreadsheet to configure the usage and pin state for your desired pin.
Or you could refer to the Technical Reference Manual for the detail about the register.
For the Input
pin, you could select Int PU
to pull-up, or Int PD
to pull-down.
