Hello
I came across an error writing the result of an character-valued function to a character variable. The write command exits with a runtime error claiming a type/format mismatch, although the function is defined in the same module and its interface is (should be) therefore implicitly known to the write statement. The compiler points to another internal write statement within the character valued funcion, but this does not seem to be the problem because the latter works if its result is written to standard out (unit *).
I was able to reduce the problem to the following short test program (test.f90):
module isoprint
contains
function isodate(values)
implicit none
character(len=20) :: isodate
integer,intent(in) :: values(:)
write(isodate,5000) values
5000 format (i4,2("-",i2.2),i3,2(":",i2.2,:))
end function isodate
subroutine print_iso_date()
implicit none
character(len=60) message
print*,'Test program'
print*,'this works: ', isodate( (/ 2010, 9, 1, 12, 15 /) )
print*,'this does not: '
write(message,'(a)') isodate( (/ 2010, 9, 1, 12, 15 /) )
print*, message
end subroutine print_iso_date
end module isoprint
program test
use isoprint
implicit none
call print_iso_date()
end program test
When I comile and run it with pgf90, I get the following output (here with PGI 9.0.4, I also tested PGI 10.9.0 with the same result):
.../scratch> pgf90 -V test.f90 ; a.out
pgf90 9.0-4 64-bit target on x86-64 Linux -tp k8-64e
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2009, STMicroelectronics, Inc. All Rights Reserved.
PGF90/x86-64 Linux 9.0-4
Test program
this works: 2010-09-01 12:15
this does not:
PGFIO-F-235/formatted write/internal file/edit descriptor does not match
item type.
In source file test.f90, at line number 11
The reason for the runtime error seems to be the internal write statement in the print_iso_date() module procedure, not the one on line 11 pointed at by the runtime error message. It uses the format edit descriptor ‘(a)’, whereas the write statement seems to assume that the function isodate() is something other than character.
isodate() is a character function in the same module and hence its
interface is known to print_iso_date(), thus this looks like an incorrect treatement of the isodate() type in the internal write statement to me.
A hint that it might indeed be a compiler problem is that another compiler form a another vendor does not have this problem:
.../scratch> <another>f90 test.f90 ; a.out
Test program
this does not:
2010-09-01 12:15
Any comments are welcome.
Regards
Pirmin
