TypeError when running start_aas.sh
I’ve followed the instructions of the Clara-Train-SDK-AI-Assisted-Annotation-Getting-Started-Guide-EA.pdf but I’m failing at running the annotation server:
root@654a950243fc:/opt/nvidia# /opt/nvidia/medical/aas/start_aas.sh --config /var/tmp/models/engine_pool.json
  File "/usr/lib/python3.5/runpy.py", line 184, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/lib/python3.5/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "aas/aas_launcher.py", line 20, in <module>
  File "aas/server.py", line 101, in aas
TypeError: string indices must be integers
Thanks in advance,
Can you please share your engine_pool.json… there might be a type error related to string/integer.
Hi and thank you for your reply,
I found the issue, I simply confused the annotation_spleen.json file and the engine_pool one.
cool :)
