U-Boot SPL201410-rc2-g3127911(Jun 07 2016-21:00:01)
I bought an old Jetson TK1 development board, but there was an error “U-boot SPL 201410-RC2-G3127911 (Jun 07 2016-21:00:01)” when I started the machine again, but there was an error 45001 serial port at the last stage of the machine [2022-03-18 11:40:36.898]Rx: [0001.067] Dowrloaded bet successfully
0001.071 No 'the Present
0001.075 Sdram Initialization is successful
  1. 087 Dowrloaded DTB successfully
    [0001.114 No 'the Present
    0001.188 Downloaded bootloader suocessfully
    0001.192 CPU-Bootloader Entry Address: 0x83D88000
    0001.197 BoardId: 375
  2. 199 Vpr Carveout Base-0x0f4600000 Size=0x00ba00000
  3. 204 Tsec Carveout Base=0x0f2600000 Size-0x002000000
    0001.209lP0 Carveout Base- 0x0F25FF000 Size=0x000001000
    0001.214 Xusb Carveout Base- 0x0F2300000 Size=0x000200000
  4. 220 Platform-DebugCarveout:0
    [0001.249 NvTbootI2cWriteo: Error code Ox00045100 Error while starting write transaction
    [0001.257] NvTbootI2cDeviceWrite(): Error code 0x00045001 Error while writing
    [0001.264] NvTbootI2c: Read failed for slave 0x80, offset 0x00 with error code
    0x00045001
    [0001.271 FAILURE in NvTbobtConfigureCpu
    [0001.275 Error is 45001
mmexport1648730191254
mmexport1648729661383
Sorry for the late response, suggest to reflas the device to newer version Linux for Tegra R21.7 | NVIDIA Developer to see if issue still present.
ok I try
oh no
[2022-04-24 05:55:18.642]
RX:[0000.000] [TegraBoot] (version UNDEF_BUILD)
[0000.004] Reset reason: power on reset
[0000.007] Processing in recovery mode
[0000.011] Established communication link with host
[2022-04-24 05:55:19.834]
RX:[0001.166] Downloaded bct successfully
[0001.175] No Battery Present
[0001.179] Sdram initialization is successful
[0001.213] Downloaded DTB successfully
[0001.249] No Battery Present
[0001.541] Downloaded bootloader successfully
[0001.545] CPU-bootloader entry address: 0x83d88000
[0001.550] BoardId: 375
[0001.552] Vpr Carveout Base=0x0f4600000 Size=0x00ba00000
[0001.557] Tsec Carveout Base=0x0f2600000 Size=0x002000000
[0001.562] Lp0 Carveout Base=0x0f25ff000 Size=0x000001000
[0001.567] Xusb Carveout Base=0x0f2300000 Size=0x000200000
[0001.573] Platform-DebugCarveout: 0
[0001.611] NvTbootI2cWaitForTransferComplete(): error code 0x00000005 I2C Transaction could not complete within time
[0001.621] NvTbootI2cWrite(): error code 0x00000005 Error while starting write transaction
[0001.628] NvTbootI2cDeviceWrite(): error code 0x00045001 Error while writing
[0001.635] NvTbootI2c: Read failed for slave 0x80, offset 0x00 with error code 0x00045001
[0001.643] FAILURE in NvTbootConfigureCpu
[0001.646] Error is 45001
