hI All,
can you please let me know if the Jetson Nano & Xavier UART RX & TX have internal pull up resistors ?
Also is there any pin on the 260 pin Jetson Nano connector which gives 1.8v output ?
thanks
hI All,
thanks
Please check the pinmux sheet in DLC, it contains the pins output feature. Jetson Download Center | NVIDIA Developer
thanks but what is DLC. I had seen the product datasheet and guide in that the UART is mentioned as 1.8v CMOS logic but does it have any internal pull up resistors ?
DLC: download center. Jetson Download Center | NVIDIA Developer
No internal pull-up.
Thanks can you please let me know is there any pin on the 260 pin Jetson Nano connector which gives 1.8v output ?
Please check in pinmux sheet.
