Uart report cpu core errror
fmon_cpu_report_start_op_fault: FMON_NAFLL_CLUSTER1_CORE: detected fault 0x20
fmon_cpu_report_start_op_fault: FMON_NAFLL_CLUSTER2_DSU: detected fault 0x20
fmon_cpu_report_start_op_fault: FMON_NAFLL_CLUSTER0_DSU: detected fault 0x20
fmon_cpu_report_start_op_fault: FMON_NAFLL_CLUSTER0_CORE: detected fault 0x20
fmon_cpu_report_start_op_fault: FMON_NAFLL_CLUSTER2_CORE: detected fault 0x20
fmon_cpu_report_start_op_fault: FMON_NAFLL_CLUSTER1_DSU: detected fault 0x20
Hello, we are using a custom Orin Industry board. After vibration testing, this issue occurred. We would like to ask if this could be a core exception caused by hardware power supply issues.
Based on the provided context, it’s possible that the issue you’re experiencing with your custom Orin Industry board could be related to hardware power supply issues. Here are some points to consider:
  1. Power rail for TMP451: The power rail for TMP451 on Jetson AGX Orin Industrial is always on, which means that powering the board on without sufficient cooling can cause it to fail. This could be a potential cause of the issue, especially if the vibration testing has affected the cooling system or the power supply.
  2. Temperature threshold: The board can only be powered on again after the temperature falls below the (threshold - hysteresis) degree Celsius. If the board cannot be sufficiently cooled, it may not be able to power on, which could be related to the issue you’re experiencing.
  3. INA3221 power monitor: Jetson Orin modules integrate a three-channel INA3221 power monitor, which provides information about the power consumption of the board. You can use sysfs nodes to read this information and check if there are any anomalies in the power consumption that could be related to the issue.
  4. Core exception: A core exception is typically a software-related issue, but it can also be caused by hardware issues such as power supply problems. If the power supply is not stable or is not providing enough power to the board, it could cause a core exception.
To troubleshoot the issue, you can try the following:
  1. Check the power supply: Verify that the power supply is stable and providing enough power to the board.
  2. Check the cooling system: Ensure that the cooling system is working properly and that the board is not overheating.
  3. Use sysfs nodes: Use sysfs nodes to read the information from the INA3221 power monitor and check if there are any anomalies in the power consumption.
  4. Check for loose connections: Verify that all connections on the board are secure and not loose, as vibration testing can cause connections to become loose.
In comparison to other Jetson Orin modules, the Jetson AGX Orin Industrial has a similar power management system, but it’s possible that the custom design of your board could be causing the issue. It’s recommended to check the specific design of your board and compare it to the standard Jetson AGX Orin Industrial design to see if there are any differences that could be causing the issue.
In summary, while it’s possible that the issue is caused by a core exception, it’s also possible that it’s related to hardware power supply issues. Further troubleshooting is needed to determine the root cause of the issue.
