A setting issue like parity would indeed be an issue. If you had to set no parity it means the other end defaulted to this. Possibly you could set parity on both ends and have it work again. Defaults on most serial ports are 8N1, so this does not surprise me at all.
Related topics
| TX2 serial UARTs ttyTHS2 sometimes receive wrong message | 10 | 794 | October 18, 2021 | |
| cannot receive data through RS232 serial port | 6 | 1454 | October 18, 2021 | |
| Serial communication issue - "Got overrun errors" | 63 | 11444 | September 25, 2017 | |
| UART from arduino to J21 pins and voltage reduction. Missing bytes. | 15 | 1656 | October 18, 2021 | |
| Troubles with usb-serial adapter ch341 | 17 | 2048 | October 18, 2021 | |
| Communication between two TK1 with UART | 5 | 1199 | April 21, 2016 | |
| Serial /dev/ttyTHS1 C++. Strange problem | 3 | 1450 | July 3, 2023 | |
| UART TX2 - receive, teency 4.0 mcu | 9 | 1144 | October 18, 2021 | |
| How to Read Serial Data via C++ on Jetson TK1? | 11 | 296 | September 9, 2024 | |
| TX2 NX uartc Receiving exception | 5 | 581 | June 14, 2023 |
