hello chennakeshavareddy.palla,
it’s by default having debug console with pin-203/205, could you please check you’re able to setup a terminal and fetch the logs via serial port utility? such as picocom
or minicom
furthermore, you may try have below steps to remove UART2 debug messages on Jetson-Nano,
- Remove “earlyprintk=uart8250-32bit,0x70006000” from kernel cmdline
- Change ODMDATA to 0x14000
- Remove console=ttyS0 in kernel cmdline.
