Continuing the discussion from Tegra234-p3701-0004-p3737-0000 GPIO55_M4 Pin Unable to input interrupt:
我遇到同样的问题、
使用jetson linux 35.1.0在orin上,遇到设置uart4_rx_ph4、soc_gpio55_pm4、soc_gpio28_pq1为输入拉高,用作按键使用。配置Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi如下
Could you verify with the latest R35.5.0 and also use pinmux spreadsheet to configure the pinmux?
You should also configure gpio dtsi for the default state.
It seems there are other driver using these 3 pins.
Do you know which driver use them?
