Hello fellows.
I would like to use UART7 for an application.
Through changing of t18x-common-platforms/tegra186-quill-common.dtsi I now have this UART available.
The problem is that a strange debugging console I can’t find anything about also makes use of that UART.
When I boot the system this shows up.
SPE VERSION #: R00.01.07 Created: Apr 28 2017 @ 13:58:46
HW Function test
Start Scheduler.
in late init
welcome to lk
adc initialized
chip_revision initialized
speedo initialized
dt initialized
clk_init_mrq: mrq handler registered
383 clocks registered
clock initialized
reset initialized
i2c5 controller initialized
i2c10 controller initialized
initialized i2c mrq handling
i2c initialized
thermal initialized
fuse initialized
soctherm initialized
aotag initialized
cvc initialized
pwm_init: pwm 7 already enabled
pwm_init: pwm 8 already enabled
pwm_init: pwm 6 already enabled
regulator initialized
dvs initialized
t186_dvs initialized
pm initialized
tegra186_reset initialized
uart initialized
sku_init: not sku 00
sku initialized
tag initialized
avfs_clk_platform initialized
clock_dt initialized
powergate initialized
avfs_gpu initialized
clock_gpu initialized
debugfs_mrq initialized
emc initialized
gpmu2bpmp initialized
mc_init_mrq: mrq handler registered
mc initialized
pg_mrq initialized
pg_legacy_mrq initialized
pm_post initialized
ppm initialized
uphy_dt initialized
uphy initialized
wake initialized
mrq initialized
tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
tag_lateinit initialized
clock_debugfs initialized
thermal_test initialized
avfs_clk_platform_post initialized
avfs_debugfs initialized
clock_pto initialized
cvc_dt initialized
dvs_debugfs initialized
rm initialized
edp initialized
gboost initialized
powergate_debug initialized
regulator_post initialized
sku_debugfs initialized
speedo_debugfs initialized
soctherm_debug initialized
aotag_hsm initialized
sc7_diag initialized
starting app shell
entering main console loop
] help
command list:
try_dw : display memory in words. Skip data aborts
tests : invoke tests
ping : ping mail target
i2cw : write byte to PWR_I2C
i2cr : read byte from PWR_I2C
display_dt : display DT
chipid : display chipid info
tag : show tag
dh : display memory in halfwords
db : display memory in bytes
mw : modify word of memory
mh : modify halfword of memory
mb : modify byte of memory
fw : fill range of memory by word
fh : fill range of memory by halfword
fb : fill range of memory by byte
mc : copy a range of memory
cc : clean cache for a range of memory
ci : invalidate cache for a range of memory
cf : clean and invalidate (flush) cache for a range of memory
fc : clean and invalidate (flush) whole data cache
td : trace dump
help : this list
debugfs : debugfs commands
threads : list kernel threads
threadstats : thread level statistics
threadload : toggle thread load display
When I shut it down this happens
] Shutdown state requested 0
Shutting down system ...
This console shows up before extlinux is started. So I assume it’s started side by side with u-Boot.
So it seems to be a seperate controller giving me this interface.
What is this? Can I disable it?
