Hello.
I am trying to get an image with a frame rate of 120 from IMX290 via UB954 / 953.
I have an IMX290 driver that works successfully in three 30/60/120 fps modes when directly connected to the jetson TX2.
I configured UB954 / 953 correctly and added the line:
serdes_pix_clk_hz = “535000000”
to each mode in the dts file.
I successfully got an image with a frame rate of 30 / 60fps using both v4l2 and gst-launch-1.0 nvarguscamerasrc.
I can’t get an image from the IMX290 with a frame rate of 120.
I checked the CSI signal at the output of UB954 (respectively at the input of the jetson TX2) using an oscilloscope, the signal is on all 4 lines, the signal responds to the dimming of the sensor, unfortunately I can not check the signal but I’m sure the signal reaches the jetson TX2 and responds to change the sensor image.
Here is the debug output I get when I try to get an image:
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections…=== gst-launch-1.0[23846]: Connection established (7F749D71D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
=== gst-launch-1.0[23846]: CameraProvider initialized (0x7f7088f800)LSC: LSC surface is not based on full res!
NvViErrorDecode Stream 0.0 failed: ts 3878706206720 frame 36 error 2 data 0x00400060
NvViErrorDecode CaptureError: CsimuxFrameError (2)
NvViErrorDecode See https://wiki.nvidia.com/wmpwiki/index.php/Camera_Debugging/CaptureError_debugging for more information and links to documents.
CsimuxFrameError_Regular : 0x00400060
Stream ID [ 2: 0]: 0VPR state from fuse block [ 3]: 0 Frame end (FE) [ 5]: 1 A frame end has been found on a regular mode stream. CSI_FAULT [ 6]: 1 An FE packet was found and marked with a CSI Error CSI_CODE [25:20]: 0x4 Check the CSI specification for the meaning. See https://wiki.nvidia.com/wmpwiki/index.php/Camera_Debugging/CaptureError_debugging#CSI_CODE
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1147)
SCF: Error BadValue: timestamp cannot be 0 (in src/services/capture/NvViCsiHw.cpp, function waitCsiFrameStart(), line 630)
SCF: Error BadValue: (propagating from src/common/Utils.cpp, function workerThread(), line 116)
SCF: Error BadValue: Worker thread ViCsiHw frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
captureErrorCallback Stream 0.0 capture 3 failed: ts 3878706206720 frame 36 error 2 data 0x00400060SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 637)
SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 358)
SCF: Error Timeout: (propagating from src/common/Utils.cpp, function workerThread(), line 116)
SCF: Error Timeout: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: ISP port 0 timed out! (in src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 478)
SCF: Error Timeout: ISP Stats timed out! (in src/services/capture/NvIspHw.cpp, function waitIspStatsFinished(), line 561)
SCF: Error Timeout: ISP port 1 timed out! (in src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 501)
SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
SCF: Error Timeout: ISP port 2 timed out! (in src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 512)
SCF: Error Timeout: (propagating from src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 519)
SCF: Error Timeout: Worker thread IspHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
tracer: nop
entries-in-buffer/entries-written: 611/611 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
gst-plugin-scan-8698 [004] … 293.087019: tegra_channel_open: vi-output, imx290 2-001a
gst-plugin-scan-8698 [004] … 293.088036: tegra_channel_set_power: imx290 2-001a : 0x1
gst-plugin-scan-8698 [004] … 293.088043: camera_common_s_power: status : 0x1
gst-plugin-scan-8698 [004] … 293.111600: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
gst-plugin-scan-8698 [004] … 293.111608: csi_s_power: enable : 0x1
gst-plugin-scan-8698 [003] … 293.116205: tegra_channel_close: vi-output, imx290 2-001a
gst-plugin-scan-8698 [003] … 293.116214: tegra_channel_set_power: imx290 2-001a : 0x0
gst-plugin-scan-8698 [003] … 293.116226: camera_common_s_power: status : 0x0
gst-plugin-scan-8698 [003] … 293.116465: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
gst-plugin-scan-8698 [003] … 293.116467: csi_s_power: enable : 0x0
nvargus-daemon-8706 [005] … 293.555050: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8706 [005] … 293.555060: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8706 [005] … 293.555068: camera_common_s_power: status : 0x1
nvargus-daemon-8706 [005] … 293.578644: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8706 [005] … 293.578652: csi_s_power: enable : 0x1
nvargus-daemon-8706 [005] … 293.578917: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8706 [005] … 293.578924: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8706 [005] … 293.578936: camera_common_s_power: status : 0x0
nvargus-daemon-8706 [005] … 293.579159: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8706 [005] … 293.579161: csi_s_power: enable : 0x0
nvargus-daemon-8706 [005] … 293.583926: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8706 [005] … 293.583937: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8706 [005] … 293.583948: camera_common_s_power: status : 0x1
nvargus-daemon-8706 [000] … 293.607601: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8706 [000] … 293.607605: csi_s_power: enable : 0x1
nvargus-daemon-8706 [000] … 293.607793: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8706 [000] … 293.607797: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8706 [000] … 293.607809: camera_common_s_power: status : 0x0
nvargus-daemon-8706 [000] … 293.608013: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8706 [000] … 293.608015: csi_s_power: enable : 0x0
nvargus-daemon-8706 [000] … 293.639358: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8706 [000] … 293.639366: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8706 [000] … 293.639376: camera_common_s_power: status : 0x1
nvargus-daemon-8706 [000] … 293.662909: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8706 [000] … 293.662916: csi_s_power: enable : 0x1
nvargus-daemon-8706 [000] … 293.662963: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8706 [000] … 293.662968: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8706 [000] … 293.662978: camera_common_s_power: status : 0x0
nvargus-daemon-8706 [000] … 293.663192: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8706 [000] … 293.663194: csi_s_power: enable : 0x0
nvargus-daemon-8706 [000] … 293.663581: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8706 [000] … 293.663588: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8706 [000] … 293.663596: camera_common_s_power: status : 0x1
nvargus-daemon-8706 [000] … 293.687240: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8706 [000] … 293.687245: csi_s_power: enable : 0x1
nvargus-daemon-8706 [000] … 293.687474: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8706 [000] … 293.687479: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8706 [000] … 293.687492: camera_common_s_power: status : 0x0
nvargus-daemon-8706 [000] … 293.687741: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8706 [000] … 293.687744: csi_s_power: enable : 0x0
nvargus-daemon-8706 [000] … 293.688222: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8706 [000] … 293.688232: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8706 [000] … 293.688245: camera_common_s_power: status : 0x1
nvargus-daemon-8706 [000] … 293.712035: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8706 [000] … 293.712041: csi_s_power: enable : 0x1
nvargus-daemon-8706 [000] … 293.712463: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8706 [000] … 293.712471: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8706 [000] … 293.712483: camera_common_s_power: status : 0x0
nvargus-daemon-8706 [000] … 293.712731: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8706 [000] … 293.712735: csi_s_power: enable : 0x0
kworker/5:3-1677 [005] … 293.782490: rtos_queue_peek_from_isr_failed: tstamp:9465255409 queue:0x0b4b4500
kworker/5:3-1677 [005] … 293.782494: rtcpu_start: tstamp:9465256852
kworker/5:3-1677 [005] … 293.782496: rtos_queue_send_from_isr_failed: tstamp:9465324027 queue:0x0b4a7258
kworker/5:3-1677 [005] … 293.782496: rtos_queue_send_from_isr_failed: tstamp:9465324160 queue:0x0b4aad68
kworker/5:3-1677 [005] … 293.782497: rtos_queue_send_from_isr_failed: tstamp:9465324291 queue:0x0b4ac998
kworker/5:3-1677 [005] … 293.782497: rtos_queue_send_from_isr_failed: tstamp:9465324422 queue:0x0b4ae518
kworker/5:3-1677 [005] … 293.782498: rtos_queue_send_from_isr_failed: tstamp:9465324551 queue:0x0b4af2d8
kworker/5:3-1677 [005] … 293.782499: rtos_queue_send_from_isr_failed: tstamp:9465324678 queue:0x0b4b0098
kworker/5:3-1677 [005] … 293.782499: rtos_queue_send_from_isr_failed: tstamp:9465324806 queue:0x0b4b0e58
kworker/5:3-1677 [005] … 293.782500: rtos_queue_send_from_isr_failed: tstamp:9465324936 queue:0x0b4b1c18
kworker/5:3-1677 [005] … 293.782501: rtos_queue_send_failed: tstamp:9465325549 queue:0x0b4a7258
kworker/5:3-1677 [005] … 293.954499: rtos_queue_peek_from_isr_failed: tstamp:9470255734 queue:0x0b4b4500
CaptureSchedule-8723 [000] … 293.957360: tegra_channel_open: vi-output, imx290 2-001a
CaptureSchedule-8723 [000] … 293.957369: tegra_channel_set_power: imx290 2-001a : 0x1
CaptureSchedule-8723 [000] … 293.957378: camera_common_s_power: status : 0x1
CaptureSchedule-8723 [000] … 293.980967: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
CaptureSchedule-8723 [000] … 293.980971: csi_s_power: enable : 0x1
CaptureSchedule-8723 [005] … 293.986074: tegra_channel_set_stream: enable : 0x1
CaptureSchedule-8723 [000] … 293.987825: tegra_channel_set_stream: 150c0000.nvcsi–1 : 0x1
CaptureSchedule-8723 [000] … 293.987827: csi_s_stream: enable : 0x1
CaptureSchedule-8723 [000] … 293.987828: tegra_channel_set_stream: imx290 2-001a : 0x1
kworker/5:3-1677 [005] … 294.010518: rtos_queue_send_from_isr_failed: tstamp:9471599913 queue:0x0b4a7258
kworker/5:3-1677 [005] … 294.010523: rtos_queue_send_from_isr_failed: tstamp:9471600022 queue:0x0b4aad68
kworker/5:3-1677 [005] … 294.010524: rtos_queue_send_from_isr_failed: tstamp:9471600130 queue:0x0b4ac998
kworker/5:3-1677 [005] … 294.010525: rtos_queue_send_from_isr_failed: tstamp:9471600250 queue:0x0b4ae518
kworker/5:3-1677 [005] … 294.010526: rtos_queue_send_from_isr_failed: tstamp:9471600362 queue:0x0b4af2d8
kworker/5:3-1677 [005] … 294.010527: rtos_queue_send_from_isr_failed: tstamp:9471600465 queue:0x0b4b0098
kworker/5:3-1677 [005] … 294.010528: rtos_queue_send_from_isr_failed: tstamp:9471600571 queue:0x0b4b0e58
kworker/5:3-1677 [005] … 294.010530: rtos_queue_send_from_isr_failed: tstamp:9471600674 queue:0x0b4b1c18
kworker/5:3-1677 [005] … 294.010532: rtos_queue_send_failed: tstamp:9471601120 queue:0x0b4a7258
kworker/5:3-1677 [005] … 294.010533: rtos_queue_send_from_isr_failed: tstamp:9472463441 queue:0x0b4a7258
kworker/5:3-1677 [005] … 294.010534: rtos_queue_send_from_isr_failed: tstamp:9472463550 queue:0x0b4aad68
kworker/5:3-1677 [005] … 294.010535: rtos_queue_send_from_isr_failed: tstamp:9472463655 queue:0x0b4ac998
kworker/5:3-1677 [005] … 294.010536: rtos_queue_send_from_isr_failed: tstamp:9472463761 queue:0x0b4ae518
kworker/5:3-1677 [005] … 294.010537: rtos_queue_send_from_isr_failed: tstamp:9472463865 queue:0x0b4af2d8
kworker/5:3-1677 [005] … 294.010538: rtos_queue_send_from_isr_failed: tstamp:9472463970 queue:0x0b4b0098
kworker/5:3-1677 [005] … 294.010539: rtos_queue_send_from_isr_failed: tstamp:9472464075 queue:0x0b4b0e58
kworker/5:3-1677 [005] … 294.010540: rtos_queue_send_from_isr_failed: tstamp:9472464180 queue:0x0b4b1c18
kworker/5:3-1677 [005] … 294.010541: rtos_queue_send_failed: tstamp:9472464630 queue:0x0b4a7258
kworker/5:3-1677 [005] … 294.122575: rtos_queue_peek_from_isr_failed: tstamp:9475255770 queue:0x0b4b4500
kworker/5:3-1677 [005] … 294.234557: rtos_queue_peek_from_isr_failed: tstamp:9480255777 queue:0x0b4b4500
kworker/5:3-1677 [005] … 294.402595: rtos_queue_peek_from_isr_failed: tstamp:9485255804 queue:0x0b4b4500
kworker/5:3-1677 [005] … 294.570578: rtos_queue_peek_from_isr_failed: tstamp:9490255806 queue:0x0b4b4500
kworker/5:3-1677 [005] … 294.682552: rtos_queue_send_from_isr_failed: tstamp:9492693993 queue:0x0b4a7258
kworker/5:3-1677 [005] … 294.682561: rtos_queue_send_from_isr_failed: tstamp:9492694177 queue:0x0b4aad68
kworker/5:3-1677 [005] … 294.682562: rtos_queue_send_from_isr_failed: tstamp:9492694355 queue:0x0b4ac998
kworker/5:3-1677 [005] … 294.682564: rtos_queue_send_from_isr_failed: tstamp:9492694530 queue:0x0b4ae518
kworker/5:3-1677 [005] … 294.682566: rtos_queue_send_from_isr_failed: tstamp:9492694704 queue:0x0b4af2d8
kworker/5:3-1677 [005] … 294.682568: rtos_queue_send_from_isr_failed: tstamp:9492694878 queue:0x0b4b0098
kworker/5:3-1677 [005] … 294.682569: rtos_queue_send_from_isr_failed: tstamp:9492695050 queue:0x0b4b0e58
kworker/5:3-1677 [005] … 294.682571: rtos_queue_send_from_isr_failed: tstamp:9492695224 queue:0x0b4b1c18
kworker/5:3-1677 [005] … 294.682575: rtos_queue_send_failed: tstamp:9492697366 queue:0x0b4a7258
kworker/5:3-1677 [005] … 294.682579: rtcpu_vinotify_event: tstamp:9492699009 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:9492696835 data:0x00000001
kworker/5:3-1677 [005] … 294.682581: rtcpu_vinotify_event: tstamp:9492791712 tag:ISPBUF_FS channel:0x00 frame:35 vi_tstamp:9492791283 data:0x00000000
kworker/5:3-1677 [005] … 294.682582: rtcpu_vinotify_event: tstamp:9492794763 tag:CHANSEL_PXL_SOF channel:0x00 frame:35 vi_tstamp:9492794349 data:0x00000001
kworker/5:3-1677 [005] … 294.682583: rtcpu_vinotify_event: tstamp:9493044677 tag:CHANSEL_PXL_EOF channel:0x00 frame:35 vi_tstamp:9493043807 data:0x04370002
kworker/5:3-1677 [005] … 294.682584: rtcpu_vinotify_event: tstamp:9493044870 tag:CSIMUX_FRAME channel:0x00 frame:35 vi_tstamp:9493043863 data:0x00400060
kworker/5:3-1677 [005] … 294.682585: rtcpu_vinotify_event: tstamp:9493045141 tag:ISPBUF_FE channel:0x00 frame:35 vi_tstamp:9493043864 data:0x00000000
kworker/5:3-1677 [005] … 294.682587: rtos_queue_send_from_isr_failed: tstamp:9493218743 queue:0x0b4a7258
kworker/5:3-1677 [005] … 294.682589: rtos_queue_send_from_isr_failed: tstamp:9493218931 queue:0x0b4aad68
kworker/5:3-1677 [005] … 294.682591: rtos_queue_send_from_isr_failed: tstamp:9493219115 queue:0x0b4ac998
kworker/5:3-1677 [005] … 294.682593: rtos_queue_send_from_isr_failed: tstamp:9493219292 queue:0x0b4ae518
kworker/5:3-1677 [005] … 294.682594: rtos_queue_send_from_isr_failed: tstamp:9493219469 queue:0x0b4af2d8
kworker/5:3-1677 [005] … 294.682597: rtos_queue_send_from_isr_failed: tstamp:9493219643 queue:0x0b4b0098
kworker/5:3-1677 [005] … 294.682598: rtos_queue_send_from_isr_failed: tstamp:9493219827 queue:0x0b4b0e58
kworker/5:3-1677 [005] … 294.682600: rtos_queue_send_from_isr_failed: tstamp:9493220002 queue:0x0b4b1c18
kworker/5:3-1677 [005] … 294.682601: rtos_queue_send_failed: tstamp:9493220862 queue:0x0b4a7258
kworker/5:3-1677 [005] … 294.738575: rtos_queue_peek_from_isr_failed: tstamp:9495255794 queue:0x0b4b4500
kworker/5:3-1677 [005] … 294.906585: rtos_queue_peek_from_isr_failed: tstamp:9500255822 queue:0x0b4b4500
kworker/5:3-1677 [005] … 295.074521: rtos_queue_peek_from_isr_failed: tstamp:9505255828 queue:0x0b4b4500
kworker/5:3-1677 [005] … 295.242569: rtos_queue_peek_from_isr_failed: tstamp:9510255834 queue:0x0b4b4500
kworker/5:3-1677 [005] … 295.354565: rtos_queue_peek_from_isr_failed: tstamp:9515255853 queue:0x0b4b4500
kworker/5:3-1677 [005] … 295.522589: rtos_queue_peek_from_isr_failed: tstamp:9520255848 queue:0x0b4b4500
kworker/5:3-1677 [005] … 295.690596: rtos_queue_peek_from_isr_failed: tstamp:9525255866 queue:0x0b4b4500
kworker/5:3-1677 [005] … 295.858564: rtos_queue_peek_from_isr_failed: tstamp:9530255862 queue:0x0b4b4500
kworker/5:3-1677 [005] … 296.026563: rtos_queue_peek_from_isr_failed: tstamp:9535255881 queue:0x0b4b4500
kworker/5:3-1677 [005] … 296.194495: rtos_queue_peek_from_isr_failed: tstamp:9540255875 queue:0x0b4b4500
kworker/5:3-1677 [005] … 296.362582: rtos_queue_peek_from_isr_failed: tstamp:9545255894 queue:0x0b4b4500
kworker/5:3-1677 [005] … 296.474578: rtos_queue_peek_from_isr_failed: tstamp:9550255890 queue:0x0b4b4500
kworker/5:3-1677 [005] … 296.642605: rtos_queue_peek_from_isr_failed: tstamp:9555255907 queue:0x0b4b4500
kworker/5:3-1677 [005] … 296.810595: rtos_queue_peek_from_isr_failed: tstamp:9560255900 queue:0x0b4b4500
kworker/5:3-1677 [005] … 296.978583: rtos_queue_peek_from_isr_failed: tstamp:9565255909 queue:0x0b4b4500
kworker/5:3-1677 [005] … 297.146587: rtos_queue_peek_from_isr_failed: tstamp:9570255921 queue:0x0b4b4500
kworker/5:3-1677 [005] … 297.314585: rtos_queue_peek_from_isr_failed: tstamp:9575255923 queue:0x0b4b4500
kworker/5:3-1677 [005] … 297.482587: rtos_queue_peek_from_isr_failed: tstamp:9580255929 queue:0x0b4b4500
kworker/5:3-1677 [005] … 297.594583: rtos_queue_peek_from_isr_failed: tstamp:9585255935 queue:0x0b4b4500
kworker/5:3-1677 [005] … 297.762602: rtos_queue_peek_from_isr_failed: tstamp:9590255945 queue:0x0b4b4500
kworker/5:3-1677 [005] … 297.930599: rtos_queue_peek_from_isr_failed: tstamp:9595255947 queue:0x0b4b4500
kworker/5:3-1677 [005] … 298.098615: rtos_queue_peek_from_isr_failed: tstamp:9600255957 queue:0x0b4b4500
kworker/5:3-1677 [005] … 298.266590: rtos_queue_peek_from_isr_failed: tstamp:9605255984 queue:0x0b4b4500
kworker/5:3-1677 [005] … 298.434599: rtos_queue_peek_from_isr_failed: tstamp:9610255976 queue:0x0b4b4500
kworker/5:3-1677 [005] … 298.602599: rtos_queue_peek_from_isr_failed: tstamp:9615255978 queue:0x0b4b4500
kworker/5:3-1677 [005] … 298.714627: rtos_queue_peek_from_isr_failed: tstamp:9620255986 queue:0x0b4b4500
kworker/5:3-1677 [005] … 298.882598: rtos_queue_peek_from_isr_failed: tstamp:9625255991 queue:0x0b4b4500
kworker/5:3-1677 [005] … 299.050601: rtos_queue_peek_from_isr_failed: tstamp:9630255999 queue:0x0b4b4500
kworker/5:3-1677 [005] … 299.218605: rtos_queue_peek_from_isr_failed: tstamp:9635256005 queue:0x0b4b4500
kworker/5:3-1677 [005] … 299.386619: rtos_queue_peek_from_isr_failed: tstamp:9640256013 queue:0x0b4b4500
kworker/5:3-1677 [005] … 299.554611: rtos_queue_peek_from_isr_failed: tstamp:9645256019 queue:0x0b4b4500
kworker/5:3-1677 [005] … 299.722620: rtos_queue_peek_from_isr_failed: tstamp:9650256026 queue:0x0b4b4500
kworker/5:3-1677 [005] … 299.834608: rtos_queue_peek_from_isr_failed: tstamp:9655256033 queue:0x0b4b4500
kworker/5:3-1677 [005] … 300.002609: rtos_queue_peek_from_isr_failed: tstamp:9660256039 queue:0x0b4b4500
kworker/5:3-1677 [005] … 300.170608: rtos_queue_peek_from_isr_failed: tstamp:9665256047 queue:0x0b4b4500
kworker/5:3-1677 [005] … 300.338628: rtos_queue_peek_from_isr_failed: tstamp:9670256067 queue:0x0b4b4500
kworker/5:3-1677 [005] … 300.506626: rtos_queue_peek_from_isr_failed: tstamp:9675256034 queue:0x0b4b4500
kworker/5:3-1677 [005] … 300.674631: rtos_queue_peek_from_isr_failed: tstamp:9680256055 queue:0x0b4b4500
kworker/5:3-1677 [005] … 300.842620: rtos_queue_peek_from_isr_failed: tstamp:9685256048 queue:0x0b4b4500
kworker/5:3-1677 [005] … 300.954618: rtos_queue_peek_from_isr_failed: tstamp:9690256067 queue:0x0b4b4500
kworker/5:3-1677 [005] … 301.122619: rtos_queue_peek_from_isr_failed: tstamp:9695256075 queue:0x0b4b4500
kworker/5:3-1677 [005] … 301.290621: rtos_queue_peek_from_isr_failed: tstamp:9700256081 queue:0x0b4b4500
kworker/5:3-1677 [005] … 301.458641: rtos_queue_peek_from_isr_failed: tstamp:9705256075 queue:0x0b4b4500
kworker/5:3-1677 [005] … 301.626623: rtos_queue_peek_from_isr_failed: tstamp:9710256083 queue:0x0b4b4500
kworker/5:3-1677 [005] … 301.794627: rtos_queue_peek_from_isr_failed: tstamp:9715256089 queue:0x0b4b4500
kworker/5:3-1677 [005] … 301.962616: rtos_queue_peek_from_isr_failed: tstamp:9720256108 queue:0x0b4b4500
kworker/5:3-1677 [005] … 302.074660: rtos_queue_peek_from_isr_failed: tstamp:9725256116 queue:0x0b4b4500
kworker/5:3-1677 [005] … 302.242650: rtos_queue_peek_from_isr_failed: tstamp:9730256110 queue:0x0b4b4500
kworker/5:3-1677 [005] … 302.410637: rtos_queue_peek_from_isr_failed: tstamp:9735256117 queue:0x0b4b4500
kworker/5:3-1677 [005] … 302.578628: rtos_queue_peek_from_isr_failed: tstamp:9740256127 queue:0x0b4b4500
kworker/5:3-1677 [005] … 302.746654: rtos_queue_peek_from_isr_failed: tstamp:9745256167 queue:0x0b4b4500
kworker/5:3-1677 [005] … 302.914632: rtos_queue_peek_from_isr_failed: tstamp:9750256162 queue:0x0b4b4500
kworker/5:3-1677 [005] … 303.082646: rtos_queue_peek_from_isr_failed: tstamp:9755256170 queue:0x0b4b4500
kworker/5:3-1677 [005] … 303.194658: rtos_queue_peek_from_isr_failed: tstamp:9760256231 queue:0x0b4b4500
kworker/5:3-1677 [005] … 303.362561: rtos_queue_peek_from_isr_failed: tstamp:9765256136 queue:0x0b4b4500
kworker/5:3-1677 [005] … 303.534709: rtos_queue_peek_from_isr_failed: tstamp:9770256189 queue:0x0b4b4500
kworker/5:3-1677 [005] … 303.702674: rtos_queue_peek_from_isr_failed: tstamp:9775256196 queue:0x0b4b4500
kworker/5:3-1677 [005] … 303.870643: rtos_queue_peek_from_isr_failed: tstamp:9780256202 queue:0x0b4b4500
kworker/5:3-1677 [005] … 304.038653: rtos_queue_peek_from_isr_failed: tstamp:9785256208 queue:0x0b4b4500
kworker/5:3-1677 [005] … 304.206713: rtos_queue_peek_from_isr_failed: tstamp:9790256217 queue:0x0b4b4500
kworker/5:3-1677 [005] … 304.318661: rtos_queue_peek_from_isr_failed: tstamp:9795256236 queue:0x0b4b4500
kworker/5:3-1677 [005] … 304.486608: rtos_queue_peek_from_isr_failed: tstamp:9800256230 queue:0x0b4b4500
kworker/5:3-1677 [005] … 304.654687: rtos_queue_peek_from_isr_failed: tstamp:9805256237 queue:0x0b4b4500
kworker/5:3-1677 [005] … 304.838613: rtos_queue_peek_from_isr_failed: tstamp:9810256220 queue:0x0b4b4500
kworker/5:3-1677 [005] … 305.006666: rtos_queue_peek_from_isr_failed: tstamp:9815256261 queue:0x0b4b4500
kworker/5:3-1677 [005] … 305.118653: rtos_queue_peek_from_isr_failed: tstamp:9820256255 queue:0x0b4b4500
kworker/5:3-1677 [005] … 305.286648: rtos_queue_peek_from_isr_failed: tstamp:9825256277 queue:0x0b4b4500
kworker/5:3-1677 [005] … 305.454709: rtos_queue_peek_from_isr_failed: tstamp:9830256278 queue:0x0b4b4500
kworker/5:3-1677 [005] … 305.622658: rtos_queue_peek_from_isr_failed: tstamp:9835256290 queue:0x0b4b4500
kworker/5:3-1677 [005] … 305.790709: rtos_queue_peek_from_isr_failed: tstamp:9840256287 queue:0x0b4b4500
kworker/5:3-1677 [005] … 305.958659: rtos_queue_peek_from_isr_failed: tstamp:9845256303 queue:0x0b4b4500
kworker/5:3-1677 [005] … 306.126688: rtos_queue_peek_from_isr_failed: tstamp:9850256296 queue:0x0b4b4500
kworker/5:3-1677 [005] … 306.238678: rtos_queue_peek_from_isr_failed: tstamp:9855256315 queue:0x0b4b4500
kworker/5:3-1677 [005] … 306.406682: rtos_queue_peek_from_isr_failed: tstamp:9860256312 queue:0x0b4b4500
kworker/5:3-1677 [005] … 306.574688: rtos_queue_peek_from_isr_failed: tstamp:9865256319 queue:0x0b4b4500
kworker/5:3-1677 [005] … 306.742671: rtos_queue_peek_from_isr_failed: tstamp:9870256325 queue:0x0b4b4500
kworker/5:3-1677 [005] … 306.910677: rtos_queue_peek_from_isr_failed: tstamp:9875256333 queue:0x0b4b4500
kworker/5:3-1677 [005] … 307.078660: rtos_queue_peek_from_isr_failed: tstamp:9880256340 queue:0x0b4b4500
kworker/5:3-1677 [005] … 307.246672: rtos_queue_peek_from_isr_failed: tstamp:9885256346 queue:0x0b4b4500
kworker/5:3-1677 [005] … 307.358671: rtos_queue_peek_from_isr_failed: tstamp:9890256353 queue:0x0b4b4500
kworker/5:3-1677 [005] … 307.526695: rtos_queue_peek_from_isr_failed: tstamp:9895256359 queue:0x0b4b4500
kworker/5:3-1677 [005] … 307.694685: rtos_queue_peek_from_isr_failed: tstamp:9900256366 queue:0x0b4b4500
kworker/5:3-1677 [005] … 307.862697: rtos_queue_peek_from_isr_failed: tstamp:9905256348 queue:0x0b4b4500
kworker/5:3-1677 [005] … 308.030673: rtos_queue_peek_from_isr_failed: tstamp:9910256356 queue:0x0b4b4500
kworker/5:3-1677 [005] … 308.198696: rtos_queue_peek_from_isr_failed: tstamp:9915256362 queue:0x0b4b4500
kworker/5:3-1677 [005] … 308.366676: rtos_queue_peek_from_isr_failed: tstamp:9920256374 queue:0x0b4b4500
kworker/5:3-1677 [005] … 308.478666: rtos_queue_peek_from_isr_failed: tstamp:9925256389 queue:0x0b4b4500
kworker/5:3-1677 [005] … 308.646676: rtos_queue_peek_from_isr_failed: tstamp:9930256383 queue:0x0b4b4500
kworker/5:3-1677 [005] … 308.814699: rtos_queue_peek_from_isr_failed: tstamp:9935256388 queue:0x0b4b4500
kworker/5:3-1677 [005] … 308.982679: rtos_queue_peek_from_isr_failed: tstamp:9940256400 queue:0x0b4b4500
kworker/5:3-1677 [005] … 309.150680: rtos_queue_peek_from_isr_failed: tstamp:9945256405 queue:0x0b4b4500
kworker/5:3-1677 [005] … 309.318700: rtos_queue_peek_from_isr_failed: tstamp:9950256411 queue:0x0b4b4500
kworker/5:3-1677 [005] … 309.486682: rtos_queue_peek_from_isr_failed: tstamp:9955256423 queue:0x0b4b4500
kworker/5:3-1677 [005] … 309.598683: rtos_queue_peek_from_isr_failed: tstamp:9960256430 queue:0x0b4b4500
kworker/5:3-1677 [005] … 309.766682: rtos_queue_peek_from_isr_failed: tstamp:9965256430 queue:0x0b4b4500
kworker/5:3-1677 [005] … 309.934691: rtos_queue_peek_from_isr_failed: tstamp:9970256449 queue:0x0b4b4500
kworker/5:3-1677 [005] … 310.102724: rtos_queue_peek_from_isr_failed: tstamp:9975256444 queue:0x0b4b4500
kworker/5:3-1677 [005] … 310.270713: rtos_queue_peek_from_isr_failed: tstamp:9980256463 queue:0x0b4b4500
kworker/5:3-1677 [005] … 310.438693: rtos_queue_peek_from_isr_failed: tstamp:9985256459 queue:0x0b4b4500
kworker/5:3-1677 [005] … 310.606692: rtos_queue_peek_from_isr_failed: tstamp:9990256477 queue:0x0b4b4500
kworker/5:3-1677 [005] … 310.718691: rtos_queue_peek_from_isr_failed: tstamp:9995256472 queue:0x0b4b4500
kworker/5:3-1677 [005] … 310.886713: rtos_queue_peek_from_isr_failed: tstamp:10000256490 queue:0x0b4b4500
kworker/5:3-1677 [005] … 311.054695: rtos_queue_peek_from_isr_failed: tstamp:10005256487 queue:0x0b4b4500
kworker/5:3-1677 [005] … 311.222702: rtos_queue_peek_from_isr_failed: tstamp:10010256506 queue:0x0b4b4500
kworker/5:3-1677 [005] … 311.390698: rtos_queue_peek_from_isr_failed: tstamp:10015256499 queue:0x0b4b4500
kworker/5:3-1677 [005] … 311.558721: rtos_queue_peek_from_isr_failed: tstamp:10020256507 queue:0x0b4b4500
kworker/5:3-1677 [005] … 311.726729: rtos_queue_peek_from_isr_failed: tstamp:10025256516 queue:0x0b4b4500
kworker/5:3-1677 [005] … 311.838724: rtos_queue_peek_from_isr_failed: tstamp:10030256519 queue:0x0b4b4500
kworker/5:3-1677 [005] … 312.006716: rtos_queue_peek_from_isr_failed: tstamp:10035256538 queue:0x0b4b4500
kworker/5:3-1677 [005] … 312.174704: rtos_queue_peek_from_isr_failed: tstamp:10040256534 queue:0x0b4b4500
kworker/5:3-1677 [005] … 312.342709: rtos_queue_peek_from_isr_failed: tstamp:10045256541 queue:0x0b4b4500
kworker/5:3-1677 [005] … 312.510717: rtos_queue_peek_from_isr_failed: tstamp:10050256547 queue:0x0b4b4500
kworker/5:3-1677 [005] … 312.678740: rtos_queue_peek_from_isr_failed: tstamp:10055256557 queue:0x0b4b4500
kworker/5:3-1677 [005] … 312.846712: rtos_queue_peek_from_isr_failed: tstamp:10060256573 queue:0x0b4b4500
kworker/5:3-1677 [005] … 312.958720: rtos_queue_peek_from_isr_failed: tstamp:10065256572 queue:0x0b4b4500
kworker/5:3-1677 [005] … 313.126726: rtos_queue_peek_from_isr_failed: tstamp:10070256575 queue:0x0b4b4500
kworker/5:3-1677 [005] … 313.294720: rtos_queue_peek_from_isr_failed: tstamp:10075256582 queue:0x0b4b4500
kworker/5:3-1677 [005] … 313.462716: rtos_queue_peek_from_isr_failed: tstamp:10080256587 queue:0x0b4b4500
kworker/5:3-1677 [005] … 313.630728: rtos_queue_peek_from_isr_failed: tstamp:10085256599 queue:0x0b4b4500
kworker/5:3-1677 [005] … 313.798716: rtos_queue_peek_from_isr_failed: tstamp:10090256600 queue:0x0b4b4500
kworker/5:3-1677 [005] … 313.966719: rtos_queue_peek_from_isr_failed: tstamp:10095256609 queue:0x0b4b4500
kworker/5:3-1677 [005] … 314.078732: rtos_queue_peek_from_isr_failed: tstamp:10100256621 queue:0x0b4b4500
kworker/5:3-1677 [005] … 314.246727: rtos_queue_peek_from_isr_failed: tstamp:10105256622 queue:0x0b4b4500
kworker/5:3-1677 [005] … 314.414727: rtos_queue_peek_from_isr_failed: tstamp:10110256638 queue:0x0b4b4500
kworker/5:3-1677 [005] … 314.582727: rtos_queue_peek_from_isr_failed: tstamp:10115256646 queue:0x0b4b4500
kworker/5:3-1677 [005] … 314.750734: rtos_queue_peek_from_isr_failed: tstamp:10120256642 queue:0x0b4b4500
kworker/5:3-1677 [005] … 314.918732: rtos_queue_peek_from_isr_failed: tstamp:10125256661 queue:0x0b4b4500
kworker/5:3-1677 [005] … 315.086728: rtos_queue_peek_from_isr_failed: tstamp:10130256657 queue:0x0b4b4500
kworker/5:3-1677 [005] … 315.198728: rtos_queue_peek_from_isr_failed: tstamp:10135256675 queue:0x0b4b4500
kworker/5:3-1677 [005] … 315.366735: rtos_queue_peek_from_isr_failed: tstamp:10140256674 queue:0x0b4b4500
kworker/5:3-1677 [005] … 315.534736: rtos_queue_peek_from_isr_failed: tstamp:10145256688 queue:0x0b4b4500
kworker/5:3-1677 [005] … 315.702755: rtos_queue_peek_from_isr_failed: tstamp:10150256685 queue:0x0b4b4500
kworker/5:3-1677 [005] … 315.870755: rtos_queue_peek_from_isr_failed: tstamp:10155256703 queue:0x0b4b4500
kworker/5:3-1677 [005] … 316.038735: rtos_queue_peek_from_isr_failed: tstamp:10160256698 queue:0x0b4b4500
kworker/5:3-1677 [005] … 316.206743: rtos_queue_peek_from_isr_failed: tstamp:10165256705 queue:0x0b4b4500
kworker/5:3-1677 [005] … 316.318745: rtos_queue_peek_from_isr_failed: tstamp:10170256720 queue:0x0b4b4500
kworker/5:3-1677 [005] … 316.486805: rtos_queue_peek_from_isr_failed: tstamp:10175256717 queue:0x0b4b4500
kworker/5:3-1677 [005] … 316.654751: rtos_queue_peek_from_isr_failed: tstamp:10180256726 queue:0x0b4b4500
kworker/5:3-1677 [005] … 316.822746: rtos_queue_peek_from_isr_failed: tstamp:10185256732 queue:0x0b4b4500
kworker/5:3-1677 [005] … 316.990747: rtos_queue_peek_from_isr_failed: tstamp:10190256739 queue:0x0b4b4500
kworker/5:3-1677 [005] … 317.158742: rtos_queue_peek_from_isr_failed: tstamp:10195256744 queue:0x0b4b4500
kworker/5:3-1677 [005] … 317.326759: rtos_queue_peek_from_isr_failed: tstamp:10200256752 queue:0x0b4b4500
kworker/5:3-1677 [005] … 317.438738: rtos_queue_peek_from_isr_failed: tstamp:10205256758 queue:0x0b4b4500
kworker/5:3-1677 [005] … 317.606755: rtos_queue_peek_from_isr_failed: tstamp:10210256770 queue:0x0b4b4500
kworker/5:3-1677 [005] … 317.774763: rtos_queue_peek_from_isr_failed: tstamp:10215256773 queue:0x0b4b4500
kworker/5:3-1677 [005] … 317.942756: rtos_queue_peek_from_isr_failed: tstamp:10220256807 queue:0x0b4b4500
kworker/5:3-1677 [005] … 318.110764: rtos_queue_peek_from_isr_failed: tstamp:10225256808 queue:0x0b4b4500
kworker/5:3-1677 [005] … 318.278735: rtos_queue_peek_from_isr_failed: tstamp:10230256818 queue:0x0b4b4500
kworker/5:3-1677 [005] … 318.446762: rtos_queue_peek_from_isr_failed: tstamp:10235256824 queue:0x0b4b4500
kworker/5:3-1677 [005] … 318.558780: rtos_queue_peek_from_isr_failed: tstamp:10240256833 queue:0x0b4b4500
kworker/5:3-1677 [005] … 318.726766: rtos_queue_peek_from_isr_failed: tstamp:10245256896 queue:0x0b4b4500
kworker/5:3-1677 [005] … 318.894765: rtos_queue_peek_from_isr_failed: tstamp:10250256843 queue:0x0b4b4500
kworker/5:3-1677 [005] … 319.062766: rtos_queue_peek_from_isr_failed: tstamp:10255256852 queue:0x0b4b4500
kworker/5:3-1677 [005] … 319.230768: rtos_queue_peek_from_isr_failed: tstamp:10260256864 queue:0x0b4b4500
kworker/5:3-1677 [005] … 319.398772: rtos_queue_peek_from_isr_failed: tstamp:10265256865 queue:0x0b4b4500
kworker/5:3-1677 [005] … 319.566794: rtos_queue_peek_from_isr_failed: tstamp:10270256884 queue:0x0b4b4500
kworker/5:3-1677 [005] … 319.678819: rtos_queue_peek_from_isr_failed: tstamp:10275256878 queue:0x0b4b4500
kworker/5:3-1677 [005] … 319.846771: rtos_queue_peek_from_isr_failed: tstamp:10280256897 queue:0x0b4b4500
kworker/5:3-1677 [005] … 320.014774: rtos_queue_peek_from_isr_failed: tstamp:10285256897 queue:0x0b4b4500
kworker/5:3-1677 [005] … 320.182795: rtos_queue_peek_from_isr_failed: tstamp:10290256909 queue:0x0b4b4500
kworker/5:3-1677 [005] … 320.350799: rtos_queue_peek_from_isr_failed: tstamp:10295256910 queue:0x0b4b4500
kworker/5:3-1677 [005] … 320.518761: rtos_queue_peek_from_isr_failed: tstamp:10300256925 queue:0x0b4b4500
kworker/5:3-1677 [005] … 320.686805: rtos_queue_peek_from_isr_failed: tstamp:10305256923 queue:0x0b4b4500
kworker/5:3-1677 [005] … 320.798788: rtos_queue_peek_from_isr_failed: tstamp:10310256924 queue:0x0b4b4500
kworker/5:3-1677 [005] … 320.966785: rtos_queue_peek_from_isr_failed: tstamp:10315256933 queue:0x0b4b4500
kworker/5:3-1677 [005] … 321.134773: rtos_queue_peek_from_isr_failed: tstamp:10320256944 queue:0x0b4b4500
kworker/5:3-1677 [005] … 321.302793: rtos_queue_peek_from_isr_failed: tstamp:10325256954 queue:0x0b4b4500
kworker/5:3-1677 [005] … 321.470787: rtos_queue_peek_from_isr_failed: tstamp:10330256948 queue:0x0b4b4500
kworker/5:3-1677 [005] … 321.638786: rtos_queue_peek_from_isr_failed: tstamp:10335256954 queue:0x0b4b4500
kworker/5:3-1677 [005] … 321.806807: rtos_queue_peek_from_isr_failed: tstamp:10340256959 queue:0x0b4b4500
kworker/5:3-1677 [005] … 321.918789: rtos_queue_peek_from_isr_failed: tstamp:10345256967 queue:0x0b4b4500
kworker/5:3-1677 [005] … 322.086808: rtos_queue_peek_from_isr_failed: tstamp:10350256986 queue:0x0b4b4500
kworker/5:3-1677 [005] … 322.254799: rtos_queue_peek_from_isr_failed: tstamp:10355256986 queue:0x0b4b4500
kworker/5:3-1677 [005] … 322.422802: rtos_queue_peek_from_isr_failed: tstamp:10360256988 queue:0x0b4b4500
kworker/5:3-1677 [005] … 322.590786: rtos_queue_peek_from_isr_failed: tstamp:10365256995 queue:0x0b4b4500
kworker/5:3-1677 [005] … 322.758824: rtos_queue_peek_from_isr_failed: tstamp:10370257000 queue:0x0b4b4500
kworker/5:3-1677 [005] … 322.926831: rtos_queue_peek_from_isr_failed: tstamp:10375256997 queue:0x0b4b4500
kworker/5:3-1677 [005] … 323.038796: rtos_queue_peek_from_isr_failed: tstamp:10380256994 queue:0x0b4b4500
kworker/5:3-1677 [005] … 323.206755: rtos_queue_peek_from_isr_failed: tstamp:10385257003 queue:0x0b4b4500
kworker/5:3-1677 [005] … 323.374807: rtos_queue_peek_from_isr_failed: tstamp:10390257021 queue:0x0b4b4500
kworker/5:3-1677 [005] … 323.542793: rtos_queue_peek_from_isr_failed: tstamp:10395257013 queue:0x0b4b4500
kworker/5:3-1677 [005] … 323.710803: rtos_queue_peek_from_isr_failed: tstamp:10400257025 queue:0x0b4b4500
kworker/5:3-1677 [005] … 323.878797: rtos_queue_peek_from_isr_failed: tstamp:10405257031 queue:0x0b4b4500
kworker/5:3-1677 [005] … 324.046799: rtos_queue_peek_from_isr_failed: tstamp:10410257041 queue:0x0b4b4500
kworker/5:3-1677 [005] … 324.158821: rtos_queue_peek_from_isr_failed: tstamp:10415257054 queue:0x0b4b4500
kworker/5:3-1677 [005] … 324.326760: rtos_queue_peek_from_isr_failed: tstamp:10420257053 queue:0x0b4b4500
kworker/5:3-1677 [005] … 324.494799: rtos_queue_peek_from_isr_failed: tstamp:10425257071 queue:0x0b4b4500
kworker/5:3-1677 [005] … 324.662800: rtos_queue_peek_from_isr_failed: tstamp:10430257066 queue:0x0b4b4500
kworker/5:3-1677 [005] … 324.830806: rtos_queue_peek_from_isr_failed: tstamp:10435257084 queue:0x0b4b4500
kworker/5:3-1677 [005] … 324.998808: rtos_queue_peek_from_isr_failed: tstamp:10440257108 queue:0x0b4b4500
kworker/5:3-1677 [005] … 325.166829: rtos_queue_peek_from_isr_failed: tstamp:10445257123 queue:0x0b4b4500
kworker/5:3-1677 [005] … 325.278804: rtos_queue_peek_from_isr_failed: tstamp:10450257116 queue:0x0b4b4500
kworker/5:3-1677 [005] … 325.446833: rtos_queue_peek_from_isr_failed: tstamp:10455257134 queue:0x0b4b4500
kworker/5:3-1677 [005] … 325.614824: rtos_queue_peek_from_isr_failed: tstamp:10460257131 queue:0x0b4b4500
kworker/5:3-1677 [005] … 325.782823: rtos_queue_peek_from_isr_failed: tstamp:10465257142 queue:0x0b4b4500
kworker/5:3-1677 [005] … 325.950831: rtos_queue_peek_from_isr_failed: tstamp:10470257145 queue:0x0b4b4500
kworker/5:3-1677 [005] … 326.118834: rtos_queue_peek_from_isr_failed: tstamp:10475257153 queue:0x0b4b4500
kworker/5:3-1677 [005] … 326.286836: rtos_queue_peek_from_isr_failed: tstamp:10480257157 queue:0x0b4b4500
kworker/5:3-1677 [005] … 326.398851: rtos_queue_peek_from_isr_failed: tstamp:10485257163 queue:0x0b4b4500
kworker/5:3-1677 [005] … 326.566848: rtos_queue_peek_from_isr_failed: tstamp:10490257171 queue:0x0b4b4500
kworker/5:3-1677 [005] … 326.734864: rtos_queue_peek_from_isr_failed: tstamp:10495257179 queue:0x0b4b4500
kworker/5:3-1677 [005] … 326.902818: rtos_queue_peek_from_isr_failed: tstamp:10500257188 queue:0x0b4b4500
kworker/5:3-1677 [005] … 327.070826: rtos_queue_peek_from_isr_failed: tstamp:10505257194 queue:0x0b4b4500
kworker/5:3-1677 [005] … 327.238825: rtos_queue_peek_from_isr_failed: tstamp:10510257201 queue:0x0b4b4500
kworker/5:3-1677 [005] … 327.406828: rtos_queue_peek_from_isr_failed: tstamp:10515257207 queue:0x0b4b4500
kworker/5:3-1677 [005] … 327.518826: rtos_queue_peek_from_isr_failed: tstamp:10520257192 queue:0x0b4b4500
kworker/5:3-1677 [005] … 327.686839: rtos_queue_peek_from_isr_failed: tstamp:10525257197 queue:0x0b4b4500
kworker/5:3-1677 [005] … 327.854833: rtos_queue_peek_from_isr_failed: tstamp:10530257204 queue:0x0b4b4500
kworker/5:3-1677 [005] … 328.022851: rtos_queue_peek_from_isr_failed: tstamp:10535257210 queue:0x0b4b4500
kworker/5:3-1677 [005] … 328.190847: rtos_queue_peek_from_isr_failed: tstamp:10540257216 queue:0x0b4b4500
kworker/5:3-1677 [005] … 328.358843: rtos_queue_peek_from_isr_failed: tstamp:10545257230 queue:0x0b4b4500
kworker/5:3-1677 [005] … 328.526833: rtos_queue_peek_from_isr_failed: tstamp:10550257229 queue:0x0b4b4500
kworker/5:3-1677 [005] … 328.638831: rtos_queue_peek_from_isr_failed: tstamp:10555257238 queue:0x0b4b4500
kworker/5:3-1677 [005] … 328.806854: rtos_queue_peek_from_isr_failed: tstamp:10560257244 queue:0x0b4b4500
kworker/5:3-1677 [005] … 328.974841: rtos_queue_peek_from_isr_failed: tstamp:10565257264 queue:0x0b4b4500
kworker/5:3-1677 [005] … 329.142836: rtos_queue_peek_from_isr_failed: tstamp:10570257268 queue:0x0b4b4500
kworker/5:3-1677 [005] … 329.310834: rtos_queue_peek_from_isr_failed: tstamp:10575257264 queue:0x0b4b4500
kworker/5:3-1677 [005] … 329.478836: rtos_queue_peek_from_isr_failed: tstamp:10580257283 queue:0x0b4b4500
kworker/5:3-1677 [005] … 329.646838: rtos_queue_peek_from_isr_failed: tstamp:10585257302 queue:0x0b4b4500
kworker/5:3-1677 [005] … 329.758866: rtos_queue_peek_from_isr_failed: tstamp:10590257321 queue:0x0b4b4500
kworker/5:3-1677 [005] … 329.926839: rtos_queue_peek_from_isr_failed: tstamp:10595257316 queue:0x0b4b4500
kworker/5:3-1677 [005] … 330.094843: rtos_queue_peek_from_isr_failed: tstamp:10600257332 queue:0x0b4b4500
kworker/5:3-1677 [005] … 330.262861: rtos_queue_peek_from_isr_failed: tstamp:10605257330 queue:0x0b4b4500
kworker/5:3-1677 [005] … 330.430848: rtos_queue_peek_from_isr_failed: tstamp:10610257336 queue:0x0b4b4500
kworker/5:3-1677 [005] … 330.598870: rtos_queue_peek_from_isr_failed: tstamp:10615257343 queue:0x0b4b4500
kworker/5:3-1677 [005] … 330.766863: rtos_queue_peek_from_isr_failed: tstamp:10620257357 queue:0x0b4b4500
kworker/5:3-1677 [005] … 330.878846: rtos_queue_peek_from_isr_failed: tstamp:10625257368 queue:0x0b4b4500
kworker/5:3-1677 [005] … 331.046847: rtos_queue_peek_from_isr_failed: tstamp:10630257361 queue:0x0b4b4500
kworker/5:3-1677 [005] … 331.214888: rtos_queue_peek_from_isr_failed: tstamp:10635257384 queue:0x0b4b4500
kworker/5:3-1677 [005] … 331.382873: rtos_queue_peek_from_isr_failed: tstamp:10640257389 queue:0x0b4b4500
kworker/5:3-1677 [005] … 331.550863: rtos_queue_peek_from_isr_failed: tstamp:10645257365 queue:0x0b4b4500
kworker/5:3-1677 [005] … 331.718871: rtos_queue_peek_from_isr_failed: tstamp:10650257367 queue:0x0b4b4500
kworker/5:3-1677 [005] … 331.886875: rtos_queue_peek_from_isr_failed: tstamp:10655257373 queue:0x0b4b4500
kworker/5:3-1677 [005] … 331.998881: rtos_queue_peek_from_isr_failed: tstamp:10660257380 queue:0x0b4b4500
kworker/5:3-1677 [005] … 332.166872: rtos_queue_peek_from_isr_failed: tstamp:10665257399 queue:0x0b4b4500
kworker/5:3-1677 [005] … 332.334857: rtos_queue_peek_from_isr_failed: tstamp:10670257394 queue:0x0b4b4500
kworker/5:3-1677 [005] … 332.502859: rtos_queue_peek_from_isr_failed: tstamp:10675257405 queue:0x0b4b4500
kworker/5:3-1677 [005] … 332.670853: rtos_queue_peek_from_isr_failed: tstamp:10680257407 queue:0x0b4b4500
kworker/5:3-1677 [005] … 332.838860: rtos_queue_peek_from_isr_failed: tstamp:10685257414 queue:0x0b4b4500
kworker/5:3-1677 [005] … 333.006869: rtos_queue_peek_from_isr_failed: tstamp:10690257433 queue:0x0b4b4500
kworker/5:3-1677 [005] … 333.118855: rtos_queue_peek_from_isr_failed: tstamp:10695257427 queue:0x0b4b4500
kworker/5:3-1677 [005] … 333.286865: rtos_queue_peek_from_isr_failed: tstamp:10700257436 queue:0x0b4b4500
kworker/5:3-1677 [005] … 333.454862: rtos_queue_peek_from_isr_failed: tstamp:10705257442 queue:0x0b4b4500
kworker/5:3-1677 [005] … 333.622871: rtos_queue_peek_from_isr_failed: tstamp:10710257471 queue:0x0b4b4500
kworker/5:3-1677 [005] … 333.790882: rtos_queue_peek_from_isr_failed: tstamp:10715257477 queue:0x0b4b4500
kworker/5:3-1677 [005] … 333.958865: rtos_queue_peek_from_isr_failed: tstamp:10720257486 queue:0x0b4b4500
kworker/5:3-1677 [005] … 334.126866: rtos_queue_peek_from_isr_failed: tstamp:10725257498 queue:0x0b4b4500
kworker/5:3-1677 [005] … 334.238894: rtos_queue_peek_from_isr_failed: tstamp:10730257496 queue:0x0b4b4500
kworker/5:3-1677 [005] … 334.406894: rtos_queue_peek_from_isr_failed: tstamp:10735257513 queue:0x0b4b4500
kworker/5:3-1677 [005] … 334.574897: rtos_queue_peek_from_isr_failed: tstamp:10740257519 queue:0x0b4b4500
kworker/5:3-1677 [005] … 334.742869: rtos_queue_peek_from_isr_failed: tstamp:10745257525 queue:0x0b4b4500
kworker/5:3-1677 [005] … 334.910888: rtos_queue_peek_from_isr_failed: tstamp:10750257523 queue:0x0b4b4500
kworker/5:3-1677 [005] … 335.078872: rtos_queue_peek_from_isr_failed: tstamp:10755257539 queue:0x0b4b4500
kworker/5:3-1677 [005] … 335.246922: rtos_queue_peek_from_isr_failed: tstamp:10760257535 queue:0x0b4b4500
kworker/5:3-1677 [005] … 335.358871: rtos_queue_peek_from_isr_failed: tstamp:10765257554 queue:0x0b4b4500
kworker/5:3-1677 [005] … 335.526878: rtos_queue_peek_from_isr_failed: tstamp:10770257548 queue:0x0b4b4500
kworker/5:3-1677 [005] … 335.694879: rtos_queue_peek_from_isr_failed: tstamp:10775257557 queue:0x0b4b4500
kworker/5:3-1677 [005] … 335.862882: rtos_queue_peek_from_isr_failed: tstamp:10780257562 queue:0x0b4b4500
kworker/5:3-1677 [005] … 336.030885: rtos_queue_peek_from_isr_failed: tstamp:10785257573 queue:0x0b4b4500
kworker/5:3-1677 [005] … 336.198925: rtos_queue_peek_from_isr_failed: tstamp:10790257576 queue:0x0b4b4500
kworker/5:3-1677 [005] … 336.366887: rtos_queue_peek_from_isr_failed: tstamp:10795257583 queue:0x0b4b4500
kworker/5:3-1677 [005] … 336.478887: rtos_queue_peek_from_isr_failed: tstamp:10800257589 queue:0x0b4b4500
kworker/5:3-1677 [005] … 336.646914: rtos_queue_peek_from_isr_failed: tstamp:10805257577 queue:0x0b4b4500
kworker/5:3-1677 [005] … 336.814915: rtos_queue_peek_from_isr_failed: tstamp:10810257584 queue:0x0b4b4500
kworker/5:3-1677 [005] … 336.982895: rtos_queue_peek_from_isr_failed: tstamp:10815257592 queue:0x0b4b4500
kworker/5:3-1677 [005] … 337.150882: rtos_queue_peek_from_isr_failed: tstamp:10820257603 queue:0x0b4b4500
kworker/5:3-1677 [005] … 337.318894: rtos_queue_peek_from_isr_failed: tstamp:10825257605 queue:0x0b4b4500
kworker/5:3-1677 [005] … 337.486892: rtos_queue_peek_from_isr_failed: tstamp:10830257611 queue:0x0b4b4500
kworker/5:3-1677 [005] … 337.598911: rtos_queue_peek_from_isr_failed: tstamp:10835257618 queue:0x0b4b4500
kworker/5:3-1677 [005] … 337.766849: rtos_queue_peek_from_isr_failed: tstamp:10840257625 queue:0x0b4b4500
kworker/5:3-1677 [005] … 337.934891: rtos_queue_peek_from_isr_failed: tstamp:10845257644 queue:0x0b4b4500
kworker/5:3-1677 [005] … 338.102890: rtos_queue_peek_from_isr_failed: tstamp:10850257640 queue:0x0b4b4500
kworker/5:3-1677 [005] … 338.270951: rtos_queue_peek_from_isr_failed: tstamp:10855257649 queue:0x0b4b4500
kworker/5:3-1677 [005] … 338.438933: rtos_queue_peek_from_isr_failed: tstamp:10860257651 queue:0x0b4b4500
kworker/5:3-1677 [005] … 338.606896: rtos_queue_peek_from_isr_failed: tstamp:10865257660 queue:0x0b4b4500
kworker/5:3-1677 [005] … 338.718904: rtos_queue_peek_from_isr_failed: tstamp:10870257678 queue:0x0b4b4500
kworker/5:3-1677 [005] … 338.886911: rtos_queue_peek_from_isr_failed: tstamp:10875257674 queue:0x0b4b4500
kworker/5:3-1677 [005] … 339.054911: rtos_queue_peek_from_isr_failed: tstamp:10880257693 queue:0x0b4b4500
kworker/5:3-1677 [005] … 339.222863: rtos_queue_peek_from_isr_failed: tstamp:10885257727 queue:0x0b4b4500
kworker/5:3-1677 [005] … 339.391025: rtos_queue_peek_from_isr_failed: tstamp:10890257705 queue:0x0b4b4500
kworker/5:3-1677 [005] … 339.558909: rtos_queue_peek_from_isr_failed: tstamp:10895257704 queue:0x0b4b4500
kworker/5:3-1677 [005] … 339.726938: rtos_queue_peek_from_isr_failed: tstamp:10900257719 queue:0x0b4b4500
kworker/5:3-1677 [005] … 339.838922: rtos_queue_peek_from_isr_failed: tstamp:10905257715 queue:0x0b4b4500
kworker/5:3-1677 [005] … 340.007012: rtos_queue_peek_from_isr_failed: tstamp:10910257734 queue:0x0b4b4500
kworker/5:3-1677 [005] … 340.174903: rtos_queue_peek_from_isr_failed: tstamp:10915257729 queue:0x0b4b4500
kworker/5:3-1677 [005] … 340.342928: rtos_queue_peek_from_isr_failed: tstamp:10920257738 queue:0x0b4b4500
kworker/5:3-1677 [005] … 340.510927: rtos_queue_peek_from_isr_failed: tstamp:10925257749 queue:0x0b4b4500
kworker/5:3-1677 [005] … 340.678877: rtos_queue_peek_from_isr_failed: tstamp:10930257775 queue:0x0b4b4500
kworker/5:3-1677 [005] … 340.847043: rtos_queue_peek_from_isr_failed: tstamp:10935257781 queue:0x0b4b4500
kworker/5:3-1677 [005] … 340.959007: rtos_queue_peek_from_isr_failed: tstamp:10940257788 queue:0x0b4b4500
kworker/5:3-1677 [005] … 341.126923: rtos_queue_peek_from_isr_failed: tstamp:10945257794 queue:0x0b4b4500
kworker/5:3-1677 [005] … 341.294973: rtos_queue_peek_from_isr_failed: tstamp:10950257800 queue:0x0b4b4500
kworker/5:3-1677 [005] … 341.463012: rtos_queue_peek_from_isr_failed: tstamp:10955257820 queue:0x0b4b4500
kworker/5:3-1677 [005] … 341.630914: rtos_queue_peek_from_isr_failed: tstamp:10960257821 queue:0x0b4b4500
kworker/5:3-1677 [005] … 341.798963: rtos_queue_peek_from_isr_failed: tstamp:10965257822 queue:0x0b4b4500
kworker/5:3-1677 [005] … 341.966962: rtos_queue_peek_from_isr_failed: tstamp:10970257826 queue:0x0b4b4500
kworker/5:3-1677 [005] … 342.078959: rtos_queue_peek_from_isr_failed: tstamp:10975257836 queue:0x0b4b4500
kworker/5:3-1677 [005] … 342.246920: rtos_queue_peek_from_isr_failed: tstamp:10980257854 queue:0x0b4b4500
kworker/5:3-1677 [005] … 342.415048: rtos_queue_peek_from_isr_failed: tstamp:10985257848 queue:0x0b4b4500
kworker/5:3-1677 [005] … 342.582956: rtos_queue_peek_from_isr_failed: tstamp:10990257855 queue:0x0b4b4500
kworker/5:3-1677 [005] … 342.750947: rtos_queue_peek_from_isr_failed: tstamp:10995257861 queue:0x0b4b4500
kworker/5:3-1677 [005] … 342.919018: rtos_queue_peek_from_isr_failed: tstamp:11000257869 queue:0x0b4b4500
kworker/5:3-1677 [005] … 343.086929: rtos_queue_peek_from_isr_failed: tstamp:11005257885 queue:0x0b4b4500
kworker/5:3-1677 [005] … 343.198934: rtos_queue_peek_from_isr_failed: tstamp:11010257881 queue:0x0b4b4500
kworker/5:3-1677 [005] … 343.366946: rtos_queue_peek_from_isr_failed: tstamp:11015257889 queue:0x0b4b4500
kworker/5:3-1677 [005] … 343.534940: rtos_queue_peek_from_isr_failed: tstamp:11020257896 queue:0x0b4b4500
kworker/5:3-1677 [005] … 343.702931: rtos_queue_peek_from_isr_failed: tstamp:11025257891 queue:0x0b4b4500
kworker/5:3-1677 [005] … 343.871024: rtos_queue_peek_from_isr_failed: tstamp:11030257890 queue:0x0b4b4500
kworker/5:3-1677 [005] … 344.038951: rtos_queue_peek_from_isr_failed: tstamp:11035257904 queue:0x0b4b4500
kworker/5:3-1677 [005] … 344.206970: rtos_queue_peek_from_isr_failed: tstamp:11040257900 queue:0x0b4b4500
kworker/5:3-1677 [005] … 344.318963: rtos_queue_peek_from_isr_failed: tstamp:11045257919 queue:0x0b4b4500
kworker/5:3-1677 [005] … 344.486939: rtos_queue_peek_from_isr_failed: tstamp:11050257914 queue:0x0b4b4500
kworker/5:3-1677 [005] … 344.654965: rtos_queue_peek_from_isr_failed: tstamp:11055257932 queue:0x0b4b4500
kworker/5:3-1677 [005] … 344.822972: rtos_queue_peek_from_isr_failed: tstamp:11060257926 queue:0x0b4b4500
kworker/5:3-1677 [005] … 344.990974: rtos_queue_peek_from_isr_failed: tstamp:11065257945 queue:0x0b4b4500
kworker/5:3-1677 [005] … 345.158949: rtos_queue_peek_from_isr_failed: tstamp:11070257939 queue:0x0b4b4500
kworker/5:3-1677 [005] … 345.326944: rtos_queue_peek_from_isr_failed: tstamp:11075257948 queue:0x0b4b4500
kworker/5:3-1677 [005] … 345.438960: rtos_queue_peek_from_isr_failed: tstamp:11080257966 queue:0x0b4b4500
kworker/5:3-1677 [005] … 345.606980: rtos_queue_peek_from_isr_failed: tstamp:11085257961 queue:0x0b4b4500
kworker/5:3-1677 [005] … 345.774983: rtos_queue_peek_from_isr_failed: tstamp:11090257989 queue:0x0b4b4500
kworker/5:3-1677 [005] … 345.942942: rtos_queue_peek_from_isr_failed: tstamp:11095257998 queue:0x0b4b4500
kworker/5:3-1677 [005] … 346.110945: rtos_queue_peek_from_isr_failed: tstamp:11100258006 queue:0x0b4b4500
kworker/5:3-1677 [005] … 346.278958: rtos_queue_peek_from_isr_failed: tstamp:11105258012 queue:0x0b4b4500
kworker/5:3-1677 [005] … 346.446973: rtos_queue_peek_from_isr_failed: tstamp:11110258020 queue:0x0b4b4500
kworker/5:3-1677 [005] … 346.558953: rtos_queue_peek_from_isr_failed: tstamp:11115258026 queue:0x0b4b4500
kworker/5:3-1677 [005] … 346.726978: rtos_queue_peek_from_isr_failed: tstamp:11120258033 queue:0x0b4b4500
kworker/5:3-1677 [005] … 346.894959: rtos_queue_peek_from_isr_failed: tstamp:11125258039 queue:0x0b4b4500
kworker/5:3-1677 [005] … 347.062951: rtos_queue_peek_from_isr_failed: tstamp:11130258046 queue:0x0b4b4500
kworker/5:3-1677 [005] … 347.230945: rtos_queue_peek_from_isr_failed: tstamp:11135258053 queue:0x0b4b4500
kworker/5:3-1677 [005] … 347.398962: rtos_queue_peek_from_isr_failed: tstamp:11140258061 queue:0x0b4b4500
kworker/5:3-1677 [005] … 347.566941: rtos_queue_peek_from_isr_failed: tstamp:11145258064 queue:0x0b4b4500
kworker/5:3-1677 [005] … 347.678965: rtos_queue_peek_from_isr_failed: tstamp:11150258074 queue:0x0b4b4500
kworker/5:3-1677 [005] … 347.846956: rtos_queue_peek_from_isr_failed: tstamp:11155258080 queue:0x0b4b4500
kworker/5:3-1677 [005] … 348.014951: rtos_queue_peek_from_isr_failed: tstamp:11160258087 queue:0x0b4b4500
kworker/5:3-1677 [005] … 348.182971: rtos_queue_peek_from_isr_failed: tstamp:11165258094 queue:0x0b4b4500
kworker/5:3-1677 [005] … 348.350978: rtos_queue_peek_from_isr_failed: tstamp:11170258108 queue:0x0b4b4500
kworker/5:3-1677 [005] … 348.518961: rtos_queue_peek_from_isr_failed: tstamp:11175258108 queue:0x0b4b4500
kworker/5:3-1677 [005] … 348.686992: rtos_queue_peek_from_isr_failed: tstamp:11180258127 queue:0x0b4b4500
kworker/5:3-1677 [005] … 348.798963: rtos_queue_peek_from_isr_failed: tstamp:11185258121 queue:0x0b4b4500
kworker/5:3-1677 [005] … 348.966953: rtos_queue_peek_from_isr_failed: tstamp:11190258140 queue:0x0b4b4500
kworker/5:3-1677 [005] … 349.134963: rtos_queue_peek_from_isr_failed: tstamp:11195258134 queue:0x0b4b4500
kworker/5:3-1677 [005] … 349.302955: rtos_queue_peek_from_isr_failed: tstamp:11200258152 queue:0x0b4b4500
kworker/5:3-1677 [005] … 349.470952: rtos_queue_peek_from_isr_failed: tstamp:11205258206 queue:0x0b4b4500
kworker/5:3-1677 [005] … 349.638982: rtos_queue_peek_from_isr_failed: tstamp:11210258168 queue:0x0b4b4500
kworker/5:3-1677 [005] … 349.806970: rtos_queue_peek_from_isr_failed: tstamp:11215258162 queue:0x0b4b4500
kworker/5:3-1677 [005] … 349.918959: rtos_queue_peek_from_isr_failed: tstamp:11220258169 queue:0x0b4b4500
kworker/5:3-1677 [005] … 350.086992: rtos_queue_peek_from_isr_failed: tstamp:11225258184 queue:0x0b4b4500
kworker/5:3-1677 [005] … 350.254991: rtos_queue_peek_from_isr_failed: tstamp:11230258158 queue:0x0b4b4500
kworker/5:3-1677 [005] … 350.422972: rtos_queue_peek_from_isr_failed: tstamp:11235258174 queue:0x0b4b4500
kworker/5:3-1677 [005] … 350.590974: rtos_queue_peek_from_isr_failed: tstamp:11240258172 queue:0x0b4b4500
kworker/5:3-1677 [005] … 350.758972: rtos_queue_peek_from_isr_failed: tstamp:11245258180 queue:0x0b4b4500
kworker/5:3-1677 [005] … 350.926972: rtos_queue_peek_from_isr_failed: tstamp:11250258186 queue:0x0b4b4500
kworker/5:3-1677 [005] … 351.038969: rtos_queue_peek_from_isr_failed: tstamp:11255258193 queue:0x0b4b4500
kworker/5:3-1677 [005] … 351.206989: rtos_queue_peek_from_isr_failed: tstamp:11260258198 queue:0x0b4b4500
kworker/5:3-1677 [005] … 351.374967: rtos_queue_peek_from_isr_failed: tstamp:11265258205 queue:0x0b4b4500
kworker/5:3-1677 [005] … 351.542967: rtos_queue_peek_from_isr_failed: tstamp:11270258224 queue:0x0b4b4500
kworker/5:3-1677 [005] … 351.710985: rtos_queue_peek_from_isr_failed: tstamp:11275258223 queue:0x0b4b4500
kworker/5:3-1677 [005] … 351.878971: rtos_queue_peek_from_isr_failed: tstamp:11280258227 queue:0x0b4b4500
kworker/5:3-1677 [005] … 352.046967: rtos_queue_peek_from_isr_failed: tstamp:11285258234 queue:0x0b4b4500
kworker/5:3-1677 [005] … 352.158983: rtos_queue_peek_from_isr_failed: tstamp:11290258240 queue:0x0b4b4500
kworker/5:3-1677 [005] … 352.327000: rtos_queue_peek_from_isr_failed: tstamp:11295258284 queue:0x0b4b4500
kworker/5:3-1677 [005] … 352.494972: rtos_queue_peek_from_isr_failed: tstamp:11300258279 queue:0x0b4b4500
kworker/5:3-1677 [005] … 352.662995: rtos_queue_peek_from_isr_failed: tstamp:11305258285 queue:0x0b4b4500
kworker/5:3-1677 [005] … 352.830996: rtos_queue_peek_from_isr_failed: tstamp:11310258292 queue:0x0b4b4500
kworker/5:3-1677 [005] … 352.998980: rtos_queue_peek_from_isr_failed: tstamp:11315258298 queue:0x0b4b4500
kworker/5:3-1677 [005] … 353.167024: rtos_queue_peek_from_isr_failed: tstamp:11320258317 queue:0x0b4b4500
kworker/5:3-1677 [005] … 353.278997: rtos_queue_peek_from_isr_failed: tstamp:11325258323 queue:0x0b4b4500
kworker/5:3-1677 [005] … 353.446984: rtos_queue_peek_from_isr_failed: tstamp:11330258320 queue:0x0b4b4500
kworker/5:3-1677 [005] … 353.614982: rtos_queue_peek_from_isr_failed: tstamp:11335258339 queue:0x0b4b4500
kworker/5:3-1677 [005] … 353.783003: rtos_queue_peek_from_isr_failed: tstamp:11340258335 queue:0x0b4b4500
kworker/5:3-1677 [005] … 353.950995: rtos_queue_peek_from_isr_failed: tstamp:11345258342 queue:0x0b4b4500
kworker/5:3-1677 [005] … 354.118990: rtos_queue_peek_from_isr_failed: tstamp:11350258349 queue:0x0b4b4500
kworker/5:3-1677 [005] … 354.286979: rtos_queue_peek_from_isr_failed: tstamp:11355258366 queue:0x0b4b4500
kworker/5:3-1677 [005] … 354.399000: rtos_queue_peek_from_isr_failed: tstamp:11360258361 queue:0x0b4b4500
kworker/5:3-1677 [005] … 354.566987: rtos_queue_peek_from_isr_failed: tstamp:11365258367 queue:0x0b4b4500
kworker/5:3-1677 [005] … 354.735003: rtos_queue_peek_from_isr_failed: tstamp:11370258386 queue:0x0b4b4500
kworker/5:3-1677 [005] … 354.903021: rtos_queue_peek_from_isr_failed: tstamp:11375258381 queue:0x0b4b4500
kworker/5:3-1677 [005] … 355.071024: rtos_queue_peek_from_isr_failed: tstamp:11380258388 queue:0x0b4b4500
kworker/5:3-1677 [005] … 355.238994: rtos_queue_peek_from_isr_failed: tstamp:11385258393 queue:0x0b4b4500
kworker/5:3-1677 [005] … 355.407020: rtos_queue_peek_from_isr_failed: tstamp:11390258408 queue:0x0b4b4500
kworker/5:3-1677 [005] … 355.519014: rtos_queue_peek_from_isr_failed: tstamp:11395258395 queue:0x0b4b4500
kworker/5:3-1677 [005] … 355.687023: rtos_queue_peek_from_isr_failed: tstamp:11400258391 queue:0x0b4b4500
kworker/5:3-1677 [005] … 355.854998: rtos_queue_peek_from_isr_failed: tstamp:11405258397 queue:0x0b4b4500
kworker/5:3-1677 [005] … 356.022993: rtos_queue_peek_from_isr_failed: tstamp:11410258404 queue:0x0b4b4500
kworker/5:3-1677 [005] … 356.191009: rtos_queue_peek_from_isr_failed: tstamp:11415258410 queue:0x0b4b4500
kworker/5:3-1677 [005] … 356.359001: rtos_queue_peek_from_isr_failed: tstamp:11420258419 queue:0x0b4b4500
kworker/5:3-1677 [005] … 356.527025: rtos_queue_peek_from_isr_failed: tstamp:11425258425 queue:0x0b4b4500
kworker/5:3-1677 [005] … 356.639016: rtos_queue_peek_from_isr_failed: tstamp:11430258436 queue:0x0b4b4500
kworker/5:3-1677 [005] … 356.807015: rtos_queue_peek_from_isr_failed: tstamp:11435258438 queue:0x0b4b4500
kworker/5:3-1677 [005] … 356.975003: rtos_queue_peek_from_isr_failed: tstamp:11440258445 queue:0x0b4b4500
kworker/5:3-1677 [005] … 357.143017: rtos_queue_peek_from_isr_failed: tstamp:11445258451 queue:0x0b4b4500
kworker/5:3-1677 [005] … 357.311009: rtos_queue_peek_from_isr_failed: tstamp:11450258460 queue:0x0b4b4500
kworker/5:3-1677 [005] … 357.479006: rtos_queue_peek_from_isr_failed: tstamp:11455258470 queue:0x0b4b4500
kworker/5:3-1677 [005] … 357.647007: rtos_queue_peek_from_isr_failed: tstamp:11460258473 queue:0x0b4b4500
kworker/5:3-1677 [005] … 357.759020: rtos_queue_peek_from_isr_failed: tstamp:11465258478 queue:0x0b4b4500
kworker/5:3-1677 [005] … 357.927007: rtos_queue_peek_from_isr_failed: tstamp:11470258498 queue:0x0b4b4500
kworker/5:3-1677 [005] … 358.095019: rtos_queue_peek_from_isr_failed: tstamp:11475258498 queue:0x0b4b4500
kworker/5:3-1677 [005] … 358.263029: rtos_queue_peek_from_isr_failed: tstamp:11480258513 queue:0x0b4b4500
kworker/5:3-1677 [005] … 358.431010: rtos_queue_peek_from_isr_failed: tstamp:11485258510 queue:0x0b4b4500
kworker/5:3-1677 [005] … 358.599007: rtos_queue_peek_from_isr_failed: tstamp:11490258526 queue:0x0b4b4500
kworker/5:3-1677 [005] … 358.767020: rtos_queue_peek_from_isr_failed: tstamp:11495258519 queue:0x0b4b4500
kworker/5:3-1677 [005] … 358.879032: rtos_queue_peek_from_isr_failed: tstamp:11500258539 queue:0x0b4b4500
kworker/5:3-1677 [005] … 359.047007: rtos_queue_peek_from_isr_failed: tstamp:11505258535 queue:0x0b4b4500
kworker/5:3-1677 [005] … 359.215021: rtos_queue_peek_from_isr_failed: tstamp:11510258552 queue:0x0b4b4500
kworker/5:3-1677 [005] … 359.383026: rtos_queue_peek_from_isr_failed: tstamp:11515258551 queue:0x0b4b4500
kworker/5:3-1677 [005] … 359.551015: rtos_queue_peek_from_isr_failed: tstamp:11520258579 queue:0x0b4b4500
kworker/5:3-1677 [005] … 359.719028: rtos_queue_peek_from_isr_failed: tstamp:11525258647 queue:0x0b4b4500
kworker/5:3-1677 [005] … 359.887034: rtos_queue_peek_from_isr_failed: tstamp:11530258592 queue:0x0b4b4500
kworker/5:3-1677 [005] … 359.999021: rtos_queue_peek_from_isr_failed: tstamp:11535258611 queue:0x0b4b4500
kworker/5:3-1677 [005] … 360.167023: rtos_queue_peek_from_isr_failed: tstamp:11540258605 queue:0x0b4b4500
kworker/5:3-1677 [005] … 360.335034: rtos_queue_peek_from_isr_failed: tstamp:11545258612 queue:0x0b4b4500
kworker/5:3-1677 [005] … 360.503045: rtos_queue_peek_from_isr_failed: tstamp:11550258617 queue:0x0b4b4500
kworker/5:3-1677 [005] … 360.671023: rtos_queue_peek_from_isr_failed: tstamp:11555258627 queue:0x0b4b4500
kworker/5:3-1677 [005] … 360.839024: rtos_queue_peek_from_isr_failed: tstamp:11560258633 queue:0x0b4b4500
kworker/5:3-1677 [005] … 361.007038: rtos_queue_peek_from_isr_failed: tstamp:11565258640 queue:0x0b4b4500
kworker/5:3-1677 [005] … 361.119023: rtos_queue_peek_from_isr_failed: tstamp:11570258646 queue:0x0b4b4500
kworker/5:3-1677 [005] … 361.287057: rtos_queue_peek_from_isr_failed: tstamp:11575258653 queue:0x0b4b4500
kworker/5:3-1677 [005] … 361.455031: rtos_queue_peek_from_isr_failed: tstamp:11580258659 queue:0x0b4b4500
kworker/5:3-1677 [005] … 361.623027: rtos_queue_peek_from_isr_failed: tstamp:11585258680 queue:0x0b4b4500
kworker/5:3-1677 [005] … 361.791040: rtos_queue_peek_from_isr_failed: tstamp:11590258678 queue:0x0b4b4500
kworker/5:3-1677 [005] … 361.959026: rtos_queue_peek_from_isr_failed: tstamp:11595258658 queue:0x0b4b4500
kworker/5:3-1677 [005] … 362.127035: rtos_queue_peek_from_isr_failed: tstamp:11600258669 queue:0x0b4b4500
kworker/5:3-1677 [005] … 362.239023: rtos_queue_peek_from_isr_failed: tstamp:11605258670 queue:0x0b4b4500
kworker/5:3-1677 [005] … 362.407041: rtos_queue_peek_from_isr_failed: tstamp:11610258686 queue:0x0b4b4500
kworker/5:3-1677 [005] … 362.575031: rtos_queue_peek_from_isr_failed: tstamp:11615258683 queue:0x0b4b4500
kworker/5:3-1677 [005] … 362.743032: rtos_queue_peek_from_isr_failed: tstamp:11620258692 queue:0x0b4b4500
kworker/5:3-1677 [005] … 362.911026: rtos_queue_peek_from_isr_failed: tstamp:11625258709 queue:0x0b4b4500
kworker/5:3-1677 [005] … 363.079853: rtos_queue_peek_from_isr_failed: tstamp:11630258706 queue:0x0b4b4500
kworker/5:3-1677 [005] … 363.247088: rtos_queue_peek_from_isr_failed: tstamp:11635258724 queue:0x0b4b4500
kworker/5:3-1677 [005] … 363.359040: rtos_queue_peek_from_isr_failed: tstamp:11640258720 queue:0x0b4b4500
kworker/5:3-1677 [005] … 363.527025: rtos_queue_peek_from_isr_failed: tstamp:11645258736 queue:0x0b4b4500
kworker/5:3-1677 [005] … 363.695053: rtos_queue_peek_from_isr_failed: tstamp:11650258737 queue:0x0b4b4500
AoltmStage-8756 [000] … 363.742192: tegra_channel_close: vi-output, imx290 2-001a
AoltmStage-8756 [000] … 363.742201: tegra_channel_set_stream: enable : 0x0
AoltmStage-8756 [000] … 363.742202: tegra_channel_set_stream: imx290 2-001a : 0x0
kworker/5:3-1677 [005] … 363.750986: rtos_queue_send_from_isr_failed: tstamp:11652408932 queue:0x0b4a7258
kworker/5:3-1677 [005] … 363.750990: rtos_queue_send_from_isr_failed: tstamp:11652409042 queue:0x0b4aad68
kworker/5:3-1677 [005] … 363.750991: rtos_queue_send_from_isr_failed: tstamp:11652409150 queue:0x0b4ac998
kworker/5:3-1677 [005] … 363.750993: rtos_queue_send_from_isr_failed: tstamp:11652409256 queue:0x0b4ae518
kworker/5:3-1677 [005] … 363.750994: rtos_queue_send_from_isr_failed: tstamp:11652409361 queue:0x0b4af2d8
kworker/5:3-1677 [005] … 363.750995: rtos_queue_send_from_isr_failed: tstamp:11652409479 queue:0x0b4b0098
kworker/5:3-1677 [005] … 363.750997: rtos_queue_send_from_isr_failed: tstamp:11652409585 queue:0x0b4b0e58
kworker/5:3-1677 [005] … 363.750998: rtos_queue_send_from_isr_failed: tstamp:11652409690 queue:0x0b4b1c18
kworker/5:3-1677 [005] … 363.751000: rtos_queue_send_failed: tstamp:11652410170 queue:0x0b4a7258
AoltmStage-8756 [000] … 363.830057: tegra_channel_set_stream: 150c0000.nvcsi–1 : 0x0
AoltmStage-8756 [000] … 363.830067: csi_s_stream: enable : 0x0
AoltmStage-8756 [000] … 363.832737: tegra_channel_set_power: imx290 2-001a : 0x0
AoltmStage-8756 [000] … 363.832758: camera_common_s_power: status : 0x0
AoltmStage-8756 [000] … 363.833065: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
AoltmStage-8756 [000] … 363.833073: csi_s_power: enable : 0x0
kworker/5:3-1677 [005] … 363.866959: rtos_queue_peek_from_isr_failed: tstamp:11655258752 queue:0x0b4b4500
kworker/5:3-1677 [005] … 364.035057: rtos_queue_peek_from_isr_failed: tstamp:11660258747 queue:0x0b4b4500
kworker/5:3-1677 [005] … 364.203041: rtos_queue_peek_from_isr_failed: tstamp:11665258765 queue:0x0b4b4500
kworker/5:3-1677 [005] … 364.315041: rtos_queue_peek_from_isr_failed: tstamp:11670258759 queue:0x0b4b4500
kworker/5:3-1677 [005] … 364.483065: rtos_queue_peek_from_isr_failed: tstamp:11675258765 queue:0x0b4b4500
kworker/5:3-1677 [005] … 364.651048: rtos_queue_peek_from_isr_failed: tstamp:11680258774 queue:0x0b4b4500
kworker/5:3-1677 [005] … 364.819060: rtos_queue_peek_from_isr_failed: tstamp:11685258793 queue:0x0b4b4500
kworker/5:3-1677 [005] … 364.987056: rtos_queue_peek_from_isr_failed: tstamp:11690258787 queue:0x0b4b4500
kworker/5:3-1677 [005] … 365.155042: rtos_queue_peek_from_isr_failed: tstamp:11695258793 queue:0x0b4b4500
kworker/5:3-1677 [005] … 365.323047: rtos_queue_peek_from_isr_failed: tstamp:11700258802 queue:0x0b4b4500
kworker/5:3-1677 [005] … 365.435057: rtos_queue_peek_from_isr_failed: tstamp:11705258808 queue:0x0b4b4500
kworker/5:3-1677 [005] … 365.603045: rtos_queue_peek_from_isr_failed: tstamp:11710258827 queue:0x0b4b4500
kworker/5:3-1677 [005] … 365.771041: rtos_queue_peek_from_isr_failed: tstamp:11715258821 queue:0x0b4b4500
kworker/5:3-1677 [005] … 365.939071: rtos_queue_peek_from_isr_failed: tstamp:11720258846 queue:0x0b4b4500
kworker/5:3-1677 [005] … 366.107080: rtos_queue_peek_from_isr_failed: tstamp:11725258852 queue:0x0b4b4500
kworker/5:3-1677 [005] … 366.275103: rtos_queue_peek_from_isr_failed: tstamp:11730258863 queue:0x0b4b4500
kworker/5:3-1677 [005] … 366.443077: rtos_queue_peek_from_isr_failed: tstamp:11735258867 queue:0x0b4b4500
kworker/5:3-1677 [005] … 366.555054: rtos_queue_peek_from_isr_failed: tstamp:11740258874 queue:0x0b4b4500
kworker/5:3-1677 [005] … 366.723080: rtos_queue_peek_from_isr_failed: tstamp:11745258880 queue:0x0b4b4500
kworker/5:3-1677 [005] … 366.891085: rtos_queue_peek_from_isr_failed: tstamp:11750258887 queue:0x0b4b4500
kworker/5:3-1677 [005] … 367.059081: rtos_queue_peek_from_isr_failed: tstamp:11755258893 queue:0x0b4b4500
kworker/5:3-1677 [005] … 367.227054: rtos_queue_peek_from_isr_failed: tstamp:11760258901 queue:0x0b4b4500
kworker/5:3-1677 [005] … 367.395053: rtos_queue_peek_from_isr_failed: tstamp:11765258908 queue:0x0b4b4500
kworker/5:3-1677 [005] … 367.567102: rtos_queue_peek_from_isr_failed: tstamp:11770258914 queue:0x0b4b4500
kworker/5:3-1677 [005] … 367.679091: rtos_queue_peek_from_isr_failed: tstamp:11775258921 queue:0x0b4b4500
kworker/5:3-1677 [005] … 367.847101: rtos_queue_peek_from_isr_failed: tstamp:11780258940 queue:0x0b4b4500
kworker/5:3-1677 [005] … 368.015072: rtos_queue_peek_from_isr_failed: tstamp:11785258934 queue:0x0b4b4500
kworker/5:3-1677 [005] … 368.183062: rtos_queue_peek_from_isr_failed: tstamp:11790258952 queue:0x0b4b4500
kworker/5:3-1677 [005] … 368.351055: rtos_queue_peek_from_isr_failed: tstamp:11795258949 queue:0x0b4b4500
kworker/5:3-1677 [005] … 368.519067: rtos_queue_peek_from_isr_failed: tstamp:11800259000 queue:0x0b4b4500
kworker/5:3-1677 [005] … 368.687086: rtos_queue_peek_from_isr_failed: tstamp:11805258969 queue:0x0b4b4500
kworker/5:3-1677 [005] … 368.799072: rtos_queue_peek_from_isr_failed: tstamp:11810258986 queue:0x0b4b4500
kworker/5:3-1677 [005] … 368.967099: rtos_queue_peek_from_isr_failed: tstamp:11815258983 queue:0x0b4b4500
kworker/5:3-1677 [005] … 369.023092: rtos_queue_peek_from_isr_failed: tstamp:11815698723 queue:0x0b4b4500
[ 85.065323] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 85.071816] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 85.285329] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 85.291713] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 85.505355] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 85.511736] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 85.725375] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 85.731867] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 85.743960] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 85.751906] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
[ 85.961346] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 85.967739] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 85.977636] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 85.985511] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
[ 86.197452] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
https://wiki.nvidia.com/wmpwiki/index.php/Camera_Debugging not available, where can I get more information on debugging?
Can anyone tell me what the problem is?
Maybe I need to add some more information to get an answer?
