Ubuntu 11.10 SDK compile threadFenceReduction Failed to compile threadFenceReduction
Hi all
I have a fresh install of Ubuntu 11.10 using gcc --version and vith latest nvidia drivers
gcc-4.4 (Ubuntu/Linaro 4.4.6-11ubuntu2) 4.4.6 with the CUDA 4.0 SDK.
I have followed all instructions here:
http://www.vectorfabrics.com/blog/item/cuda_4.0_on_ubuntu_11.04
and have:
-L/usr/lib/nvidia-current in my common.mk
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib64
/usr/local/cuda/bin on the PATH
have a GEFORCE 9500 but when I do a make in NVIDIA_GPU_Computing_SDK/C I get
make -C src/threadFenceReduction/
make[1]: Entering directory `/home/dev/NVIDIA_GPU_Computing_SDK/C/src/threadFenceReduction'
threadFenceReduction.cu: In function ‘int main(int, char**)’:
threadFenceReduction.cu:119:167: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘char*’ [-Wformat]
obj/x86_64/release/threadFenceReduction.cu_11.o: In function `getNumBlocksAndThreads(int, int, int, int&, int&)':
tmpxft_00003d8c_00000000-4_threadFenceReduction.compute_20.cudafe1.cpp:(.text+0xf7b): undefined reference to `max'
tmpxft_00003d8c_00000000-4_threadFenceReduction.compute_20.cudafe1.cpp:(.text+0xf87): undefined reference to `min'
obj/x86_64/release/threadFenceReduction.cu_11.o: In function `shmoo(int, int, int, int)':
tmpxft_00003d8c_00000000-4_threadFenceReduction.compute_20.cudafe1.cpp:(.text+0x144e): undefined reference to `min'
collect2: ld returned 1 exit status
make[1]: *** [../../bin/linux/release/threadFenceReduction] Error 1
make[1]: Leaving directory `/home/dev/NVIDIA_GPU_Computing_SDK/C/src/threadFenceReduction'
make: *** [src/threadFenceReduction/Makefile.ph_build] Error 2
Using
GNU Make 3.81
Can anyone please help? Is this missing libraries or something else? I’d really like to get started with CUDA.
Thanks in advance :thanks:
