hi
i have a vm in VMware ESXi 6 with Ubuntu 16.04.4 os. when adding on gpu NVidia gtx 1080i to this vm as passthrough and install latest NVidia driver (396.26), after reboot graphical environment do not work correctly and screen is black. when run NVidia-smi -q command display below info
root@ubuntu:~# nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Sat Jun 2 02:23:47 2018
Driver Version : 396.26
Attached GPUs : 1
GPU 00000000:0B:00.0
Product Name : GeForce GTX 1080 Ti
Product Brand : GeForce
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-427e2765-b340-cea6-b62d-d282f1ef4653
Minor Number : 0
VBIOS Version : 86.02.39.00.23
MultiGPU Board : No
Board ID : 0xb00
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.01.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x0B
Device : 0x00
Domain : 0x0000
Device Id : 0x1B0610DE
Bus Id : 00000000:0B:00.0
Sub System Id : 0x85EA1043
GPU Link Info
PCIe Generation
Max : 3
Current : 2
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : 0 %
Performance State : P5
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
FB Memory Usage
Total : 11178 MiB
Used : 0 MiB
Free : 11178 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Compute Mode : Default
Utilization
Gpu : 2 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 37 C
GPU Shutdown Temp : 96 C
GPU Slowdown Temp : 93 C
GPU Max Operating Temp : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 18.45 W
Power Limit : 275.00 W
Default Power Limit : 275.00 W
Enforced Power Limit : 275.00 W
Min Power Limit : 125.00 W
Max Power Limit : 330.00 W
Clocks
Graphics : 139 MHz
SM : 139 MHz
Memory : 810 MHz
Video : 734 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1999 MHz
SM : 1999 MHz
Memory : 5505 MHz
Video : 1620 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : None
Someone can help me ?
tanks
nvidia-bug-report.log.gz (111 KB)
