Ubuntu 16.04 input lock (?) using x-server and lightdm - Gtx 1060 6gb
I’m transitioning from an RX-480 to a GTX-1060 on my main box, and I’ve opted to install the proprietary driver.
I’ve blacklisted nouveau, removed all of my old AMD drivers, and installed the proprietary drivers via commandline using the script provided on website.
My xorg logs indicate that the driver’s loading properly, everything on my screen is working as it should. When I run startx the system boots my desktop just fine, but it refuses any and all input.
I’ve been consistently getting this error message when I start up X:
systemd-logind[ {SOME NUMBER, ALWAYS CHANGES} ]: Failed to enable subscription: Launch helper exited with unknown return code 1
systemd-logind[ {SAME NUMBER AS BEFORE} ]: Failed to fully start up daemon: Input/output error
and glxinfo returns:
Error: unable to open display
lsmod | grep -i nvidia
nvidia_drm           49152   0
nvidia_modeset      843776   1 nvidia_drm
nvidia            12984320   1 nvidia_modeset
drm_kms_helper      155648   1 nvidia_drm
drm                 364544   3 drm_kms_helper,nvidia_drm
lscpi | grep -i VGA
03:00.0 VGA compatible controller: NVIDIA Corporation Device 1c03 (rev a1)
nvidia-installer.log (2.94 KB)
nvidia-bug-report.log.gz (118 KB)
