So I thought I’d try to officially change from the CUDA 8 RC to the real CUDA 8. So I downloaded the .run file and proceeded to somehow just destroy my system. I think it was because I said “yes” to letting it configure x-server stuff. Huge. Mistake.
Basically, after spending all day on this, I’ve cleared and purged everything multiple times, finally got my display working and solved an infinite login loop.
The only issue is, I’m having CMake issues now.
I kind of just gave up with how Nvidia wants us to install CUDA. The local method takes too long to download the files and the network method just doesn’t seem to do anything. I can’t ever locate the package using apt-get.
But there is the Ubuntu package nvidia-cuda-toolkit which I’ve installed successfully! I have nvcc back and all that happiness but now when I try to compile my project using CMake, I keep getting undefined references to cudaCreateStream and other basic CUDA functions like that.
What’s interesting is that Ubuntu’s nvidia-cuda-toolkit doesn’t actually install to /usr/local/cuda so I have no idea where anything is or if CMake is even looking there.
I can use nvcc to compile a stand-alone “Hello, world!” file with a cudaDeviceSynchronize() but I’m wondering how do I fix CMake to compile?
Here’s my CMakeLists.txt:
cmake_minimum_required(VERSION 3.2)
project(regulus)
find_package(CUDA REQUIRED)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -D_FORCE_INLINES")
set(CMAKE_CXX_STANDARD 11)
set(CUDA_HOST_COMPILATION_CPP ON)
set(CUDA_SEPARABLE_COMPILATION ON)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -Wextra -Wno-unused-parameter")
# Pass options to NVCC
list(APPEND
CUDA_NVCC_FLAGS
${CUDA_NVCC_FLAGS};
-gencode arch=compute_50,code=sm_50
-std=c++11
-O3
--expt-extended-lambda
cuda_add_executable(
regulus
main.cu
include/domain.hpp
include/timer.hpp
include/mesher.hpp
include/array.hpp
include/globals.hpp
include/stack-vector.hpp
include/math/math.hpp
include/math/point.hpp
include/math/matrix.hpp
include/math/equals.hpp
include/math/tetra.hpp
include/math/rand-int-range.hpp
include/lib/calc-ta-and-pa.hpp
include/lib/nominate.hpp
include/lib/fract-locations.hpp
include/lib/fracture.hpp
include/lib/redistribute-pts.hpp
include/lib/get-assoc-size.hpp
include/lib/mark-nominated-tetra.hpp
tests/test-suite.hpp
src/point.cu
src/peano.cu
src/nominate.cu
src/fract-locations.cu
src/fracture.cu
src/get-assoc-size.cu
src/rand-int-range.cu
src/mark-nominated-tetra.cu
tests/test-suite.cu
tests/domain-tests.cu
tests/mesher-tests.cu
tests/math-tests.cu
tests/matrix-tests.cu
tests/array-tests.cu
tests/tetra-tests.cu
tests/nomination-tests.cu
tests/fract-location-tests.cu
tests/fracture-tests.cu
tests/redistribute-pts-tests.cu
tests/stack-vector-tests.cu
tests/get-assoc-size-tests.cu
target_link_libraries(
regulus
cudart
cudadevrt
And here’s my linking errors:
[ 4%] Building NVCC intermediate link file CMakeFiles/regulus.dir/regulus_intermediate_link.o
nvlink error : Undefined reference to 'cudaEventDestroy' in '/home/christian/cuda/regulus/build/CMakeFiles/regulus.dir/src/./regulus_generated_nominate.cu.o'
nvlink error : Undefined reference to 'cudaGetErrorString' in '/home/christian/cuda/regulus/build/CMakeFiles/regulus.dir/src/./regulus_generated_nominate.cu.o'
nvlink error : Undefined reference to 'cudaStreamDestroy' in '/home/christian/cuda/regulus/build/CMakeFiles/regulus.dir/src/./regulus_generated_nominate.cu.o'
nvlink error : Undefined reference to 'cudaGetParameterBuffer' in '/home/christian/cuda/regulus/build/CMakeFiles/regulus.dir/src/./regulus_generated_nominate.cu.o'
nvlink error : Undefined reference to 'cudaLaunchDevice' in '/home/christian/cuda/regulus/build/CMakeFiles/regulus.dir/src/./regulus_generated_nominate.cu.o'
nvlink error : Undefined reference to 'cudaDeviceSynchronize' in '/home/christian/cuda/regulus/build/CMakeFiles/regulus.dir/src/./regulus_generated_nominate.cu.o'
nvlink error : Undefined reference to 'cudaEventCreateWithFlags' in '/home/christian/cuda/regulus/build/CMakeFiles/regulus.dir/src/./regulus_generated_nominate.cu.o'
nvlink error : Undefined reference to 'cudaEventRecord' in '/home/christian/cuda/regulus/build/CMakeFiles/regulus.dir/src/./regulus_generated_nominate.cu.o'
CMakeFiles/regulus.dir/build.make:13928: recipe for target 'CMakeFiles/regulus.dir/regulus_intermediate_link.o' failed
make[2]: *** [CMakeFiles/regulus.dir/regulus_intermediate_link.o] Error 255
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/regulus.dir/all' failed
make[1]: *** [CMakeFiles/regulus.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
