Most times when I start my PC it crashes on boot, after 1-2 restarts it works. I have tried to update to newest kernel and latest nvidia driver in the past, but the issues remained.
Currently I am using Ubuntu 18.04.1 LTS
with kernel 4.20.3-042003-generic
. I have the graphic card GeForce GTX 1070/PCIe/SSE2
. I am using nvidia-driver-415.
I know that the latest driver is version 418.43, but I don’t know how to install it on Ubuntu. In the official PPA sudo add-apt-repository ppa:graphics-drivers/ppa the latest driver is 415.
Here is a screenshot of the error from my log boot.
The problematic line is this one:
kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000927c:0:0
Any ideas how I can fix it?
Here is the full log of my last boot:
ukuu.desktop[2925]: ----------------------------------------------------------------------
ukuu.desktop[2925]: Found installed: 4.15.0.45.47
ukuu.desktop[2925]: Found installed: 4.15.0-44.47
ukuu.desktop[2925]: Found installed: 4.15.0-45.48
ukuu.desktop[2925]: Found installed: 4.20.3-042003.201901171122
ukuu.desktop[2925]: No updates found
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): BenQ BL2706HT (DFP-0): connected
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): BenQ BL2706HT (DFP-0): Internal TMDS
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): BenQ BL2706HT (DFP-0): 165.0 MHz maximum pixel clock
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): BenQ BL2706HT (DFP-1): connected
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): BenQ BL2706HT (DFP-1): Internal TMDS
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): BenQ BL2706HT (DFP-1): 0.0 MHz maximum pixel clock
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-2: disconnected
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-3: disconnected
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-4: disconnected
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-5: disconnected
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-6: disconnected
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-7: disconnected
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
/usr/lib/gdm3/gdm-x-session[1587]: (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
gsd-media-keys[2892]: g_variant_get_va: assertion 'value != NULL' failed
gsd-media-keys[2892]: g_variant_unref: assertion 'value != NULL' failed
org.gnome.Shell.desktop[2651]: current session already has an ibus-daemon.
dbus-daemon[1317]: [system] Activating via systemd: service name='org.freedesktop.GeoClue2' unit='geoclue.service' requested by ':1.88' (uid=1000 pid=2651 comm="/usr/bin/gnome-shell
systemd[1]: Starting Location Lookup Service...
dbus-daemon[1317]: [system] Successfully activated service 'org.freedesktop.GeoClue2'
systemd[1]: Started Location Lookup Service.
polkitd(authority=local)[1411]: Registered Authentication Agent for unix-session:1 (system bus name :1.88 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/Authenticati
gnome-shell[2651]: Telepathy is not available, chat integration will be disabled.
gnome-shell[2651]: JS WARNING: [/usr/share/gnome-shell/extensions/ubuntu-dock@ubuntu.com/appIcons.js 1028]: unreachable code after return statement
dropbox[2964]: Unable to connect to the Notification Watcher: Timeout was reached
update-notifier[3287]: Unable to connect to the Notification Watcher: Timeout was reached
gsd-xsettings[2841]: Failed to get current display configuration state: Timeout was reached
