Ubuntu 18.04 login loop after JDK update
I have a Dell Precision T5500 with an NVIDIA G98 [Quadro NVS 420] running Ubuntu 18.04.
I ran into the login loop problem after updating from Java JDK 8 to JDK 11 and rebooting.
I tried workarounds like
  • ``` dpkg-reconfigure lightDM ```
  • ``` chown user:user .Xauthority ```
  • ``` mv .Xauthority .Xauthority.bak ```
etc. I eventually purged NVIDIA drivers using
sudo apt-get purge nvidia*
and tried rebooting and logging in, unsuccessfully, before attempting to reinstall drivers.
I tried multiple combinations of purging drivers and reinstalling using
sudo ubuntu-drivers autoinstall
and
sudo apt install nvidia-340
(recommended driver),
and also tried using apt-get to fix missing and broken packages.
I ensured that there is no ‘nomodeset’ kernel parameter, and tried running
grep modeset /etc/modprobe.d/* /lib/modprobe.d/*
which returned no result even when using sudo.
I’ve attached a log file created after rebooting the computer and trying to log in once.
nvidia-bug-report.log.gz (83.6 KB)
Please post the output of
ls -l /usr/lib/x86_64-linux-gnu/libGL*
Here it is
output.txt (3.44 KB)
Are you running lightdm or gdm as DM? Which DE, Gnome?
Please post the complete output of
sudo apt install --reinstall nvidia-340
I’m running lightDM, which seems to be the only DM installed.
I have Gnome 3.28.4.
output_reinstall.txt (4.92 KB)
Anything seems to be correctly in place and no diversion errors show up on driver reinstall either.
Please check if this is a broken user profile by just creating a new user and loggin in as that.
The same login error occurs for all users. I can still log in from the terminal but cannot otherwise.
Please run
sudo journalctl -b0 --no-pager >journal.txt
and attach the output file.
Here it is
journal.txt.zip (486 KB)
