Ubuntu 18.04 MX-150 crash on screen resume
I experience a number of problems with this display.
The diagnostic log is attached.
When the screen saver comes on all open applications stay running, but as soon as I then enter the password to resume, the apps all close, the X session closes and I basically have a clean slate.
Occasionally this does not happen, but more often than not it does happen.
Here the link to the log: Dropbox - File Deleted
Since this is an Optimus system, the display is driven by the intel gpu. In dmesg, you’re getting the error
[drm:skl_ddi_pll_enable [i915]] *ERROR* DPLL 1 not locked
I suspect this could lead to the igpu losing the display on turning it off.
Please check if you can reproduce this when switching to intel mode (sudo prime-select intel, reboot) and if upgrading the kernel to 4.17 or 4.18 fixes the issue.
I switched to intel mode and the problem has gone away, so no, I could not replicate it.
Wrt the upgrading of the kernel: I had a newer kernel installed, but it made the machine quite unstable. So I switched back to the mainline kernel.
If this istthe NVidia driver failing, then what is the solution? Simply selecting the Intel display bypasses the problem, but it doesn’t solve it.
I installed kernel 4.18.8 and switch back to NVidia mode, but the systems just hangs after a while. It seems to boot fine, I can log in, but then within a minute or two, the whole system freezes. Only a forced power-off will get it back up.
When this is happening, is the login still avalable at VT7? Use CTRL+Alt+F7 to switch to it.
Does it also happen when you disconnect the external monitor?
When it happens (system freeze), nothing responds any more. Can’t get to a console ctlr-alt-F1 or F7.
More on my original problem: I switched to intel mode and tested it yesterday, but clearly not well enought because I just had a screen blank timeout (set to 5 min this morning) and when I entered my password all my apps crashed again. So, in reference to whether I can reproduce the error with intel mode: yes, I can.
Here’s my full hardware stack:
roland@roland-zenbook:~$ sudo lshw
[sudo] password for roland:
roland-zenbook
    description: Convertible
    product: UX461UN
    vendor: ASUSTeK COMPUTER INC.
    version: 1.0
    serial: J1N0CX17A84604B
    width: 64 bits
    capabilities: smbios-3.0 dmi-3.0 smp vsyscall32
    configuration: boot=normal chassis=convertible family=UX uuid=4A314E30-4358-3137-4138-343630344241
  *-core
       description: Motherboard
       product: UX461UN
       physical id: 0
       version: 1.0
       serial: QCCBKQ0JE80300258
       slot: MIDDLE
     *-firmware
          description: BIOS
          vendor: American Megatrends Inc.
          physical id: 0
          version: UX461UN.305
          date: 12/04/2017
          capacity: 8128KiB
          capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification uefi
     *-memory
          description: System Memory
          physical id: 8
          slot: System board or motherboard
        *-bank:0
             description: Row of chips LPDDR3 Synchronous Unbuffered (Unregistered) 2133 MHz (0.5 ns)
             product: K4EBE304EB-EGCG
             vendor: Samsung
             physical id: 0
             serial: 55000000
             slot: ChannelA-DIMM0
             width: 64 bits
             clock: 2133MHz (0.5ns)
        *-bank:1
             vendor: Samsung
             physical id: 1
             serial: 55000000
             slot: ChannelB-DIMM0
             width: 64 bits
     *-cache:0
          description: L1 cache
          physical id: d
          slot: L1 Cache
          capacity: 256KiB
          capabilities: synchronous internal write-back unified
          configuration: level=1
     *-cache:1
          description: L2 cache
          physical id: e
          slot: L2 Cache
          capacity: 1MiB
          configuration: level=2
     *-cache:2
          description: L3 cache
          physical id: f
          slot: L3 Cache
          capacity: 8MiB
          configuration: level=3
     *-cpu
          description: CPU
          product: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
          vendor: Intel Corp.
          physical id: 10
          bus info: cpu@0
          version: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
          serial: To Be Filled By O.E.M.
          slot: U3E1
          capacity: 4005MHz
          width: 64 bits
          clock: 100MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves ibpb ibrs stibp dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp cpufreq
          configuration: cores=4 enabledcores=4 threads=8
     *-pci
          description: Host bridge
          product: Intel Corporation
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 08
          width: 32 bits
          clock: 33MHz
        *-display
             description: VGA compatible controller
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 07
             width: 64 bits
             clock: 33MHz
             capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:134 memory:ed000000-edffffff memory:c0000000-cfffffff ioport:f000(size=64) memory:c0000-dffff
        *-generic:0
             description: Signal processing controller
             product: Skylake Processor Thermal Subsystem
             physical id: 4
             bus info: pci@0000:00:04.0
             version: 08
             width: 64 bits
             clock: 33MHz
             capabilities: msi pm cap_list
             configuration: driver=proc_thermal latency=0
             resources: irq:16 memory:ef320000-ef327fff
        *-generic:1
             description: Non-VGA unclassified device
             physical id: 13
             bus info: pci@0000:00:13.0
             version: 21
             width: 64 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
             configuration: driver=intel_ish_ipc latency=0
             resources: irq:20 memory:ef337000-ef337fff
        *-usb
             description: USB controller
             product: Sunrise Point-LP USB 3.0 xHCI Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 21
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:126 memory:ef310000-ef31ffff
           *-usbhost:0
                product: xHCI Host Controller
                vendor: Linux 4.15.18-041518-generic xhci-hcd
                physical id: 0
                bus info: usb@1
                logical name: usb1
                version: 4.15
                capabilities: usb-2.00
                configuration: driver=hub slots=12 speed=480Mbit/s
              *-usb:0
                   description: Video
                   product: USB2.0 HD UVC WebCam
                   vendor: Azurewave
                   physical id: 5
                   bus info: usb@1:5
                   version: 17.04
                   serial: 0x0001
                   configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
              *-usb:1
                   description: Bluetooth wireless interface
                   vendor: Intel Corp.
                   physical id: 8
                   bus info: usb@1:8
                   version: 0.10
                   capabilities: bluetooth usb-2.00
                   configuration: driver=btusb maxpower=100mA speed=12Mbit/s
           *-usbhost:1
                physical id: 1
                bus info: usb@2
                logical name: usb2
                version: 4.15
                capabilities: usb-3.00
                configuration: driver=hub slots=6 speed=5000Mbit/s
        *-generic:2
             product: Sunrise Point-LP Thermal subsystem
             physical id: 14.2
             bus info: pci@0000:00:14.2
             version: 21
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi cap_list
             configuration: driver=intel_pch_thermal latency=0
             resources: irq:18 memory:ef336000-ef336fff
        *-generic:3
             product: Sunrise Point-LP Serial IO I2C Controller #0
             physical id: 15
             bus info: pci@0000:00:15.0
             version: 21
             width: 64 bits
             clock: 33MHz
             configuration: driver=intel-lpss latency=0
             resources: irq:16 memory:ef335000-ef335fff
        *-generic:4
             product: Sunrise Point-LP Serial IO I2C Controller #1
             physical id: 15.1
             bus info: pci@0000:00:15.1
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: irq:17 memory:ef334000-ef334fff
        *-communication
             description: Communication controller
             product: Sunrise Point-LP CSME HECI #1
             physical id: 16
             bus info: pci@0000:00:16.0
             version: 21
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=mei_me latency=0
             resources: irq:135 memory:ef333000-ef333fff
        *-pci:0
             description: PCI bridge
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: f1
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:122 ioport:e000(size=4096) memory:ee000000-ef0fffff ioport:d0000000(size=301989888)
           *-display
                description: 3D controller
                product: NVIDIA Corporation
                vendor: NVIDIA Corporation
                physical id: 0
                bus info: pci@0000:01:00.0
                version: a1
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list rom
                configuration: driver=nouveau latency=0
                resources: irq:143 memory:ee000000-eeffffff memory:d0000000-dfffffff memory:e0000000-e1ffffff ioport:e000(size=128) memory:ef000000-ef07ffff
        *-pci:1
             product: Sunrise Point-LP PCI Express Root Port #7
             physical id: 1c.6
             bus info: pci@0000:00:1c.6
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:123 memory:ef200000-ef2fffff
           *-network
                description: Wireless interface
                product: Wireless 8265 / 8275
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: wlp2s0
                version: 78
                serial: e0:9d:31:f2:c0:f6
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=iwlwifi driverversion=4.15.18-041518-generic firmware=34.0.1 ip=192.168.112.93 latency=0 link=yes multicast=yes wireless=IEEE 802.11
                resources: irq:138 memory:ef200000-ef201fff
        *-pci:2
             product: Sunrise Point-LP PCI Express Root Port #9
             physical id: 1d
             bus info: pci@0000:00:1d.0
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:124 memory:ef100000-ef1fffff
           *-storage
                description: Non-Volatile memory controller
                physical id: 0
                bus info: pci@0000:03:00.0
                version: 03
                width: 64 bits
                clock: 33MHz
                capabilities: storage pm pciexpress msix nvm_express bus_master cap_list
                configuration: driver=nvme latency=0
                resources: irq:16 memory:ef100000-ef103fff
        *-generic:5
             product: Sunrise Point-LP Serial IO UART Controller #0
             physical id: 1e
             bus info: pci@0000:00:1e.0
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: irq:20 memory:ef332000-ef332fff
        *-generic:6
             product: Sunrise Point-LP Serial IO SPI Controller #0
             physical id: 1e.2
             bus info: pci@0000:00:1e.2
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: irq:22 memory:ef331000-ef331fff
        *-isa
             description: ISA bridge
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 21
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master
             configuration: latency=0
        *-memory
             description: Memory controller
             product: Sunrise Point-LP PMC
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             version: 21
             width: 32 bits
             clock: 33MHz (30.3ns)
             configuration: driver=intel_pmc_core latency=0
             resources: irq:0 memory:ef32c000-ef32ffff
        *-multimedia
             description: Audio device
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 21
             width: 64 bits
             clock: 33MHz
             configuration: driver=snd_hda_intel latency=32
             resources: irq:139 memory:ef328000-ef32bfff memory:ef300000-ef30ffff
        *-serial UNCLAIMED
             description: SMBus
             product: Sunrise Point-LP SMBus
             physical id: 1f.4
             bus info: pci@0000:00:1f.4
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: memory:ef330000-ef3300ff ioport:f040(size=32)
  *-network:0 DISABLED
       description: Ethernet interface
       physical id: 1
       logical name: virbr0-nic
       serial: 52:54:00:56:a1:fa
       capabilities: ethernet physical
       configuration: autonegotiation=off broadcast=yes driver=tun driverversion=1.6 duplex=full link=no multicast=yes port=twisted pair speed=10Mbit/s
  *-network:1
       physical id: 2
       configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A ip=192.168.122.1 link=no multicast=yes
I did some tests now and it doesn’t happen in Intel mode without an external monitor.
Can you check if using another cable fixes the issue?
Are you serious?? This happens at a client where I use an external monitor and on two different monitors at home (a projector and a screen). It is definitely a software bug, but I’m not sure who to turn to for a fix. Is it X that crashes, or the Intel driver or NVidia.
If it’s happening while switched to intel, it is very unlikely to be related to the nvidia driver since that’s not even loaded in that case.
Since this is only happening while any external display is attached, this can also be hardware related, maybe some flakey hdmi connector. Does that notebook have different connectors? Do those have the same issue?
In any case, while the system seems frozen, can you ssh in and create a nvidia-bug-report.log?
