Ubuntu 20.04.3 not starting if adding "Option “ColorSpace” “RGB”" in xorg.conf
If adding in xorg.conf the settings below
Option “ColorRange” “Full”
In next OS restart before user login screen the OS is halted and only start if removing the settings above.
LCD monitor is using VGA cable.
I had used the settings above because the documentation explain both settings are used in LCD monitors when using vga cable.
I remember using the settings above using a driver version before versions 470.
Really need the options above ?
Thanks for reply.
Could you post the full contents of the file? (ideally in a code block so the smart quotes don’t interfere)
Thanks for reply.
I have added the settings how are in nvidia documentation and when OS start the OS is halted before user login screen.
Ubuntu 20.04.3
XORG.CONF
nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings: version 470.86
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 470.86
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
Option “Xinerama” “0”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier     "Mouse0"
Driver         "mouse"
Option         "Protocol" "auto"
Option         "Device" "/dev/psaux"
Option         "Emulate3Buttons" "no"
Option         "ZAxisMapping" "4 5"
EndSection
Identifier     "Keyboard0"
Driver         "kbd"
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “LG Electronics E1641”
HorizSync 30.0 - 61.0
VertRefresh 56.0 - 75.0
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BoardName “NVIDIA GeForce GT 640”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “Coolbits” “8”
Option “Stereo” “0”
Option “nvidiaXineramaInfoOrder” “CRT-0”
Option “metamodes” “1366x768_60 +0+0 {ForceCompositionPipeline=On}”
Option “SLI” “Off”
Option “MultiGPU” “Off”
Option “BaseMosaic” “off”
SubSection “Display”
Depth 24
EndSubSection
EndSection
It doesn’t address the specific issue, but as a workaround you don’t need to set these options as they’re the defaults.
Thanks for reply.
I had used the same settings in driver previous version and not problems;
Trying with current version the OS not start.
Thus I had posted here if perhaps is a bug.
might very well be a bug since the settings are correct. Please run nvidia-bug-report.sh as root with your settings in place and attach the resulting nvidia-bug-report.log.gz file to your post.
Processing: nvidia-bug-report.log.gz…
Thanks very much for your reply.
Seems something went wrong, the attachment is still stuck in the virus scanner. Please try attaching it again.
